Show us your tandem!
Old 09-12-21, 01:58 PM
  #126
Hypno Toad
meh
Hypno Toad's Avatar
Quoted: 1111 Post(s)
Liked 1,013 Times in 519 Posts
Finally! The stars aligned and we got our new Co Motion Java out for a good ride!
Hypno Toad is offline
Old 09-13-21, 09:05 AM
  #127
mbliven
Bikes: Rodriguez travel tandem with Rohloff hub (2020), Rodriguez Phinney Ridge gravel bike (2021), Trek Al-carbon road bike (2015), Zebra Kenko retro road bike (~1981).
Quoted: 10 Post(s)
Liked 7 Times in 4 Posts
Lovely tandem - how did it handle on your ride? What size wheels and tires do you have there? Also, I have to ask - how did you decide on the festive color scheme?
mbliven is offline
Old 09-13-21, 09:41 AM
  #128
Hypno Toad
meh
Hypno Toad's Avatar
Thank you!
The Java handles like a dream! This captain is still working on tight turns, it's long and handles tight turns like the QE2, it's just a learning-curve (LOL).
It's running WTB Venture TCS 700c on CliffHanger 700c wheels; these tires will be great for our first big adventure: The Filthy 50 (weather permitting, the stoker is not stoked for the 'filthiest' 50 - the captain will ride a single if the weather is nasty)
The colors were the stoker pick, these are her favorite gemstones' colors, and we called this Java our 30th anniversary gift (much more fun than of a ring).
BTW - This is our first 'real' tandem, we have a '65 Schwinn Twinn that has never done a ride over 10 miles.
Likes For Hypno Toad:
Old 09-13-21, 12:27 PM
  #129
mbliven
Quoted: 10 Post(s)
Well, enjoy the Filthy 50. That looks like a pretty fun event, with the mix of gravel and pavement and the rolling hills. I hope you get cool overcast conditions, but no rain!
mbliven is offline
Likes For mbliven:
Old 09-15-21, 08:34 AM
  #130
jim_pridx
jim_pridx's Avatar
Bikes: 2010 Bob Brown Cycles tandem, 2019 Co-Mo Carrera tandem, 1980 Richardson tandem, 2014 Cervelo R3, 2018 Specialized Roubaix, 1985 Bianchi Campione, 1983 Trek 720, 2020 Trek Fuel EX8, 2021 Salsa Mukluk
Quoted: 72 Post(s)
Liked 116 Times in 70 Posts
Congrats on the Co-Motion! It's great to see you in the tandem forum, too!
BTW, I used to work in this building shortly after it was constructed:
jim_pridx is offline
Likes For jim_pridx:
Old 12-01-21, 01:55 PM
  #131
Chilepines
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times in 37 Posts
Our new tandem - Clementine. I'll be posting the build process which has been interesting. di2 in a steel frame poses some challenges.
Chilepines is offline
Old 12-01-21, 08:25 PM
  #132
ianbal
I would be interested to hear your experience with Curtlo as well as the build process. Good luck with the new bike.
ianbal is offline
Likes For ianbal:
Old 12-01-21, 10:40 PM
  #133
Russ Roth
Quoted: 1088 Post(s)
Liked 1,025 Times in 723 Posts
I've got an early to mid-80s Gitane I've never been able to nail down. Currently running truvative 9sp cranks, with french thread Phil BB in the back and a standard sram in the front, I had to turn down an english thread eccentric to do that but 20.00 vs 200 made it an easy decision. Shifting is Dura Ace bar ends running friction. And riding on Velocity tandem wheels.
My wife has been wanting to get more serious about gravel riding and doing some longer rides on it so it'll be undergoing some revisions again this year.
Plan are...
ditch the V-brakes for much nicer cantis, even with the travel agent the brakes suck
New seatposts, the old ones are really light weight and I suspect weak. I think they're 25.0 but they were so chewed up when I got it I could never get a good reading on them.
Sand down a threadless adapter so I can run a stronger handlebar with a threadless stem.
Ditch the simplex for a tiagra triple front and a deore rear der to run a wider range cassette.
We've already run it with some 700x40 tires, so I know we can go gravel with plenty of clearance, neither of us are real powerhouses so I suspect it'll be a very comfy ride that won't be too whippey with out power levels.
Russ Roth is offline
Old 12-10-21, 05:20 PM
  #134
justcynn
Bikes: Lots of Schwinns
Quoted: 109 Post(s)
Liked 250 Times in 114 Posts
new to us Schwinn Twinn. Bought from a guy that said he used it one time, looks new and lucky for us - its in a large size which apparently means 22" front and 18" rear C-T.
My wife and I ride together on our own bikes and since I ride quite a bit more than she does, its harder to stay together. for an Entry Level the Twinn gets pretty good reviews on Amazon, but the bottom bracket is low with the 26" stock wheelset causing some pedal strike. I happen to have a 700 Wheelset set up for Disc Brakes that I may try to swap in to solve this issue and considering junking the cheap suspension fork for a rigid aluminum, carbon or chromoly. our intended use is rail trails, possibly the Katy Trail, the Mickelson this summer and some local off road trails. I spend quite a bit of time on my vintage Steel bikes so this will be new and different.
Question: is it set up like a fixie where both have to pedal all the time, or can one person freewheel while the other pedals? Looking forward to reading this forum to learn more about this before we do our maiden voyage
justcynn is offline
Likes For justcynn:
Old 12-11-21, 07:47 AM
  #135
Chilepines
Quoted: 67 Post(s)
There is a timing chain so both will have to pedal at the same time.
I very much doubt you can put 700c wheels on that bike - there will not be enough clearance at the fork, or probably rear triangle either.
Sounds like you re new to tandems, so I'd suggest giving it a try as is before putting any energy into modifying it - you really won't know what does and doesn't work for you until you give it a try!
Old 12-13-21, 07:59 AM
  #136
JerrySTL
JerrySTL's Avatar
Bikes: Giant Defy Advanced, Breezer Doppler Team, Schwinn Twinn Tandem, Windsor Tourist, 1954 JC Higgens
Quoted: 36 Post(s)
Liked 10 Times in 8 Posts
I have the same bike. My wife and I have done the entire Katy Trail, Great Allegany Passage, and most of the C&O trail on it. I have heavily modified the bike as things have broken or worn out.
One of the first things was getting rid of the suspension fork. That alone went a long way to stop the pedal striking the ground. This fork works well: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The cheap seats and pedals went next. My wife uses the old school pedal straps to keep her feet from slipping off the pedals when I shift gears. Yes you both have to pedal at the same time.
The stock wheels lasted only about 2000 miles. Replacing them was somewhat difficult as the rear used a 7-speed freewheel - not a cassette. It's very difficult to find a wheel with a freewheel AND disc brake. You can get an 8-speed cassette wheel and put on a 7-speed cassette with an adapter ring. We did that for a while. However the granny gear wasn't quite low enough for some hills.
Therefore I switch the tandem over to an 8-speed with an 11-34T cassette. To do this you need a rear wheel that can take an 8-speed cassette, an 8-speed rear derailleur, and an 8-speed shifter. It was a great upgrade.
Tip: If you plan on doing any touring, carry a tandem rear derailleur cable and a rear brake cable. They are about 3000-35000 mm long. Many bike shops don't carry them and you'll really be out of luck if one breaks. Plus you can cut the cables shorter if something on the front snaps.
There's much, much more that I can tell you about the bike. PM me or send me an email at whittle at charter.net if you want more information.
JerrySTL is offline
Old 12-14-21, 06:46 PM
  #137
justcynn
Quoted: 109 Post(s)
[QUOTE=JerrySTL;22338365]I have the same bike. My wife and I have done the entire Katy Trail, Great Allegany Passage, and most of the C&O trail on it. I have heavily modified the bike as things have broken or worn out.
There's much, much more that I can tell you about the bike. PM me or send me an email at whittle at charter.net if you want more information.[/
thank you for the great info, this is very helpful!
justcynn is offline
Old 12-23-21, 09:38 PM
  #138
GhenghisKahn
OwainGyndwr
GhenghisKahn's Avatar
Bikes: 90 Fisher 3x7 hardtail, 2016 Reid 1x7 commuter, 2017 Viva 46x18 fixed gear, 93 2x8 Avanti Kona
Quoted: 34 Post(s)
Liked 67 Times in 43 Posts
This our Silverback Duel Limited Edition(whatever THAT means lol)3x9 sport tandem. It has Ultegra rr der, Sora frt and Altus shifters and levers. Tektro calipers, cf fork. The gearing is 30-42-52x12-32. Alex dw set. 40h rr, 36h frt. Conti Gatorskin 700x23mm. Saddles are no name that we'll upgrade at some point. The ride is solid, steady and predictable.. We're using platforms while gaining experience. We'll upgrade to dual-sided spds when we're ready. Shifting is smooth and accurate. Would like to move to mechanical disc at some point, but the rim brakes are fine for now. Money well spent to get us started. We thought about touring with it, but it has limits that makes it not suitable for a lengthy tour. All in all a very nice bike. 👍
GhenghisKahn is offline
Likes For GhenghisKahn:
Old 01-11-22, 06:01 PM
  #139
galyons
the dream shall never die
galyons's Avatar
Bikes: Cannondale RT3000 Tandem Cannondale R900 CAAD 8 Campy
Quoted: 8 Post(s)
Liked 17 Times in 8 Posts
New to us and newly refurbished. 2002 Cannondale RT3000. Ultegra groupo with Deore XT RD and V-brakes. Has a rear drum brake. New chains, FD shift cable and housing, seats, handlebar wrap, brake shoes and lots'a cleaning and adjusting. Ready to ride. The wife is not a cyclist, so let the journey begin! Hopefully joy to follow!
galyons is offline
Likes For galyons:
Old 01-15-22, 03:55 PM
  #140
Hproduguidon
Quoted: 48 Post(s)
Liked 372 Times in 127 Posts
ma trouvaille du jour
gitane
1970
Hproduguidon is offline
Likes For Hproduguidon:
Old 01-15-22, 10:31 PM
  #141
antmaster5000
Bikes: BMC TeamMachine, Surly Pacer, All City Big Block
Quoted: 92 Post(s)
Liked 62 Times in 30 Posts
Love these sunny winter days
antmaster5000 is offline
Likes For antmaster5000:
Old 01-15-22, 11:30 PM
  #142
7up
7up's Avatar
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times in 18 Posts
This is my Schwinn Mini-Twinn
7up is offline
Old 01-17-22, 01:23 AM
  #143
2flit
2Flit
Location: Orcas Washington and currently Circumnavigating in a Farrier F36 Trimaran
Bikes: 1968 Rene Herse Gentleman's Bike; 1974/5 Jim Merz Custom-built; 1984 Rodriquez tandem; 2012 Bilenky Tandem; 1967 Cinelli SC; 1984 Specialized Exp. 68cm; 1971 Holdsworth 63cm(my first bike ever and owned since new!); 1994 Bridgestone MB5; 86'Trek420
Quoted: 38 Post(s)
Liked 170 Times in 35 Posts
This is our Bilenky Travel Tandem that we cycled across the south island of New Zealand on and across Europe... and a few other places.
A good side view of the S&S coupled tandem
Canal de Midi France
The start of the Molseworth, New Zealand
A pilgrimage to our bag maker
Somewhere in Tours
Front Wheel Bistro
The Tandem packs into two airline bags This is the first....
... and this is the second bag
2flit is offline
Old 01-17-22, 04:36 PM
  #144
Wheels4
Wheels4's Avatar
Bikes: Cannondale, Trek, Cervelo and Santana
Liked 39 Times in 14 Posts
This is our Santana. I actually posted about it under a different screenname, but have since started using my original account on here. Anyways... I bought it about 4-5 months ago and the plan was to get back into cycling and help my wife get back into shape while recovering from Breast cancer treatment. So far, we have been on a couple of rides and she is doing really great! We are both enjoying it.
Bikes: C'dale, Trek, Cervelo and Santana
Wheels4 is offline
Old 01-21-22, 12:48 PM
  #145
motochick
motochick's Avatar
Bikes: '80 Medici Tourismo, '82 Merckx, '85 Peugeot PSN10, '86 Ironman, '89 Trek 520, '96 Steelman, '96 Torelli CX, '97 Friday Two'sDay, '02 CoMo Speedster, '09 Giant Reign, '10 Canfield, '13 Turner DHR, '16 Chase BMX
Quoted: 40 Post(s)
Liked 256 Times in 51 Posts
Here is our new-to-us, highly modified from original, 2002 Co-Motion Speedster. And yes, we are highly allergic to black bike parts, hoping to get some red pedals for the front soon!
Gotta love those pedals
motochick is offline
Likes For motochick:
Old 01-23-22, 07:09 PM
  #146
mbliven
Quoted: 10 Post(s)
Can you explain the purpose of the stoker's bar end levers? One for the rear rim brake, perhaps? What does the other one control? I've never seen a set up like that.
mbliven is offline
Old 01-23-22, 07:18 PM
  #147
fooferdoggie
Quoted: 680 Post(s)
Liked 949 Times in 556 Posts
the price of this pedals jumped a lot in the last couple of months.
fooferdoggie is offline
Old 01-23-22, 10:21 PM
  #148
Wheels4
Wheels4's Avatar
I thought I read, in another thread, that they moved the shifting duties to the stoker. I believe they used a custom attachment(where the water bottle cage mounts) for cables to make it work. I thought it was pretty cool, myself.
Wheels4 is offline
Likes For Wheels4:
Old 01-25-22, 05:36 PM
  #149
motochick
motochick's Avatar
Quoted: 40 Post(s)
This was my husbands idea/doing. I am the stoker and I do the shifting via Campy bar end shifters. There were no cable stops where we needed them for this to work so we made some. It works super awesome, I doubt we will ever go back to the captain shifting unless I lose the ability to do so physically.
Really? I haven't bought new ones in a while, we have 7 sets or so but I need to get some more as our bike hoarding has gotten worse! LOL. Even having to pay more is worth it for the ability to pedal correctly.
Old 01-26-22, 11:15 AM
  #150
antmaster5000
Quoted: 92 Post(s)
Very interesting idea having the stoker shift. Does the captain need to communicate for certain shifting situations that you might not be able to see? You would have a lot less cable distance with the stoker shifting which would improve shifting quality a lot. As the captain of our rig I definitely like shifting (and my stoker would not be interested in taking over these responsibilities) but I applaud you for going against the grain here!
