Suntour Perfect with 13-tooth cog?
Old 05-03-22, 06:12 AM
jonwvara
jonwvara's Avatar
Quoted: 765 Post(s)
Liked 660 Times in 351 Posts
I once owned a Suntour Perfect freewheel that had smaller threads in the outside cog position, allowing it to take a 13-tooth small cog. They're not very common, but there are some around, I think. What I can't recall, and haven't been able to find out, is whether these freewheels are designed for a the standard six-speed 126mm OLD, or for the 120mm six-speed ultra variant.
What I'm asking, I guess, is this: Did Suntour (or anyone else, for that matter) make a 120-spaced 6-speed freewheel that would accept a 13-tooth cog? At least one inquiring mind wants to know.
www.redclovercomponents.com
--Ogden Nash
jonwvara is offline
Old 05-03-22, 07:26 AM
OldCoot
Bikes: 82 Univega Specialissima, Bike Friday Pocket Rocket, Kona Wheelhouse, Rocky Mtn Thunderbolt, Viner Strada Bianca, ~73 Bob Jackson, ~75 Volkscycle Mark100.
Quoted: 70 Post(s)
Liked 183 Times in 73 Posts
Yes, there was a Suntour freewheel version for 6 spd 120 OLD. see https://www.sheldonbrown.com/suntour-freewheel.html
OldCoot is offline
Likes For OldCoot:
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1453 Post(s)
Liked 2,195 Times in 962 Posts
Jon, in my service experience and IIRC, the 13T Perfect is always spaced for 126mm. I'd check the one I think I have but it is in NH and I'm in GA.
I recently worked on a client's Atom 77 Compact. As you can see it had a 13T sprocket.
Also, the Suntour New Winner, Winner Pro, and Winner bodies can be 6 speed narrow-spaced with 13T.
While I have limited experience with the Regina CX narrow spaced, I'm certain they can be equipped with a 13T as well.
Bob
pastorbobnlnh is offline
Likes For pastorbobnlnh:
Old 05-03-22, 07:29 AM
pastorbobnlnh
Freewheel Medic
And Jon, will you seriously use a 13T? I thought I knew you better!
Bob
Old 05-03-22, 08:55 AM
mech986
mech986's Avatar
Quoted: 355 Post(s)
Liked 345 Times in 174 Posts
This source says yes to a 13T on an Ultra Winner body but not the Perfect body.
https://www.disraeligears.co.uk/site...-_page_26.html
Italvega and Torpado Enthusiast
mech986 is offline
Old 05-03-22, 09:01 AM
jonwvara
jonwvara's Avatar
Quoted: 765 Post(s)
As a general rule, I don't know better, regardless of the endeavor involved. But in this case, I suppose I will take the easy way out and restrict myself to a 14-tooth high. Coasting down hills has a certain charm.
--Ogden Nash
jonwvara is offline
Likes For jonwvara:
Old 05-03-22, 09:33 AM
sd5782
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 698 Times in 393 Posts
I just picked up at a bike show a Suntour 13-28 6 speed that seems to be ultra spaced when holding it up to compare with another Ultra 6 I have mounted. Body says VIA with a date code of bd. It measures around 29mm thickness. A very nice 13-15-18-21-24-28 spacing and silver cogs. Sorry about the poor picks. Looks like a slightly wider spacing gap between the two smallest cogs. This one may be a home built one, but may give possibilities to others for their own custom built one.
sd5782 is offline
Old 05-03-22, 04:15 PM
pastorbobnlnh
Freewheel Medic
I suppose that technically speaking, the 13T Perfect has a different model name. It's shown in the post above. It uses the same sprockets which fit Perfect and ProCompe bodies in the other five positions. The internals are identical with the exception of the upper part of the outer body.
I believe the one above has had the original standard spacers replaced with ultra spacers. The giveaway is the gap between the 13T and the second sprocket. IIRC, this model only came in standard spacing. Can you compare it to a six speed Shimano? It should be about the same height.
Old 05-03-22, 04:54 PM
sd5782
Quoted: 583 Post(s)
Pretty close in height of cogs to the Shimano. Perhaps the Suntour is just a wee bit thinner through the stack height. The Shimano does have more overhang. Shimano is on the left.
sd5782 is offline
Old 05-03-22, 04:56 PM
Gonzo Bob
cycles per second
Gonzo Bob's Avatar
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times in 48 Posts
Yes. I bought a Team Fuji in 1984 that was spaced at 120mm and came with a Suntour New Winner Ultra-6 13-24 freewheel
Gonzo Bob is offline
Old 05-03-22, 05:48 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
The Perfect and the Winner/New Winner are completely different freewheels. If the Perfect ever came with a 13T outer I've forgotten it.
thumpism is offline
Old 05-03-22, 06:28 PM
pastorbobnlnh
Freewheel Medic
...and to clarify further, the internals on a New Winner are completely different from a Winner which is different from the Winner Pro. However, a ProCompe is a tuned-up Perfect.
Just to add to the conversation.
Bob
Old 05-03-22, 07:25 PM
John E
feros ferio
John E's Avatar
Quoted: 1393 Post(s)
Liked 1,326 Times in 837 Posts
I never thought I would need a 13, but it works well with a 45-42 / 13-15-17-20-23-26 half-step or my 46-38 / 13-15-17-19-22-25 1.5-step. With a 49 or 50T outer chainring, I am happy with a 14T high in back.
John E is offline
Old 05-04-22, 12:58 AM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1955 Post(s)
Liked 3,661 Times in 1,679 Posts
I thought I had a perfect with a 13 but maybe I'm wrong.
Edit.... I was wrong, just looked.
52telecaster is offline
Old 05-04-22, 05:18 AM
bulgie
blahblahblah chrome moly
bulgie's Avatar
Quoted: 1176 Post(s)
Liked 2,572 Times in 1,074 Posts
Not what anyone was asking, just a fun fact, in the mid-'80s there was a wide 6 (not Ultra) that went to eleven. Endorsed by Nigel Tufnel.
They were Winner Pro IIRC. I have a couple of them, could go look but I'm lazy and someone here (@pastorbobnlnh) will know off the top of his head.
The Z-11 cog could only go on the Y-13, no other choice. The Y-Z combo could only go on a wide-6 not narrow 6 nor 7 nor 5 speeds.
I used 'em on my MTB for a while there, circa '85. The 11t let me use a 42 for the big ring, on a XC-racer. An adapter I made let me use a freewheel cog as the granny ring on my triple, a TA 5-vis; I settled on an 18 to 20t granny That let me use a smaller freewheel, which in turn let me use a Dura-Ace 7400 short-cage rear mech, so I had SIS on my MTB — before the pros did. (Joe Murray came up to me at Crested Butte and complained about Shimano promising him SIS and not delivering. He seemed mad at me for having it!) I had to make a "perch" to graft the SIS DT shifter to, at first, thumb-shifter position on a flat bar, then a bit later I switched to drop bars and made bar-end shifter perches for the DT levers. Later there were commercially-available products to do this — Keith Bontrager for one, sold bar-end shifter perches for DT levers — but none were around when I first made mine. And of course eventually Shimano made indexing thumbies and bar-ends, putting all us DIY-ers out of business...
Oh but I'm totally rambling now. What were we talking about?
Mark B
bulgie is offline
Likes For bulgie:
