Want to replace centering adjustment screws on Dura Ace BR-7403 brakes
The attached pdf files shows the centering adjustment screws on Dura Ace BR-7403 brakes as Phillips head, but mine are straight. The screws in both the front and rear brakes are tight and the screwdriver tends to slip out of the slot, damaging it. I'd like to replace the centering adjustment screws with Phillips head screws or, even better, with socket head cap screws. One of the attached pdf files says the screws are M4 x 11.7. Is there any reason why the screws at https://www.ebay.com/itm/Genuine-Shi...EAAOSwZ2tcLH41 wouldn't work as replacements?
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
might work. all you can do is try them.
if you have problems with "phillips head screws slipping" consider going to 1/4 hex bits with accurately shaped Phillips drivers. I like the Wera items available on ebay. you can get hex and Torx drivers as well.
A really good Phillips screwdriver, like a Snap On, is OK when new. The one you pull out of the bargain bin at ace hardware will destroy fasteners from the start.
The shimano screws in particular seem very soft. A good "bit" fits correctly and will not slip and round out the screw head.
Mark Petry
Bainbridge Island, WA
Mark Petry
Really Old Senior Member
A genuine JIS screwdriver fits much better-
https://www.parktool.com/product/der...ewdriver-dsd-2
Quoted: 1438 Post(s)
Liked 1,092 Times
Shimano screws are likely JIS drive, not Phillips. JIS drivers will probably fit the recesses properly. Having said that I prefer socket drive over Phillips. M4 x 12 should fit OK, if not it would be easy to grind off the slight extra length.
https://en.wikipedia.org/wiki/List_o...rives#Phillips
https://en.wikipedia.org/wiki/List_o...ves#JIS_B_1012
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
I personally would just run down to my Ace or Tru Value hardware store with one of them and match it up with a SS socket head they have for like $1
Likes For dedhed:
Bikes: 3 road steelys, 3 alu, 1 mtb, 1cx
Quoted: 20 Post(s)
Liked 22 Times
Try using a 2.5 or 3mm hex wrench in the existing bolts on your brake adjuster bolts.
Some of the dura ace brakes used a combination JIS and hex bolt. Assuming the bolt
is not seized in place, it should turn with a hex wrench.
I think these will work, although I'd rather have a socket head as long as the screw was stainless steel. I just bought the 2-pack which cost me $1.25.
https://www.homedepot.com/p/M4-0-7-x...1058/204225839
Neither the front nor the rear bolt is seized but no hex driver works.
Quoted: 4210 Post(s)
Liked 3,875 Times
On the vast majority of the dual pivot calipers I see I don't touch these "centering" screws at all, unless the caliper is already set up really off center. Then I generally just set the screw so that the two sides/arms/pads are symmetrical. To center the caliper/pads I just turn the caliper backing plate (and the mounting bolt) on the frame. Andy
AndrewRStewart
AndrewRStewart
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Hex Head cap Screws Metric
Or this Metric set screw with internal hex
Set Screw Metric M4
Quoted: 2026 Post(s)
Liked 1,096 Times
