Upgrading to 11 speed cassette setup 11-51
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
I'd like to upgrade my 11-speed Shimano m8000 xt 11-46T cassette to an 11-51. I see shimano makes a Deore CS M5100 11-51. Link below. Is that swap just a matter of swapping the cassette and adding a couple extra chain links or entirely new 11-speed chain?
I have a Shimano single front ring. XT-SM-CRM80. 30 tooth.
Alternatively, can I swap my 46 cassette cog for a 51 tooth cassette cog?
Shimano 11-speed cassette
Quoted: 254 Post(s)
Liked 182 Times
Both of the M8000 rear derailleur options indicate a max cog of 46, and the medium cage version only has a total capacity of 39. Usually those specs are a bit conservative, but you may have trouble getting a 51 cog to work well, especially if you have the medium cage rather than the long cage M8000 derailleur. If it doesn't work, you can swap in the M5100 Deore rear derailleur, which is designed for the 11-51 cassette.
Likes For AeroGut:
Quoted: 73 Post(s)
Liked 24 Times
Thanks AeroGut. I have the Shimano XT M8000 Shadow+ 11 Speed Rear Derailleur according to a receipt I dug up.
Edit ** How can I measure the derailleur to determine if it is a medium or long cage? ** I think shimano has a code for the cage length:
SS = short cage
GS = medium cage
SGS = long cage
Back on the trails after a 5 year absence and everyone is powering up the climbs with sram 52's or shimano 51's.
SS = short cage
GS = medium cage
SGS = long cage
Likes For AeroGut:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
The XT M8000 RD won't take a 51t cog, regardless of the cage length. There are aftermarket gizmos like the Wolftooth Goatlink that might work.
You will likely need to either switch to the Deore M5100 RD mentioned above, or you can also use a Shimano 12 speed RD, as those are designed to handle that size cog and have the same pull ratios as the 11 sp RDs.
I am using a 12 speed XT RD with an XT 11 SP shifter and an 11sp 11-51t Sunrace Cassette on a standard HD freehub (which is what I assume you have).
Likes For Kapusta:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
This is on your Canfield? Definitely don't half ass it. That's the kind of bike that works this stuff the hardest. It needs any leeway built into the design to handle the chain growth when the suspension moves. If it were a hard tail someone might tell you ehhhh, maybe and you could try it and maybe it would be ok.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Disco Infiltrator
Liked 2,105 Times
Quoted: 73 Post(s)
Liked 24 Times
My 11 speed RD is a medium cage.
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Quoted: 73 Post(s)
Liked 24 Times
Quoted: 73 Post(s)
Liked 24 Times
Confirmed with "Stans No Hubs" that my hub is a standard Hyperglide (HG) hub that will take a Deore m5100 cassette. Looking forward to pedaling that 51 tooth gear uphill.
Thanks for the help guys.
Likes For lyle.coop:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
What kind of stuff are you climbing where and 11-46 with a 30t chain ring isn't adequate?
Advanced Slacker
Liked 2,537 Times
Quoted: 2975 Post(s)
Liked 1,182 Times
10-50 and 28t chainring on my full suspension mountain bike and fat bike. 11-46 and 28t on my hard tail and I wish I had lower gears on it at times.
