Change in Road Manners
I recently put new tires on my 65 Schwinn Racer. The new tires are correct for the old S5/S6 rims. The bike now wants to lean/turn right when hands free rolling. It didn't before the tire change. I've checked the tire's bead seating, wheel straightness, the axle seating in the forks, the seat alignment, and my riding posture. All is the same, as far as I can figure; except now I have to really lean my body to the left to keep the bike rolling straight when hands free. Please no comments on hands free riding. It is fun, helps with balance skill, and I only try it when there's no other traffic i.e. an empty road and just me. Just trying to figure what I might be missing.
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
Swap your tires front to rear.
Quoted: 2483 Post(s)
Liked 2,955 Times
Double-check that the axle is fully seated in both dropouts.
Likes For Trakhak:
Quoted: 7652 Post(s)
Liked 3,478 Times
Take the wheel off and install it with the current left side, on the right.
Likes For Maelochs:
It would work the same, yes. If the rear wheel isn't aligned with the bike, it will always want to go one way or the other. Obviously, this is much less critical with the front wheel.
Wheels can also be out of alignment, vertically. That would force the rider to lean slightly, to compensate. I'm not sure that that would make much difference, though.
Quoted: 913 Post(s)
Liked 515 Times
Okay. I checked the wheels front to back with a straight edge. Sure enough, one side of the front tire won't line up, the other side shows a 1/4" or so gap between the straight edge and front tire with the tool flat on the rear tire. (I used to do work like this for aligning industrial belt drives) Swapped the front tire 180* as per Maelochs. A test spin later and the bike rides normal again. Curious as to why this is. The front axle was seated in the forks, both axle ends nutted the same with 2 threads showing on each side. As far as I can tell it was centered. Could it be the way the wheel was built to run with the rear wheel on a 3 speed hub?
Quoted: 6195 Post(s)
Liked 4,810 Times
Before the tire change, how long has it been since you rode it hands free? If the bikes been sitting around and you finally drug it out of years of storage and had to put new tires on it in order to ride it then maybe the rider isn't as good as they once were. <grin>
Liked 4,810 Times
Also, are you sure it isn't a brake or shifter cable bend from bars to frame pulling or pushing it one way?
So, how come I'm limited to 5 posts per 24 hours? I haven't been onboard for a few years and I updated my email. I went to reply yesterday but the board says I can't because of my posting limits.
Liked 4,810 Times
Once you get past your tenth post I think they'll trust you. While you may not have run afoul of this on other websites, most that I use have the same policy.
Thanks for the info. Yes, I'm on other forums and spammers take their toll, this is the 1st I've read about bots in the mix. That and constants ads are interrupting my internet. I suppose all those seminar attendees for "market penetration" are now at work
