Campagnolo Victory Crank Removal
I picked-up a 1985 Trek 760 with Campagnolo Victory cranks. I'm toying with the idea of removing the cranks to check-out the bottom bracket. It has the Campy self extracting crank system, so it looks like I would need a left hand threaded" 22mm crank extractor. I have not figured out what the thread pitch is and I'm wondering if anyone knows what it is. Any info will be appreciated.
Quoted: 4585 Post(s)
Liked 1,740 Times
Why not just use the crank extractor that is built in?
Search "c-record crank extractor" on ebay. About $50.
Quoted: 4236 Post(s)
Liked 3,963 Times
My Sutherland's Manual says it's 22x1mpt LH. I thought I still had mine but it likely got sold off when my shop closed. If you can't find one or make one let me know and I'll see if Full Moon might have one from Pedaler's old tools we ended up with. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
I will check that on ebay, thanks Kontact. The reasons I'm hesitant about using the self-extractor thing are the horror stories about messing up the cranks with that system. I have stripped some beautiful old cranks and don't want a repeat.
Liked 1,740 Times
I've also used the regular kind with normal thread and have never had a problem. The fact that these tighten as you remove the bolt should only decrease the risk. It really isn't that different than using a dedicated extractor, IMO.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3936 Post(s)
Liked 6,619 Times
Quoted: 409 Post(s)
Liked 433 Times
The only thing I'd worry about with a Victory / Triomphe crankset is chainrings... weird BCD that nobody but Campy ever made rings for. 116 mm, minimum ring was a 36T, I think. Too bad, really, I always thought they were neat.
--Shannon
--Shannon
Likes For ShannonM:
Liked 1,740 Times
There's a fair number of compatible chainrings on ebay for cheap.
señor miembro
Liked 6,619 Times
This summer, I bought a beautiful Triomphe crankset on eBay with a very rare 40t ring (and 52t) for less than $60 shipped, so deals are out there.
Look for a Miche Young crankset online. Made for junior-sized racers in shorter arm lengths. They came with 36/46 rings in a 116 BCD.
The smallest ring with this BCD is 35; I know, I'm looking at a stack of them. Don't ask.
When removing a Victory or early C-Record crankarm DO NOT (ever) remove the self-extracting bolt with the 2 pin holes. BTW: it is left-hand threaded. To remove the crankarm, use a good 7mm hex bit socket on a 3/8" ratchet.
Likes For Dave Mayer:
señor miembro
Liked 6,619 Times
Liked 1,740 Times
So don't remove the self extractor, or remove it some other way?
Liked 1,740 Times
Clark W. Griswold
Quoted: 4496 Post(s)
Liked 4,178 Times
Yes but keep in mind that BCD (116) was used really mostly for youth bikes beyond the short lived Triomphe and Victory stuff , so people have had issues with bending chainrings. There are a few vintage Campagnolo chainrings out there but a lot of what you might see is vintage youth chainrings. I did the research years ago as I got the crank for basically nothing on a bike I bought for the 600 Tri Color (yes it was a weird bike).
Liked 1,740 Times
señor miembro
Liked 6,619 Times
Likes For gearbasher:
The only reason why someone would remove the extractor bolts is for one of the following:
- Some ham-fisted mechanic used a 6mm hex key and mangled the 7mm interface. I've seen a lot of this. Yes, 7mm is a size; it does exist.
- An Ebay doofus removed the extractors from a Victory or C-Record crankarm in a pathetic attempt to get a higher price for the crankarms and extractors separately. Of course, when an unsuspecting user attempts to remove the crankarms using a standard right-handed extractor, and cross-threads and then strips the alu threads, they'll be P.O.'d.
But again, these bolts should stay fitted to the crankarms for their life.
