Wheel Dish for Wider Tires?
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
My trusty 700X35mm Clement USH tires are on their last legs so I tried mounting some 42mm Spec Pathfinders on my Norco Search. The Pathfinders seem to fit on the front but are rubbing on the non-drive side chainstay. There appears to be +/-3mm of room between the tire and drive side chainstay. Is it possible to have the rear wheel dished 1-2mm so the tire would fit or am I SOL?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Is the wheel properly dished now? The Norco site says that the Search S1 comes stock with WTB Resolute 42s, so they should fit.
Quoted: 4806 Post(s)
Liked 3,931 Times
Before you do anything else, remove the rear wheel, flip it around and put it back on (so the axle seats exactly like it did before). Now look at the tire and chainstay. Same issue; 3mm on the NDS? The problem is in the frame, not the wheel. If the 3mm is now to the DS, then, yes, the dish is off and should be corrected (either with spoke dish or moving axle washers).
Correcting frame issues with dish is simply adding funk. Good in many types of music, but not on a bike (although it has been gone many times).
Likes For 79pmooney:
bOsscO
Quoted: 296 Post(s)
Liked 355 Times
Thanks all! Some answers and clarifications;
- No i'm not sure if the wheel is dished correctly now. I can pop it into my LBS to confirm but will try your wheel trick 79pmooney.
- My Norco S1 is from 2015 and came stock with some Kenda 700X28mm file treads, not the 42mm Resolutes (don't think they even made Resolutes in 2015).
- I sure hope it's not a frame problem in the rear triangle; maybe a trip to the LBS is the ticket.
Quoted: 581 Post(s)
Liked 921 Times
Before you do anything else, remove the rear wheel, flip it around and put it back on (so the axle seats exactly like it did before). Now look at the tire and chainstay. Same issue; 3mm on the NDS? The problem is in the frame, not the wheel. If the 3mm is now to the DS, then, yes, the dish is off and should be corrected .
Guest
Liked 3,270 Times
Ah. If a bike comes stock with 28s, I'd wager that 42s are going to be really pushing it. Even after you get the rear wheel to sit straight in the frame, you're still only going to have 1.5mm between the tire and the chainstays. Better keep that wheel true!
Quoted: 1461 Post(s)
Liked 1,486 Times
1.5mm on both sides is very tight. This might still rub even with a perfectly straight frame and properly dished wheel, just from frame and wheel flex under load.
79pmooney has good suggestions to check wheel dish vs frame alignment. I'd be curious to know what the results of this are.
Likes For msu2001la:
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
I use hex "L" wrenches to check clearances. a 4mm wrench is 4mm across the flat sides, for example.
