Kickr Core Hub/Cassette question
Bikes: Motobecane USA - Mirage SL
Quoted: 15 Post(s)
I'm thinking about buying a Kickr Core to run with Zwift because my Powerbeam won't provide resistance anymore. The Kickr Core comes with the ability to put on an 11 spd Cassete. I assme, since 7/8/9 cassettes are the same size as 10 (correct me if im wrong) the spacer for a 10 spd to 11 spd hub is what I'm looking for.
Also is there a difference in the mating of a SRAM/Shimano gearset, or are they interchangeable??
Likes For rlmalisz:
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
The Core comes with the 1.8mm spacer you need for 8/9/10. Either SRAM or Shimano 8/9/10 cassettes will work.
Likes For shelbyfv:
Randomhead
Liked 3,699 Times
Moved here from General Cycling
SRAM/Shimano are the same interface. Ignoring some newer cassette bodies. If you are using 7 speed, then you need a 4.5mm spacer. For 8+ speeds, you need the 1.8mm spacer. Those spacers are readily available, your local bike shop should have some
In case anybody wants to try this or is wondering if it works: I have installed my 1992 Koga Miyata Exerciser 7speed steel bike on my Wahoo Kickr Core. Of course spacers are needed to fit a 7speed cassette on the Kickr. It was running great, but the jumps between the 7 sprokets were a bit to big for me (if you're an exact cadence guy...). So I switched to an 11speed cassette and chain......and....surprise: it works!!
I'm using:
-Steel frame (126mm original spacing fits on the Kickr with a bit of force)
-Shimano 1055 rear derailleur (short)
-Shimano 1055 crankset (52/39)
-Shimano 7speed downtube shifters (for 11speed you have to switch to "friction mode" because the indexing is 7speed...)
-Shimano 105 11speed 11-28 cassette
-Shimano 105 chain (11speed)
I'm using:
