2 speed hubs, kickback?
Quoted: 137 Post(s)
Liked 51 Times
hi folks. reading thru lots of posts on various topics i' keep seeing mentions of something called a two speed kickback?. so. just wondering what this is.? a hub? and how does it work? how would this translate in gear inches or however one measures resistance, and lastly. can one be put on a folding bike. thanks for any help. lots of interesting topics on here, lots of knowledgable folks too.
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
I recall a couple kickback versions one with a yellow stripe and another in blue.
Different gear ratios and a nice idea for a coaster brake cruiser.
Nowadays, Shimano's Nexus 8-speed hub runs circles around the old kickbacks.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
https://www.sturmey-archer.com/en/products/2-speed
All the ones listed in the link are coaster brake.
I have one that is rim brake. No coaster guts. No reaction arm. Not sure what other difference there may be. They come set up for 120mm over locknut dimension. But, with a proper 13/32 nut on each side of the axle can be made to fit a 130mm width drop outs.
You'd probably want to run a 36-ish tooth chainring & cruise in the "overdrive." Then kickback to direct drive for hills.
They work ok. Mine leaks oil. It's not really a big deal.
Car dependency is a tax.
Industry guy
The 2 speed kickback is a development of the 2 speed manual hub designed and build by Bendix.
The manual version used a knuckle and lever(similar to Shimano 3 speed set up) to change the gear ratio.
The automatic(kickback) version allowed the change of gear ratio by simply backpedaling slightly, not enough to engage the coaster brake , and
then continuing to pedal as normal.
The secret of the system is a spring- a thin, flat steel one with tiny tines bent at the ends, which allow the hub to engage in both gears.
Simple in theory, but a bit tricky to overhaul. The spring has to be oriented correctly, and the grease used to lubricate the hub seeds to work
where needed, but not impinge on the action of the spring.
The hub came in three ratios- red band, blue band and yellow band.
Middleweights and Stingrays came stock with the automatics for a time.
Balloon models primarily came with the lever activated version.
AB-26 is the "magic spring"
rusty
rusty
Likes For 100bikes:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
And the gals flip for a Bendix "Automatic!"
Likes For JohnDThompson:
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
Merry Sales has returned the Bendix 2-speed kickback to production as the Eagle.
Yep. And has been.
Lastly, can one be put on a folding bike?
Yep. And has been.
Palmer
Liked 1,825 Times
In addition to the 'kickback shift', there's also automatic shift two speed hubs.
Fichtel&Sachs was famous for theirs, and this went on to be manufactured under the SRAM banner until 2017. Sturmey-Archer (since 1902) makes their A2 hub in freewheel and coaster versions in both a lower rpm shift version (26" & 700C wheels) and a higher rpm shift version (16" & 20" wheels) with various spoke hole counts*.
*I've yet to see an internet retailer make clear which version they're offering!!!
Growing up, a friend rode a bike with the triple red band bendix 2 speed, neither of us actually mastered the skill necessary to consistently shift it.
I love the
"Apply brake safely, with your foot.....The American Way"
Well, it was 1955.
Well, it was 1955.
