Converting from drops to flatbar
We're seriously considering converting our Santana Nuovo handlebars from drops to flatbar. My Captain's back is getting stiffer and it's getting less comfortable to manage the bike with the drop bars. We've ridden flatbars and drops on other single and tandem bikes in the past and understand the arguments for more hand positions in the drops, etc.
We're curious if anyone has done this, and what advice you may have. Can you also recommend a tandem specific shop to purchase the needed parts from? We're in N.California but suspect we may need to purchase online.
We love the ride and fit of the bike and thought that although it may cost more than we want to spend, it would still be cheaper to do a conversion than trying to find another bike that's as comfortable and fits us as well. We don't want to shop for another bike when the fit on this one is perfect for us.
Thanks for any thoughts!
Bikes: Merlin Road, Rivendell Road, Arvon custom tandme, Hi-Light G-7
Quoted: 24 Post(s)
Liked 11 Times
I have done the conversion the other way from flat bar to drop bar on a MTB. In my case, the handling felt floppy afterward and I never liked it.
Have you tried raising the handlebars and reducing the reach with a different stem? That would be cheaper than converting to flar bar. To change from dropbar to flat bar will require changing the shifters and quite possibly the whole drive train depending on the age of your tandem.
Quoted: 2495 Post(s)
Liked 738 Times
I have done the conversion both ways. It is not tandem specific. I get what parts I don't already have from any online retailer that has what I am looking for. This is the most recent conversion from FSA drop bars with Shimano Flightdeck brifters to a 31.8 center section flatbar and three finger long pull brake levers and Shimano Rapidfire trigger shifters. It matters a whole lot what your brake types are (v-brake, canti, disc) and what kind of shifters you have now (brifter, bar end). If I know what you have at present I will have a pretty good idea of what you need for a conversion.
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
You will need to shorten (sorry) lengthen your stem by approximately 45 mm. As above said, the conversion depends on brake type. We have toured many years, my stoker removed her drops within the first year. I never understood the reason for stoker drops. I hardly ever used the drops, so when we replaced our santana with a new custom bike, we went for slightly angled-back flatbars, ergon grips and GP5/GP3 bar ends. I wish I changed years back. On windy days, the reach on the bar ends approximates drops. The wider bars are more comfortable and stability is better, especially when fully loaded with front panniers. The mtb brake levers allow quicker and stronger braking.
alpine cross trainer
Bikes: Specialized Roubaix, Quintara Roo Sendoza, DaVici In-2-Ition Tandem,
Quoted: 21 Post(s)
Liked 20 Times
At the age of 73, I also am less flexible and less comfortable with my drop bars. I added a stem riser which was much easier than replacing my drop bars. The stem riser let me sit straighter, taking pressure off my hands and removing lots of strain from my neck and shoulders. The only negative is that directs more pressure toward my butt, which I can deal with.
Quoted: 18 Post(s)
Liked 39 Times
My only word of experience, having done both. As a short legged captain, I find drop bars for the stoker easier to swing my leg over. Flat bars for the stoker seem to extend forever and I think I'm going to fall over half the time when getting on the bike. I'm sure this is due to my short legs and frame that never seems small enough. I only point this out because there are weird things that happen when you change your tandem, so don't be surprised if something random gets easier/worse with your change.
IMHO - setup your tandem however makes you ride it the most!
simon
Thanks everybody! Good encouraging info here.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
If the issue is back flexibility, it’s going to be a lot cheaper and easier to just get a stem with more rise
You could get lost and die.
You could hit a tree and die.
Bikes are designed weight and geometry wise to handle a certain way with certain bars, weight distributions and angles. If you change the bar you are going to significantly change all those factors and the bike won't handle well.
Case in point I recently did an Emonda SLR build. My other bikes are pretty upright, I got an angled stem for another drop bar gravel bike because I hated it. Of course in the last few years I hired a personal trainer and engaged in a very serious fitness journey. For the first time since I was on a college varsity team exactly 25 years ago, I was able to touch the ground with my fingers while keeping my knees straight.
So anyway I was afraid of a very "low" position so I started the build with a higher angled stem. It wasn't bad so I dropped it and eventually went to the handlebar Trek recommends for that bike, almost a Tour de France type position. Didn't bother me; it would have years ago but this was just fine. However, the lower and more bent forward I was, the better the bike turned and handled because of course, the Emonda was designed to have the rider in a very aero, far forward position with plenty of weight over the front tire. Not doing so even by a little resulted in worsened, much less sharp handling.
So I went back and put the original stem on my Warbird replacing the angled one. Indeed, then too the bike's handling improved significantly with much sharper turn into the curves. It's also more stable on trails while descending and doesn't jostle around as much. Just 20 freaking degrees.
So for you, you should do one of two things:
1. Engage in better fitness and flexibility so you can enjoy the drop bar again. Not easy but worth it. You can do it at any age, you'd be surprised at the long term results if you are very consistent in a stretching, body weight and light resistance regimen.
*OR*
2. Sell your current bike and buy a new one with a flat bar offering whatever body position you like.
You can get an angled stem to make the bike liveable while you engage in #1 but be prepared to have it negatively affect the bike's handling to a degree as it did for me above.
*OR*
Quoted: 332 Post(s)
Liked 740 Times
*OR*
*OR*
If you change your bar, you may want to have a variety of stems in different angles and lengths on hand to further tune the fit.
Especially for a tandem, assuming it fits you, it’s overkill to replace the whole bike because you want to try a different type of bar. You can always switch back.
Thanks for all this information. Very helpful!
We decided to start by changing out to a slightly different stem that raises the handlebars a bit and brings them just slightly closer. So far so good, but we haven't been out on any long rides yet.
We really like this bike. It fits us perfectly and we love the quality of the ride. We'll try anything we can before going through the hassle of selling this one only to buy another. It's very challenging to find a bike to satisfy 2 people and we're sticking with this one for as long as we can.
Likes For k8t:
Quoted: 680 Post(s)
Liked 949 Times
I did butterfly bars on ours but I could nto find a mirror that worked very well so I went to straight with bar ends all in nice soft bar tape. really feels good. the fist is my regular bike but the tandem is the same.
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 334 Post(s)
Liked 782 Times
Thanks so much for this info regarding Jason at Tandem Outfitters. We are within reach of the Bay Area and will definitly
think about giving him a call.
Cheers!
Cheers!
