Installing a cheap carbon fork. Is this normal?
Quoted: 142 Post(s)
Liked 34 Times
Trying to replace an old and heavy suspension fork with a cheap Toseek carbon 27.5 fork.
The steerer has two "ridges" at the bottom, the last one prevents the bottom fork crown race to go all the way down.
Is this normal? Shall I file the ridges off or just force the crown race down?
Quoted: 501 Post(s)
Liked 436 Times
The race should be a firm press fit. You need to support the race evenly so it's dead square as you press it on - if it tilts as in your picture it can dig in, not go on and damage the fork. It might help to gently smooth the carbon with a fine abrasive, but as I can't see/feel what the fit is like I can't recommend it.
Likes For grumpus:
Quoted: 142 Post(s)
Liked 34 Times
I can push it diwn and make it sit square only using my fingers and no tools, though I can't make it go down all the way.
I see youtube videos where they use an extendable race that can be pushed down. Check after 2:40.
Here is mine, still not sure if this is how it is supposed to be or shall I try to get it all the way down.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I'd use a crown race setter with the appropriate diameter and interface. Not worth buying one, IMO, but your LBS can do it in about a minute. Finger-tight isn't how you want it.
Likes For Rolla:
Quoted: 142 Post(s)
Liked 34 Times
Anyway, problem solved now. I figured out that the fork/headset are built to support riders heavier than myself, so I just put the fork into the headset, loaded it with my weight and the race snapped to the bottom of the fork. All is nice and flash now.
Thank you anyway.
Quoted: 5793 Post(s)
Liked 2,584 Times
It's an interference fit, so a decent amount of force is called for.
You can use a short length of faced steel pipe as a slide hammer to do the job.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
Used fingers only to avoid unnecessary damage from rushing, smashing or pressing things harder than needed.
Thank you anyway.
Thank you anyway.
Quoted: 142 Post(s)
Liked 34 Times
Agree in general, but in this particular case the crown race is designed to press against the sealed bearings when we cycle, right? The riders's weight is creating this pressure, so it's supposed to withstand a lot of stress.
Or did I get it wrong?
Anyway, all seems to be good in a visual inspection.
Quoted: 1109 Post(s)
Liked 1,200 Times
That said, I've installed a few races without a tool. Frankly, I never thought of doing it your way and probably would have tried it if I had. But what I've done is I slide them down the steer tube as far as I can by hand, keeping it squared up to the steer tube. I've then seated it by tapping with a wooden stick or dowel and hammer very carefully and in very small increments, slowly and evenly around the race, keeping it squared up, Tiny taps, very evenly. It's actually not that hard to do it, patience and common sense involved. It's pretty crucial to keep it very squared up, because if it gets angled too much it binds. You just have to work your way around bit by bit. A tool would definitely be more fool proof and easier.
Liked 2,584 Times
Not at all. The only issue might have been starting it at an angle.
In fact, it's not at all rare for headsets that weren't pressed in all the way, to settle over the first few rides.
FB
Chain-L site
FB
Chain-L site
Clark W. Griswold
Liked 3,996 Times
