Smaller Singlespeed Suggestions?
I have to give a shout-out to Wabi and to my LBS: I really wanted a 42cm Wabi and my LBS told me there was no way I could find a 650c tire that could handle the goatheads around here, and Wabi told me that the 49cm (which could take Schwalbe Marathons, and thus handle my roads) was definitely too tall and probably too long for me. I'm grateful to both of them for being honest with me and not letting me buy the bike I wanted when it was the wrong size for me.
My LBS is keeping an eye out for a used bike my size, and knows that I want a lightweight singlespeed, ideally under $1,300 or so, but nothing has come up yet. In the meantime, since I'm sad about the Wabi and feel the need to browse specs online: anything I should be looking at? LBS suggested that I check out the All City Nature Boy and I've heard good things about the Soma Rush. Any other great frames/completes that are 49cm or smaller that I could talk to my LBS about or search for on Craigslist?
I'm still bummed out about the Wabi (it was so perfect until I saw the geometry) so feel free to commiserate about the bikes that haven't fit you, as well.
Quoted: 12 Post(s)
I had a similar experience.
Wabi told me the 42cm probably wouldn't work for me, what I really needed was something in between 42 and 49, and that the rack situation (I need a basket(s) for loads or 20lb or more) also probably wouldn't work. One LBS was adamantly against 650B, another LBS said they were viable but would be special order.
I am not sure why Wabi chose to accommodate riders three or more standard deviations below the mean but not two (surely there are more of us, actually I am 1.8 standard deviations below the mean for a man in the USA) but that helped me to rule them out. Shame. You would think with limited production runs they could fix this but I am guessing that there are design difficulties when using 700C tires with a 45-46 cm frame that they didn't want to deal with.
I, too, got a rec for All City but I don't want to spend that much.
The previous model State 4130 single speeds had 46cm and 49cm, which are a lot smaller than the current (2022 and post-) production run. The frame isn't as high quality as what you would like but other parts can be upgraded as necessary. You can find both new and old geometry charts at the State website.
Quoted: 12 Post(s)
He was a Specialized dealer. I am guessing that he doesn't carry them in his store. But he was also opposed to a 42 cm bike for me. He said it would be more suitable for someone 4'10" and that the best fit for me would be a State 4130--that he had one and it was nice. I think it will be fine with better wheels and tires.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
2011 42cm Wabi Lightning with 650c wheels
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Likes For TejanoTrackie:
Quoted: 12 Post(s)
Pretty much. Cinelli Gazetta and Kilo TT were also on my short list but the former does not get good reviews and the latter is from a vendor I've been advised against. My saga is in the "740 mm standover" thread.
Do you have any suggestions for upgraded light but affordable wheels and tires?
I think the OP's problem was that there are no 650c tires that can handle goat head thorns. I have an old MTB with 26" wheels and use a Mr. Tuffy strip under the tread which can handle goat heads, roofing nails and just about anything else. I'm also 5'-2" and own a Wabi that fits me fine with a 100mm flipped up stem and bullhorns.
Veteran Racer
Liked 765 Times
Yes, but it is an aluminum frame rather than the steel used on the current lightning. It is extremely light, only 14.6 lbs minus the seat bag and water bottle.
Quoted: 12 Post(s)
I'd like to spend less than $300 (preferrably less than $200). Wheels that come with the bike are 700C 14mm and can take a max tire width of 28mm.
I am not sure what I need for brake clearance (dual pivot, clamp diameter 23.8 mm front and rear).
Veteran Racer
Liked 765 Times
https://wabicycles.com/products/wabi...speed-wheelset
Steel is Real
Bikes: Wabi Lightning, Wabi Special, Wabi Thunder, Merckx Extra Corsa, Colnago Tecnos, Colnago Super, Cinelli Supercorsa, De Rosa Professional, De Rosa Replica 73, Serotta Colorado iii, Koga Miyata Full Pro, Panasonic RT-3500, Lynskey R320, Time VXRS
Quoted: 22 Post(s)
Liked 21 Times
Veteran Racer
Liked 765 Times
Unfortunately, the geometry doesn’t allow a 700c option smaller than 49cm. The main triangle can’t go any smaller. The only option would be a larger 650C frame, but it is hard to justify another frame size to accommodate the limited percentage of people that fall between the 42cm and 49cm. Plus, the 42cm can work with the right stem setup. Honestly, we were going to discontinue the 42cm (so as to not have to manage the 650Cs and relatively low sales), but we had enough customers ask/beg us for it given no other options out there.
Steel is Real
Quoted: 22 Post(s)
Liked 21 Times
Well, you could offer a smaller 700c wheel model if you were willing to adopt a shortened sloping top tube design and reduce the head tube angle while increasing the fork offset to avoid toe overlap with the front wheel. There are many successful examples of this approach on the market today. As to your comment that the 650c (42cm) model can be made to work with a longer stem, that is true up to a point since handling is adversely affected if the bars are placed too far ahead of the front wheel. Anyway, I did order a 650c Classic from you, realizing that this may be the last 650c bike I'll ever be able to purchase. Out of curiosity, how many orders have you received so far for the 42cm (650c) model ?
We got a handful of orders. I don't quote exact numbers, but the 42cm comprises less than 5% of our Classic orders historically.
Thanks for your order too.
