ebike crankarm removal?
My neighbor's ebike developed a squeak in the crankcase/bottom bracket after washing (hose, not pressure-washer). Knowing nothing about the drive system I still volunteered to look at it.
Couldn't get past first base, which is remove the crankarm. My square-taper crankarm extractor does not work because the spindle's hole is too big (nothing to drive against).
I thought maybe it's one of those "self-extracting" ones I've heard about. Looked at a Park's video and no, it's not self-extracting.
Tried to pry it off. Nope. Nothing convenient to pry against anyway.
I can (obviously) remove the retaining bolt (see pix). It is an 8mm hex, iirc.
How do I remove? It's a Suntour arm, if that is helpful.
And if anyone if familiar with these Bosch motors (bottom bracket drive), is there anything to lube?
You need an insert that sits on the end of your crank extractor for Octalink/ISIS cranks.Like This https://www.parktool.com/product/cra...-cranks-ccp-44
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
While I don't necessarily recommend it, I've seen someone cover an octalink hole with a coin and then use a square-taper crank tool.
Likes For Rolla:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
CWP-7 from Park would work well and save you space in the tool box so no need for CCP-44 and CCP-22 but you could get both of those and be set CCP-44 for ISIS and Octalink cranks.
Also if you need to remove a lockring it happens to be the old 8 notch XTR tool
Thx guys. I mainly do vintage and have only worked with cottered and square tapered. I do have four bikes with external bearing BB's but I have not needed to service them yet. I assume they are octalink. But I want to swap the cranks on one (back to vintage) before selling in the spring, so I will buy a tool then, maybe the Pedro. My old crank puller had the piece to handle both types, but it seized up, I tossed it, and its cheap generic replacement will only do square taper.
Clark W. Griswold
Liked 3,996 Times
Quoted: 883 Post(s)
Liked 824 Times
I used the "dime" trick on ISIS several times, but never had an "Octa" (don't know why that shouldn't work though). That's in the past with the appropriate Park tool.
