Flat pedals for toe clips?
Quoted: 142 Post(s)
Liked 34 Times
Time to replace my 10 yo pedals that I was using with toe clips.
Any recommendations for modern decent quality pedals that can last?
Good quality flats I see on internet these days don't accept toe clips and those that can, come with a combination of a single cheap ball bearing and a plastic sleeve that holds the other side of the pedal axle.
Quoted: 5793 Post(s)
Liked 2,586 Times
Check out MKS pedals. They still have toe clip seed styles available, though you might have to settle for track style models.
If you search diligently you'll find lots of offerings, either used or NOS.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 1944 Post(s)
Liked 2,164 Times
Good quality cup/cone quill pedals can last a long time. But they are just like hubs in that they need to be maintained and properly adjusted.
The typical MKS road model is the Sylvan. Cup/cone pedals don’t need a “break-in” period. If they are not smooth, open them up, and make sure they are greased, and adjust them.
I can’t speak of the build quality of the new MKS pedals vs. the ones from the 80’s, but 10 years seems too short of a pedal life.
John
John
Likes For 70sSanO:
Half way there
Quoted: 987 Post(s)
Liked 880 Times
Here's one more endorsement for MKS pedals. Great quality at a nice price. Many styles to suit most needs.
Likes For Moe Zhoost:
Quoted: 142 Post(s)
Liked 34 Times
John
John
Quoted: 1438 Post(s)
Liked 1,092 Times
John
John
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
What pedals are you replacing?
I'd look at the MKS "Urban Platform" pedal. It's derived from the venerable Lyotard mod. 23 pedal, and has a wide tab for easy entry into the clip. My only objection to it is that it doesn't accommodate slotted cleats, but if you're not using cleats, that isn't an issue.
https://www.amazon.com/MKS-Urban-Pla.../dp/B007T3F1DM
Likes For JohnDThompson:
