Average elevation gain
Bikes: 1975 Motobecane Le Champion lilac, 2015 Specialized Secteur Elite
Quoted: 97 Post(s)
I am curious how hilly the average ride is for other recreational cyclists.
My usual road routes average around 20 miles with an elevation gain of around 800 ft.
I can ofc choose alternate routes that would be less hilly or more hilly but that seems to be where I have settled in.
I get my data from Strava and am also wondering how accurate it is concerning elevation?
Ride On!
Bikes: Allez DSW SL Sprint | Fuji Cross
Quoted: 227 Post(s)
About the same for me. 600-1000 ever 20 miles, unless I'm looking for hills.
Just saw your question about strava accuracy -- it's pretty good. I don't notice much difference (ON THE ROAD) when using my device with an altimeter and my device that doesn't have one.
Where I do notice a difference is bike paths that follow road ways *can be* WAY off on Strava.
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
My 60-km route that I've been enjoying this summer is around 350 m of elevation. This is one of the hillier routes around here. There's one descent where I might reach 65 km/h, and to be frank, it's a bit scary.
I am averaging about 80ft of climbing per mile (15m per km) this year. I mainly do climbs, so my average might be higher than most. Most rides tend to be about 100ft of climbing per mile.
Strava is only as reliable as the data it is given and elevation is inconsistent. Many lower-end Android phones report far higher than average elevation. The same for dedicated GPS devices such as watches. Even Garmin devices report bad data.
iPhones tend to be correct as well as most modern and higher-end Android phones.
Bikes: 2016 Trek Domane 5.2
Quoted: 29 Post(s)
Quoted: 18424 Post(s)
Liked 15,579 Times
I consider 60'/mile moderately hilly. 100'/mile is quite hilly.
Quoted: 104 Post(s)
Liked 5 Times
My recreational cycling club has regular rides with 100 feet of climbing per mile of a loop ride (eg 6000 feet of climbing on a 60 mile ride). We consider this to be a hilly ride. We also have easier rides.
Quoted: 97 Post(s)
100' per mile on anything over 10 miles would probably kill me or I would need to greatly reduce my overall average speed.
Quoted: 18883 Post(s)
Liked 10,646 Times
I did Loup Loup Pass from the valley floor this weekend. It was about 3,500 of vert and a 32 mile loop. Of course half of that was the way back down. I enjoyed the ride up a lot more than the ride down, mostly because the road was awful for the descent.
On average, though, I got about 60 feet of gain per mile the last time I checked. Across all rides, the fun ones on weekends and the after work loop.
Quoted: 2952 Post(s)
Liked 3,106 Times
It all depends on where you live. I'm in the middle of a giant river valley. I can ride 100 miles with 100 feet of elevation gain, all of that levee roads and overpasses.
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
Average solo ride 65-75km & 600-800m excluding neighborhood rollout distance
Average group ride 75-110 & 600-1200m depending on who leads it
Convert that to your bizarre units
Spin Meister
I don't have a typical ride because there's so much mixed terrain in Los Angeles, where I live, and in California in general. Hill climbs are just a few miles north and south of my mid-town home.
I like to cram as much uphill as I can into as short a distance as possible. I want to put in 2,000 to 3,000 feet in 15 miles or so.
Below is a typical ride with hills from two days ago, in the Santa Monica Mountains. Of course, the start and finish were flat, so most of the climbing – 2,200 feet – took place in a little under 8 miles. That's about 280 feet or so a mile. The uphill part of those miles averaged about 10%, with some sections going to 15%.
I think these types of rides are part of the reason I wake up each morning with a heartbeat in the low 40s.
This post is a natural product. Slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects.
I am not sure why it matters how much climbing other people have done, you will get answers from 0 to 30,000 ft.
Do what you want to do.
Quoted: 1332 Post(s)
Liked 398 Times
1200-1500 feet over 20-25 miles tends to be my average. Trying to start working in more hills and bump that up once in a while.
Spin Meister
"I get my data from Strava and am also wondering how accurate it is concerning elevation?"
As long as you're getting consistent readings from the same ride, don't worry about it.
If you want to test out your Strava elevation readings, select "Create Route" from the tools menu and Strava will create a route with elevation based on its data. Obviously, it should match. This method works for anybody's ride, so you can also test if someone else's device is faulty. Use this technique on any of the leaders of the Strava climbing challenge, and you will find all of them have bad elevation data.
Quoted: 4806 Post(s)
Liked 3,932 Times
To take your question literally: average elevation gain. Since most of my rides begin and end at my garage or to somewhere, then later back, almost exactly zero.
Most of my rides (by number) are in town and back. I record that as 550'. Recent months, I have been doing little in hills so I record my rides through the Tualitin valley as flat though little of it is actually. If I ride up to Skyline over Portland, getting to 1000' is easy. Bald Peak southwest of Portland is about 1600' so that's usually a 2000' day.
I do not have a computer with elevation function on any of my bikes. I count the elevation gained on specific hills, not gradual inclines or small stuff.
Ben
Ben
Non omnino gravis
This shouldn't be as hard as people are making it out to be. Look at your total distance and elevation. Divide by number of rides. If you have Veloviewer, it's right on the summary page.
Total Rides: 364
Avg. distance: 34.5 miles
Avg. elevation: 1,418ft
If I climbed the "average" amount some have claimed here, combined with the miles I log, I would do over 1 million vertical feet a year. People seem to ignore the descent that invariably follows the climb when giving their "averages." My climb to the Forest Falls campground yesterday logged 4,600ft in 20.6 miles-- so I guess my BF-standard climbing average is 223ft/mi.
Total Rides: 364
Quoted: 7 Post(s)
Total Rides: 364
Total Rides: 364
Non omnino gravis
Yes, but the OP asked what is the "typical" elevation gain by folks on here, which is total ascent divided by number of rides. I've averaged 42ft/mi this year, which is based on total miles ridden, both ascending and descending. I can't sit and say, "Oh my real average is like double that, because I'm not going to count the miles going downhill." That's the equivalent of having the power meter ignore zeros.
Bikes: 2014 Cannondale Synapse Carbon 4 Rival; 2014 Cannondale Trail 7 29; 1972 Schwinn Suburban, 1996 Proflex 756, 1987(?) Peugeot, Dahon Speed P8; 1979 Raleigh Competition GS; 1995 Stumpjumper M2 FS, 1978 Raleigh Sports, Schwinn Prologue
Quoted: 213 Post(s)
The ride I'm about to go out and do is around 850' over 27 miles. Not excessively hilly. Not super flat, either. But I like hills. I try to get out to the mountains when I can. A very hilly ride for me would be 3000' over a metric century. I've done more, but I would classify that as very, very hilly. Usually pretty darn wiped, as well. Actually a very hilly ride wipes me out, too. But what can I say, I like the pain
Bikes: Wizard, Eisentraut, Paramount, Litton, Turner, Surley, Trek, Kona, Landshark, Hujsak, Masi, Tesch, Holland, Retrotec, Spectrum
Quoted: 37 Post(s)
It's a matter of choice for me. Do I want to do a hilly ride or a flatish ride. Road bike or mountain bike.
I, most of the time, live on a hill in So Cal so any ride involves climbing to finish the ride, and most often to start the ride as well. I can do a road ride that averages 19.3'/mile on a 41.5 mile ride and most of the climbing is in the first mile and last two miles. I can also do one that averages 77.7'/mile over 30.8 miles and I'm rolling all the time. My mountain bike rides are all over 100'/mile with most in the 130-150'/mile range. My commute is 21.3'/mile.
When I go to our house in No Cal, the average goes up on road rides. Largely because we seek out the climbing. We average closer to 100'/mile. The commute is 36.4'/mile.
I live in North Carolina for a few years. When at the coast, a road ride was ~5'/mile. In the mountains it was ~100'/mile. The commute in Raleigh was 50.5'/mile. Mountain bike showed similar variability.
So it's all numbers and what you seek. Best to just go ride.....
