single speed/track chainrings on a double.....
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Trying to sort out gearing for a Holdsworth build. 144BCD Campy cranks. I think I can get the gearing I need/want with 42/46 in front and 13-32 freewheel, but the 144BCD chainrings I'm finding (at a reasonable $) are specified as 'track' rings. Track rings are 1/8", road/double/etc 3/32".... Is this likely to cause a problem? Will a 6-7-8 chain work, or is it too narrow for a 1/8" ring. Cyclone II mechs, friction, don't care about lack of ramps/pins, etc.
Thx!
Thx!
Quoted: 4806 Post(s)
Liked 3,929 Times
Won't work. You need an 1/8" chain to run over the chainwheel. Too wide for the spacing of the freewheel.
I can't say I've ever tried to run 1/8" chain over the old freewheels but 3/32" chain was invented specifically for the job. I do know that a 3/32" chain will not sit down on an 1/'8" chainwheel or cog. The teeth are too fat to fit inside the links.
Quoted: 761 Post(s)
Liked 1,563 Times
Quoted: 3812 Post(s)
Liked 3,342 Times
interestingly enough there are such animals as 1/8" multispeed gear blocks
took in a Chiorda built Kmart derailleur five speed machine with such a drive train
1/8" Agrati Thun pattern chainset
1/8" drive chain
Regina 5V gear block with 1/8" cogs
1/8" drive chain
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 986 Post(s)
Liked 635 Times
I presume this is, ahem, "interesting" on a 120mm rear hub? Or they built narrower rear hubs to accommodate this?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 3,342 Times
had no occasion to measure OLD of rear hub
frame spacing as recalled was 120mm
