Post Your Titaniums
Post Your Titaniums
Old 02-13-22, 01:57 PM
  #3101
rekmeyata
rekmeyata's Avatar
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times in 204 Posts
Originally Posted by tomato coupe
The number of parts is irrelevant. There are many examples of industry innovators that are no longer on the cutting edge of product development. It's pretty common for competitors to adopt those innovations and improve upon them, and then add innovations of their own.
Again, you are off base, the cold working technique that Lynskey created and patented is a technique that is still being used today by all TI builders, with no innovations done to it since it can't be improved upon.
The expensive builders say they have innovations but when you look those innovations it's just word games, like Seven says they have customization, ok, all that is about is to build a bike based on your fit needs, not much innovation there that custom steel builders haven't been doing! Then they mention the 7-process methodology, under big bang wiz wording that means nothing in concern as to how a Ti frame is built, all it is is individualization and quality assurance...big deal.
Sturdy cycles says they produce parts using cold metal fusion, nothing new there either, it's what Lynskey created, except Sturdy used a 3D printing process now for certain TI parts, the same thing that Moots does. Some Ti builders will brag about their length of time building TI frames, one said as much as 10 years! WOW!! 10 full years!!!...oh wait, I'm getting too excited about 10 years, Lynskey has 36 years' experience with the cold process, dwarfing all others.
So, ALL these other TI builders have not done anything to innovate the process that Lynskey patented.
Titanium has a reduced carbon footprint compared to carbon fiber, can be recycled at the end of its life, and titanium doesn't corrode.
rekmeyata is offline
Likes For rekmeyata:
Old 02-13-22, 03:07 PM
  #3102
tomato coupe
Quoted: 3952 Post(s)
Liked 7,297 Times in 2,947 Posts
Originally Posted by rekmeyata
Again, you are off base, the cold working technique that Lynskey created and patented is a technique that is still being used today by all TI builders, with no innovations done to it since it can't be improved upon..
You can give Lynskey a ribbon for pioneering the technique, but it doesn't give them any advantage in today's market if everyone else uses it.
tomato coupe is offline
Old 02-13-22, 05:19 PM
  #3103
rekmeyata
rekmeyata's Avatar
YES IT DOES, it gives them 36 years of experience using the technique. I guess from what you're saying is that you would rather go see a first time heart surgeon, and you're going to be his first heart surgery, since he or she is using the same technique that a heart surgeon who has done 100's using the "same" technique, so what's the difference? Yeah, that's what I thought.
Old 02-13-22, 05:31 PM
  #3104
tomato coupe
The other bike manufacturers aren't building their first Ti frame, like your hypothetical rookie heart surgeon.
Likes For tomato coupe:
Old 02-13-22, 06:24 PM
  #3105
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10425 Post(s)
Liked 11,898 Times in 6,094 Posts
The thing about your analogy is that while the novice may not initially be as skilled as the guy who's done it hundreds of times, he's also not limited by having done it hundreds of times. My old boss, back before he lost his marbles, used to change his area of focus every couple years, because mostly, groupthink and conventional wisdom take over, and you need to look at it from the outside, the way someone new to the field does. After a few years, you lose that fresh perspective and end up thinking just like everyone else.
Now, there are, of course, people who continue working in one field and manage to keep innovating. But there are a lot more who fall into groupthink and conventional wisdom.
genejockey is offline
Old 02-13-22, 08:42 PM
  #3106
rekmeyata
rekmeyata's Avatar
Actually, it does because I was being as stupid as Gene Jockey analogy was.
Old 02-13-22, 09:11 PM
  #3107
genejockey
genejockey's Avatar
Withdrawn.
Old 02-14-22, 01:22 PM
  #3108
xseal
xseal's Avatar
Quoted: 34 Post(s)
Liked 46 Times in 25 Posts
Can't speak to analogies, and I'm biased, but when you see how Moots hand makes their frames from domestically sourced Ti, double welding each joint, you can't help but feel confident in a "life time" frame. Cool people too. I love these small manufacturers. I agree its a matter of $$, but if that is less important, great to buy from folks like Moots (next bike will be an Argonaut, carbon).
xseal is offline
Old 02-14-22, 07:57 PM
  #3109
rekmeyata
rekmeyata's Avatar
Originally Posted by genejockey
Not half as stupid as the heart surgeon analogy.
Whatever you say, jockey boy.
Old 02-14-22, 08:20 PM
  #3110
rekmeyata
rekmeyata's Avatar
This is an excerpt for a Lynskey letter: "Our tubing is grade 1, aerospace grade, 3/2.5 seamless tubing. Probably .034 - .035 in wall thickness. We have several suppliers around the world and here domestically that we deal with, depending on the tube specs. So there is no "one place" that our tubing is sourced from. All tubing is 100% first quality aerospace grade certified, and we also have several quality control testing that we do once the tubing is received. Our butting process is external butting, and we may take wall thicknesses down from .035 to potentially .028, again, depending on the model and which tube within the design." So as you can see it depends on the cost point of the bike if Lynskey will use US sourced titanium or not, all of Moots bikes are expensive so I could see them using US sourced TI. Having said that, Russian TI is actually better than US sourced TI. OT4 Aerospace titanium which is an equivalent to international standard Ti - 4Al - l.5Mn; Manganese and Vanadium are interchangeable in Ti alloys; Russia uses Mn because it is readily available in Russia. Russian OT4 would fall somewhere between 3/2 and 6/4 and be closer to 6/4. I can't find anything about Chinese TI. Also, the reason US sourced TI is more expensive is the American labor cost to refine it, doesn't mean that US sourced titanium is a better alloy.
Old 02-14-22, 08:30 PM
  #3111
BillyD
Administrator
BillyD's Avatar
Quoted: 11969 Post(s)
Liked 6,646 Times in 3,483 Posts
Hey, you three guys, this thread has been around for 16 glorious years. This arguing is messing it up. How about you guys drop it or move on.
BillyD is offline
Likes For BillyD:
Old 02-15-22, 09:11 AM
  #3112
Rdmonster69
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times in 216 Posts
Here Here !!
Can't we all just get along. I'm here to look at pictures of glorious titanium bikes and unless one brand has its tubes warm rolled on the thighs of a beautiful swimsuit model it all the same to me. I will say I support U.S. companies because I wont give those godless commie's my hard earned coin !!
Rdmonster69 is offline
Likes For Rdmonster69:
Old 02-15-22, 06:36 PM
  #3113
familyguy
Running on plenty
familyguy's Avatar
Bikes: Too many to list
Quoted: 23 Post(s)
Liked 63 Times in 19 Posts
Litespeed-built Merlin (Aspen seems to be the consensus). Swapped the front Tektro CR720 for a Shorty 4 setup which solved a few shudder issues. SPD pedals no fitted for commute and longer-than-around-the-block-to-the-shops duties.
familyguy is offline
Likes For familyguy:
Old 02-16-22, 08:12 AM
  #3114
Rdmonster69
Shawn of the Dead
Quoted: 277 Post(s)
LOL!!! your computer you're using was made in CHINA, so was your cell phone, most of the electronics and other parts in your car, your TV(s), your stereo, a lot of parts on the bike you ride including all the Shimano parts. I can go on and on, but I think you see how ridiculous your comment was about not giving your hard-earned money to the commies, but it was funny!
My computer and cell phone are provided by my work. I receive my hard earned coin by using commie products !!
But your right ... I was mostly joking ....when possible I support American companies despite all their use of heathen commie parts ....Thank god I like Italian motorcycles ....surely they do not use Chinese parts :; )
Old 02-17-22, 10:34 AM
  #3115
primov8
primov8's Avatar
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times in 95 Posts
Loving the cool air this morning. Great to be back on the Helix.
primov8 is offline
Old 03-10-22, 10:54 PM
  #3116
bamboobike4
Quoted: 359 Post(s)
Liked 582 Times in 336 Posts
Lynskey made this one, too.
26 years ago.
bamboobike4 is offline
Likes For bamboobike4:
Old 03-14-22, 11:50 AM
  #3117
indiglow
indiglow's Avatar
Bikes: Serotta Legend Ti, Bianchi D2 Super Pista
Quoted: 15 Post(s)
Liked 4 Times in 1 Post
26 years ago.
This is gorgeous! Can we please get some details? Curious about the frame in particular.
indiglow is offline
Old 03-15-22, 05:14 PM
  #3118
Nicke71
Liked 40 Times in 11 Posts
Seven Axiom SL
Nicke71 is offline
Likes For Nicke71:
Old 06-20-22, 01:11 PM
  #3119
Boerd
Bikes: Moots Vamoots RSL 2018, Passoni Titanio 2020
Quoted: 111 Post(s)
Liked 33 Times in 8 Posts
Nicke71, that is a superb looking bike! I always liked the Seven Ti bikes.
Boerd is offline
Old 06-24-22, 02:21 AM
  #3120
tFUnK
Quoted: 430 Post(s)
Liked 460 Times in 318 Posts
New bar tape to match the headset. Got some blingy chainring bolts too, but didn't want to get the hands dirty to install them. Oh, and added a holographic sticker on the down tube - looks good under the light. Heavy and noodly compared to my carbon bikes, but I like the thin-tubes aesthetics. Set up as 1x with 44/12-36, good enough for solo riding without serious climbs (roughly equivalent to 34/28 climbing gear). Threw on 25mm Paves; 25mm GP4000 would not clear the chainstays 😔. Maybe a potato chip mod away from running 30mm tires (clearance on fork and seat stays seem good).
tFUnK is offline
Likes For tFUnK:
Old 07-28-22, 02:25 PM
  #3121
clichty
clichty's Avatar
Bikes: Moots Vamoots RCS, Serotta Ti, Felt F55, Surly Ogre
Quoted: 37 Post(s)
Liked 38 Times in 12 Posts
Posting this in too many threads but oh well.
Just picked up my new Moots Vamoots RCS. New DA12 Di2 with a Stages left arm PM (no dual sided available yet). Titanium everything (stem/seatpost/cages) and carbon everything else. Went with Enve 4.5AR SES wheels; a bit more aero given the lack of elevation in the Midwest. Apparently Dura Ace 140 brake rotors don't exist yet so we adapted the rear to a 160 (extra braking power).
Got one of the new Silica titanium mounts however my old Wahoo Bolt didn't fit so I had to get a new one (oh darn). I was thinking about it anyway so apparently now was the time.
Only did a test ride before taking delivery and it was unreal. The sound of riding on the titanium and the Enve Hub was incredible. New DA shifts before your finger even leaves the shifter. Can't wait to give it a proper introduction to the road this weekend.
clichty is offline
Old 07-28-22, 02:51 PM
  #3122
DowneasTTer
Bikes: 2022 LiteSpeed CHEROHALA CITY, 2019 Canyon Roadlite 9.0 CF LTD, 2015 Giant FastRoad CoMax 1, 2001 Mongoose Pro Triomphe,
Quoted: 129 Post(s)
Liked 84 Times in 50 Posts
Here's one of our LiteSpeed Cheerohala City bikes at the turn around spot for today's ride.
DowneasTTer is offline
Likes For DowneasTTer:
Old 07-28-22, 04:27 PM
  #3123
genejockey
genejockey's Avatar
Wait - Did I not post the latest iteration of my Litespeed in this thread? I swear I've posted it everywhere else I thought I could get away with it!
This is the third and probably final build I've done on this frame since receiving it in December. 1995 Litespeed Ultimate with Time carbon fork. Ultegra R8000, Fulcrum Racing 4 wheels. I liked the previous one with 7410 Dura Ace, but it didn't have enough gears - 39x25 is not enough!
Likes For genejockey:
Old 07-29-22, 07:31 AM
  #3124
eric1971
Quoted: 72 Post(s)
Liked 21 Times in 9 Posts
eric1971 is offline
Likes For eric1971:
Old 07-29-22, 11:57 AM
  #3125
d-klumpp
Axiom Qs
Originally Posted by Nicke71
Seven Axiom SL
Love the Axiom! After 15 yrs with my Alaris, the equivalent of today's Axiom S, I plunked down a deposit on an Axiom XX this week, so I would appreciate some details on your rig that I can't glean from the pics. Back when I bought my Alaris, Seven made more components, so I started with Seven fork, stem, and seat post. Since the stem is certainly no longer an option, what stem did you choose?
Thanks,
Dave
BTW, really like the looks of the bottle cages!
d-klumpp is offline
