Stripped Threads on Solid Axle
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
Somehow, I managed to strip some threads on a solid hub axle on the drive side.
The nut takes a couple of turns and then releases. I can take the nut off no problem.
These are vintage British hubs, pretty rare. I suppose I can try to take the hub apart and
adjust the spindle to move it a few millimeters to the drive side and hope something catches.
Is that my best route? Or try some J.B. Weld?
Quoted: 4210 Post(s)
Liked 3,875 Times
JB Weld won't do much but to lock the nut in place. Can you determine the axle threading? I suspect 3/8" x 26TPI (or 9.5mm x 26) as these were very common back then. If so then a replacement axle (and nut as it's likely also thread damaged too) should be easy to find, being the most current common solid spec. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
perhaps a silly question, but did you try a new nut? if the threads are stripped and not too bad, you may be able to repair them. can take a picture?
i wouldn't use jb weld and expect it to hold very well under that kind of use. iow's, it's not at all designed for it
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 199 Times
I bought an old Campy hub on EBay and the axle was stripped. I used a thread file and rolled the axle into the file, instead of clamping the axle down and filing it. I was able to restore the threads and the cone and locknut can now spin on and off with no resistance. Maybe you can try using a thread file and using a new nut as previously mentioned.
I had posted these pictures in the “What have you been wrenching on lately?” thread.
The axle was stripped and the cone nut could not be removed.
I twisted the axle forward and backwards across the file to restore the threads.
The axle after the repair.
Cleaned up and ready to be re-assembled.
Standard Member
Liked 940 Times
Andrew, Yes, those are the correct specs. I'll make sure I ask about the threading if I buy something.
Thook, I tried two different axle nuts (both of which worked fine on it before). I'll try to get a photo
when I take the wheel off. Thanks for the tip on the JB Weld.
Momoman, I had not heard of a thread file. I was looking at possibly investing in a thread die tool,
but the file seems less expensive. I'll have to really examine the threads to see the extent of the damage.
Likes For 1989Pre:
Liked 3,875 Times
Old time LBSs have/had the Bicycle Research thread chasers. These were nut like things that would not cut or remove material but try to reform thread profiles. You might call around and get lucky. But the cost of a replacement axle is pretty low. Andy
AndrewRStewart
AndrewRStewart
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
If there's a bike co-op in your town they'll have a bin full of salvaged axles.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Senior member
Quoted: 943 Post(s)
Liked 658 Times
if what Andrew says is correct on the thread sizing, to my recollection, any auto parts store should have the size in their thread repair rental kits (comes with files and chasers). i say rental, but it's really free, if you aren't aware. you get your money back when you return the tool/s
Standard Member
Liked 940 Times
Here is a photo of the British Hub Company Eurekas, from the 1950's. I'll take the rear apart and get some specs on the spindle.
Andrew R. Stewart, thanks. I'll ask about the thread chaser over at the co-op, which is the best vintage-knowledgeable shop in the area. If I buy new, I have to be sure I'm getting the correct specs.
Andrewclaus, I'll also ask them about axles.
Thook, I did not know that. That is definitely an option for me to keep-in-mind.
Dan Burkhart, thanks. I won't be too surprised, then, if they don't have it.
Liked 3,875 Times
What! Did you actually say that someone should buy a product, use it then expect their refund and refund??? Sorry but this attitude is just really bad and IMO unethical. As a lifer in the LBS and retail I would see tht we were out of stock and or too bust to ever help this consumer again if they tried this. It's boarder line stealing, plane and simple. Andy
AndrewRStewart
AndrewRStewart
Quoted: 122 Post(s)
Liked 199 Times
Advance Auto Parts Tool Loaner Program
Autozone loan-a-tool
edit: I corrected the name on the Advance Auto Parts link above. Also added the Autozone link.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
it's really fantastic that the stores do it because it saves the backyard mechanic a boat ton of money on the repairs requiring very specialized tools. quite often, those tools are expensive to buy though you may only ever use a tool like that once or twice in the life of your vehicle
Quoted: 1438 Post(s)
Liked 1,092 Times
I do not understand how removing metal from a threaded shaft which has worn/stripped to the point that a nut will not hold will be of any help. The thread form may be restored but the diameter will be reduced. I can see how rolling metal back into shape as Andrew Stewart suggests might work, though.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
sometimes (not necessarily on his axle) you can recut threads and go to a slightly smaller diameter. i've done it different situations, just not real often. eg...exhaust manifold studs come to mind. it can be easier to cut/rethread a frozen stud vs breaking it off and having to drill it out.
maybe my reply here is all TMI, but i'm feeling chatty on this rainy day
Liked 3,875 Times
It seems that I jumped to a conclusion about thook's comments. I have not heard of auto parts stores renting tools before, tool rental outfits yes but not otherwise retail shops. I take back my strong comments, sorry. Andy
AndrewRStewart
AndrewRStewart
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
I’ve never done this on a bicycle, but I have done this for concrete anchors and column anchor nuts/bolts. So take for what it’s worth.
get an extra nut of the appropriate size. Screw it halfway unto an extra axle. So half the nut is not threaded. Cut straight down making 2 slots halfway down the nut - the half that isn’t threaded. Thread the rest of the way down, this will debur your cut and allow the cut side to thread onto the axle you say is stripped. You’ve now made a makeshift thread chaser. Thread it down, slotted side first onto the stripped male threads. It will clean up the threads if they aren’t too bad.
If it really is stripped and not just banged or galled, get a new axle.
Liked 3,875 Times
AndrewRStewart
AndrewRStewart
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
My experience is just not always in the shop with all the correct tools. More like “Ah shoot, quick grab the torch/grinder/portaband before the inspector comes around.”
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Standard Member
Liked 940 Times
Update: Since I had no problem getting the nut off (it would just not thread completely on), I took the hub apart and moved the axle over to the damaged (drive) side a bit, maybe 7mm. Now, the nut threads right on. Somehow, it threaded past the slightly-damaged threads and made it to the area of the good ones that were then revealed. Thanks for all the tips and suggestions. They were almost necessary, and might come in handy in the future.
