Roadmaster Elite Front Brake Issue
Hello all.
I picked up a bike today at a garage sale for 5 bucks for my neighbor. I was going thru it and found that the front brake pads were at the end of their adjustment, but still were not aligned correctly with the rim.
The front hub is completely seated in the front fork. Both wheels are 26".
What is curious to me is that the front brake is a center-pull style, while the rear brake is a side-pull. Is it typical for a bike like this (early 1980's?) to have two different style brakes? If not, I suspect maybe someone might have replaced the front brake and has thus introduced this issue.
In any case, I am hoping you guys might be able to shed some light on this issue for me. Many thanks in advance.
Really Old Senior Member
I suspect it's an incorrect replacement.
Quoted: 6193 Post(s)
Liked 4,810 Times
On a bike that old, I just suspect that someone put parts on it that they had available to them. Whether it's correct for the bike really doesn't matter if it suits their needs. All that matters is whether they work good enough.
And whose to say that someone had a bunch of miscellaneous bike parts laying around and put them on a frame they also had and sold it at a garage sale. <grin>
Likes For Iride01:
Quoted: 2026 Post(s)
Liked 1,096 Times
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
If that pad rubs on the rubber of the tire you will have a blow out before you know it. Either the front brake is wrong, which is the likely culprit, or you could put a larger front wheel on it (27" or 700C) because it looks like there''s plenty of room for it and then the brake pads might reach. Or you can remove the pads before you damage the tire and just use the rear brake, depends on what kind of riding your neighbor does. This is where lots of extra parts lying around comes in handy. Good luck,
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Maybe its the wrong size wheel, big gap at top of fork in pic seems to match frame but that is another possibility of it being changed..... where are you at? (location)
Likes For JoeTBM:
Thanks for the replies everyone. You confirmed my suspicions. My plan is to scrounge up a different brake for the front and hopefully get it to work.
Yeah there is no pressure here. We have 5 bucks invested in the bike.
>> can you cut the slot in the fork 3/8 of an inch deeper to make the brake pads line up?
You read my mind! I thought of that and may give this a try actually.
I am in Wisconsin.
I am in Wisconsin.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Aican and bdop make drop pad holders, but honestly that bike isn't worth the expense. Best to junk pick or head to the coop for a used caliper with longer reach.
https://www.ebay.com/itm/12468418681...UAAOxyhSBR-wqg
Likes For dedhed:
Liked 4,810 Times
Are the front and back wheels the same diameter? I mean this isn't something made for 27" wheels and someone put a 700C wheel on the front or similar is it?
I wouldn't slot the hole in the fork, but I might make a plate to drop the hole some.
https://www.sheldonbrown.com/home-drop.html
I might have stumbled onto a possible remedy. I went to remove the pads with the idea of possibly elongating the slot in the caliper so I could move the pads further. When I loosened the nut, the pads naturally settled into a position where they would contact the rim correctly.
So now I'm thinking maybe of using a beveled washer on the stud? Something like this:
Thoughts?
Thoughts?
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Will the calipers spread enough to allow them between the pad and the arm? If so, it's a cheap fix.
Quoted: 1074 Post(s)
Liked 295 Times
Thoughts?
Thoughts?
brake looks to be steel. Why not simply bend the lower half of the slot?
Likes For dabac:
It crossed my mind to bend it, but was afraid it might break. But now that I think about it, it should be strong enough to take it. I could gently heat it.
Maybe I will try bending. If it works, this would be the simplest fix.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Look at a set of brake shoes for V-brakes. They come with conical washers, one set thin, one thick, for angular adjustment. The calipers may not spread enough to fit them in, but I'd try it with the thin set inboard. If you have another bike with V-brakes, temporarily strip them off it to try it out.
I wouldn't mess around too much with modifying the front brake. When properly adjusted, it's supposed to do most of the work. You don't want your $5 investment leading to major trauma. Sheldon's site says he's never done the drop bolt for a customer, only for himself, and the example shown is a rear brake.
I did this, and it worked great!! I may bevel the pads now to make fuller contact with the rim, but even as it is the front brake feels fine.
Thanks for the idea!
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Just keep an eye on the wear as they will slowly creep closer to the rubber as they wear down. If it stops you as is, I wouldn't bevel them. But if you need more stopping power up front, beveling might help. Good luck
Likes For Bigbus:
Likes For scoostraw:
