Using toolboxes for parts storage (and some cheap dividers)
feros ferio
Quoted: 1397 Post(s)
Liked 1,337 Times
Here’s my setup for the bits I need the most, sorta semi-controlled chaos:
Of note is that the unit on the left of the first pic and the red cabinets in the second all came from IKEA. The first is meant to be an organizer for a kid’s room, but the modular design is quite handy.
Quoted: 569 Post(s)
Liked 599 Times
After seeing these I am embarrassed to show the inside of my right sized shop:
I've got that same kids toy organizer from IKEA in my bike shed! But I've not got parts sufficiently organized for the drawer bins to slide into the slots yet.
Likes For tgot:
Edumacator
Quoted: 2492 Post(s)
Liked 3,225 Times
Metal and bearing drawers seems smart, I am working with what I already have. Nice wood flat files, smaller blonde sets and larger/darker 15 drawer pair.
Kept their original labels just to make things confusing
Cerussite Chalcanthite = Brake pads & hardware
I still have 15 + empty drawers in the big cabinets
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
Edumacator
Liked 3,225 Times
Though it is probably for the best I have less space!
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 73 Post(s)
Liked 337 Times
Likes For bikamper:
Quoted: 3818 Post(s)
Liked 6,752 Times
1991 PBP Anciens
Quoted: 73 Post(s)
Liked 337 Times
Nah. His garage is smaller than our attached garage, aka, her garage(where I'm not allowed). His 68 Camaro RS hasn't turned a wheel in two years. Both his and his kids dirt bikes are in there, along with a fridge and his wife's Volvo and workout gear.
Likes For bikamper:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 138 Post(s)
Liked 309 Times
Some of these collections are...impressive.
[Quietly bookmarks thread for showing spouse at an opportune tactical moment.]
Likes For Rick_D:
Quoted: 7360 Post(s)
Liked 2,503 Times
On a related topic, I'm long overdue for an organization effort like these.
I think I have settled on categories. The four main ones are:
- components (such as brake calipers, derailleurs)
- accessories (bells, toe straps, bottle cages)
- small bits (nuts, bolts, pieces of components such as derailleur pulleys)
- supplies (handlebar tape, inner tubes)
Got any others?
Got any others?
Edumacator
Liked 3,225 Times
I’m just impressed by the space folks have. Suburban plastic land living afforded me only a single car garage. Which is for the best because having more space would have mean more opportunity to avoid the sanity!
www.theheadbadge.com
Quoted: 2429 Post(s)
Liked 4,421 Times
Got any others?
Got any others?
If you frequently build or fix bikes, classify by consumables and frequently needed parts first: Consolidate your cables, M4, M5 and M6 hardware, brake pads, grips, and handlebar end plugs all in the same cabinet. Brake noodles too if V-brakes are common. This helps a lot.
The the silly little ARTGUY toolbox turned out to be perfectly suited for this when I had to rebuild seven bikes for an event this weekend (plus rip a Huffy apart for parts...a very satisfying 10 minutes - @AdventureManCO should know all about that). Once all the tools were out, most of the trips were to that toolbox or the Husky next to it with the 100-quantity cable rolls in it. I could grab multiple parts at once knowing they were coming up too.
-Kurt
Likes For cudak888:
1991 PBP Anciens
Quoted: 73 Post(s)
Liked 337 Times
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1256 Post(s)
Liked 3,613 Times
That is low, even for me. Unless they are to be used appropriately, like for the garbage, or a Paramount. You have Paramounts.
Jus sayin'
There were 135 Confentes, but only one...Huffente!
Liked 4,421 Times
I hurled that dual-suspension frameset into the scrap truck with glee. Fight me.
-Kurt
Likes For cudak888:
Quoted: 1616 Post(s)
Liked 2,221 Times
@easyupbug - I had a 1947 Dodge in college that I picked up for $50. Original paint with all the sub layers exposed to the metal in some spots. It too had a fluid drive which was just a fluid coupling between the flywheel and the clutch (3 speed).
It would go anywhere in the snow as you could not get the rear wheels to spin but could apply the needed traction. I was stopped once for potential equipment violation and asked to put it in gear ad let out the clutch with my foot on the brake.
The RPM dropped about 200 RPM but the engine kept running. It has "suicide" doors in the back as I believe yours has.
Found a good, IIRC, 352 Hemi from 1952 I was going to put in it but the steering box was in the way. Lots of stories associated with it. Sold it when I left college for $200. Should take a digital pic of it .
1991 PBP Anciens
Quoted: 73 Post(s)
Liked 337 Times
Here's where the slush box comes in. When coming to a stop, do not push in the clutch. Just before the car stops, the transmission drops into 3rd. When it's time to start moving again, floor the old broad and she starts out slowly, but stately, in 3rd. Let off the gas at about 20 mph, and the old girl will upshift to 4th and run 70 all day long, with Jeep Wrangler gas mileage.
The only time the clutch is used again is to manually downshift into the low range or reverse. There is a kickdown from 4th to 3rd for passing or steep hills. There will be much sound and fury coming from the old flathead six when the kickdown is activated, but it means little.
Her big behind.
In keeping with the thread, I believe there is a box in the trunk with several pairs of pedals in it.
The Huffmeister
Liked 3,613 Times
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,183 Times
Best, Ben
BTW, who has more Campy stuff?
Mad Honk
Voltaire
Voltaire
Likes For xiaoman1:
Edumacator
Liked 3,225 Times
Now we know where all of the parts have disappeared to........Nice collection!
Best, Ben
Mad Honk
Best, Ben
Mad Honk
Liked 4,421 Times
The toolbox really came in handy for that, and I'm getting a lot of ideas from what I'm seeing here - a big thank you to everyone for chiming in.
-Kurt
The Huffmeister
Liked 3,613 Times
The Huffy frame didn't hurt me. What broke me were the six other Huffy-level bikes that I had to fix over the weekend. That included two Wal-Mart Mongoose POSs which got V-brake studs brazed to their front forks. That's how little patience I have with garbage sidepulls these days.
-Kurt
-Kurt
Liked 4,421 Times
It was worth it. We needed every one of them.
I also bought our program a Cannondale 20" with faded neon paint in the process. I think it'd be fun to strip it down and polish it...
...and put a Huffy badge on it.
-Kurt
Likes For cudak888:
Quoted: 474 Post(s)
Liked 1,077 Times
But then, I have a friend whose garage and basement are even more, eh,”loved” and he then has three warehouse locations. I’m a neat freak by comparison.
