Tubeless... What would you do?
My hands can affirm that they were not having fun. They've been blistered after chipping away at the dried sealant residue stuck on the tires last week. About 1/3 of the tire left on one, and 1/2 of the way left on the other.
Then when I'm done with this there's the other tire I've set up tubeless that I need to pull to swap tires. Basically once I get this pair of Conti Terras cleaned up they're going back on the XO2 with TPU tubes. So the Schwalbe G1s currently on the XO2 need to come off (and the rear is set up tubeless with fresh sealant just a few weeks ago 🤦♂️). Not really looking forward to any of it, but it is what it is.
Quoted: 431 Post(s)
Liked 460 Times
I'm cleaning out the old sealant because I want to patch them from the inside and then there's a good chance I will just run them with tubes afterward. The residue sealant is quite tacky and I'm not sure how they will get along with an inner tube, be it TPU or butyl.
Quoted: 431 Post(s)
Liked 460 Times
I guess a lot depends on what sealant you use, how long it takes to wear out the tire, and how fussy you are about cleaning up sealant. It can range from what you describe, to scraping some not so dry latex, to never bothering at all. I mostly don't bother, but when I did, I didn't find it to be a big deal.
Quoted: 242 Post(s)
Liked 455 Times
I have the pleasure of dealing with tubeless and get to see a lot of different tires and sealants when replacing the tires or refreshing the sealant.
It's interesting to see what the inside of the tires look like and unpleasant to remove the old and dried sealant...which no longer works as it is a dried coating on the inside of the tire.
Some tires have large chunks of sealant that we...I lol...remove before adding sealant.
I don't know if at some point the layers and chunks change the ride feel of the bike and certainly on a heavy, full suspension bike the added weight is negligible imo.
We remove the worst chunks and peel away what easily peels then give it a good scrubbing with warm, soapy water, wiping dry with a shop towel then back on the wheel and fresh sealant added.
It does work great on pin hole punctures and good on bigger punctures when a plug is used. but it can be a real mess and hassle when it doesn't work and the rider fails to carry a tube...just in case.
Likes For Kai Winters:
Quoted: 6972 Post(s)
Liked 10,968 Times
The dried sealant will not affect the tube.
In other words, you are still making this much harder than it needs to be. Just throw in a tube and ride.
Likes For Koyote:
Quoted: 1248 Post(s)
Liked 1,323 Times
What always baffles me is that even after it is pointed out that this is not an issue, the same rhetoric keeps coming back. The other bizarre response whenever Tubeless comes up is the response that flats are not an issue for certain individuals as they have ridden for up to 7 years and never get flats. Those individuals completely miss the point; flats are an issue for most active cyclists who choose to ride supple performance tires outdoors. Comparing tubeless to Gaterskins or Marathons is ridiculous as nothing ruins a good riding bike more than crappy dead tires. Tubeless allows people to ride supple high-performance tires and virtually eliminate ride-stopping punctures. Squirt in some sealant through the valve every 6 months or so and replace the tire once worn out what is so hard about that? If a puncture does not seal, jab a plug-in (Dynaplug for me) keep on riding and replace the tire when worn out.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
I was not joking about the natural loofah, which is slightly more abrasive than a dish sponge. That is why people use it to exfoliate.
Liked 10,968 Times
And to reiterate a couple more points before I leave this thread:
--You don't need to clean old sealant out of a tire.
--You still need to carry a spare tube and inflation system even when running tubes, so that's not a rap against tubeless.
--You don't need to carry a sewing kit, sewing machine, or floor pump when riding tubeless.
--You don't need to carry super glue when running tubeless. (Honestly, where did THAT come from? Crazy.)
--YOU DON"T NEED TO CLEAN OLD SEALANT OUT OF A TIRE.
Likes For Koyote:
Liked 1,323 Times
When these folks claim that they don't need tubeless because they rarely (or never) get flats, I really wish they'd give us their annual mileage and riding conditions. I mean, if you're riding a couple thousand miles per year on nicely paved roads, then sure, maybe you rarely flat -- and when you do, a roadside repair is no big deal. I ride 7k-8k miles per year, much of it on Flint Hills gravel -- and tubeless is a game-changer. More times than I can count, I've gotten home from a ride to find sealant on my frame -- and yet, I never even noticed that my tire had been punctured. I just rode.
Likes For Atlas Shrugged:
Quoted: 2495 Post(s)
Liked 739 Times
It's not weird, it's evolution. Humans have a brain structure, I forget the name of, that allows us to extrapolate a fatal scenario without actually having to die from trying it. My cat must have a similar structure because he would jump out the ground floor windows all the time, but never, ever, out the second floor ones.
Liked 10,968 Times
So much drama.
Quoted: 431 Post(s)
Liked 460 Times
I get it, in most cases you don't need to remove old sealant. Yes I should have just plugged it and called it a day 🤷♂️
But I'm already in the situation that I'm in, and I'm gonna try to remove all the sealant. I don't have a better reason other than I don't want it in my tire. But a secondary reason would be to try to locate the hole to do a patch from the inside (and run tubes with it later).
But I can also think of a couple of other reasons why one might want to do this. What if I was planning to run latex tubes? What if I was planning to list my tires for sale? These situations work out better if the sealant were not there. So yes it may be a silly exercise to the majority here, but to me it makes sense to do it, and since this is the internet I'm allowed to gripe about the hassle even if it's annoying or pointless for you to read 😁 Thanks to those who offered suggestions for removal, I look forward to trying them.
Everytime someone tells me I should have done whatever, yes I agree but it would be more helpful if you just came over to help me scrape and peel this crap off of my tires 🤣
Randomhead
Liked 3,699 Times
The year before I switched to tubeless on my gravel bike, I had 20 flats. I should have taken a picture of all the tubes, because I kept them to try to patch them all at once since tube glue goes bad once it's opened.
I was wondering why my rear gravel bike tire was losing air overnight and once I looked at the tire I realized I had dozens of little punctures. Filled it up with sealant and no more losing air overnight. It could have been one episode of hitting a lot of stuff, but I didn't notice it while riding. I keep thinking I should carry something to patch a larger hole, but I haven't needed it. I do carry a pump and tube though.
Likes For unterhausen:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
BB
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 672 Post(s)
Liked 417 Times
I've moved worn tubeless tires to non-tubeless wheelsets and latex or butyl tubes. No problems at all.
Likes For bbbean:
Quoted: 431 Post(s)
Liked 460 Times
Randomhead
Liked 3,699 Times
I don't think of this area as having a lot of goatheads, but I have seen some so I think you are right.
Quoted: 672 Post(s)
Liked 417 Times
I did wipe out the old sealant with a paper towel, but no problems from the little bit of sealant that didn't want to wipe out.
Quoted: 431 Post(s)
Liked 460 Times
Gotcha. I've got solid chunks of latex stuck on top of thin layers of dried latex on the inside of the tires. I guess it wouldn't matter with latex tubes as the solvent has already dried out.
Quoted: 116 Post(s)
Liked 374 Times
I run tubeless on both my Tesch S-22 with Boyd’s Altamonte rims and Continental 5000 S TR tires and my Ritchey Breakaway has a set of Fulcrum Zero Nites running Continental 5000TR tires, both converted with Boyd’s rim tape. I live and ride in Bahrain currently and the heat here seems to dry out the sealant much faster than back in Texas. I guess you can consider this environment severe duty. I initially started with Orange Endurance sealant in Texas but when that ran out I switched over to the sealant from Boyd’s. For me, taking care of my tires is just another part of bike maintenance. I have no problem taking everything apart, cleaning it, then reinstalling with fresh sealant. Since going to tubeless, this is just a part of my preventive maintenance for the wheels. In Texas I’d do this a couple times during the summer for each wheelset. The old sealant typically had some that had congealed but was mainly intact, just less of it due to leaks that had been sealed over the last month or so.
Now that I am in Bahrain, and after my first summer here, I noticed that the Boyds seemed to have a lot more congealed sealant and it was congealing in the span of about a month or so. So, I end up taking the tires off, removing the congealed sealant which is very easy to do, rinsing everything down and reinstalling with fresh sealant. Taking my time, total time for me for a pair of wheels is about 45 minutes, start to finish. For this most recent time, I switched back over to Orange to see if it can take the heat any better than Boyd’s.
With either sealant, it has never been a chore for me to remove the old sealant but maybe that is because it is not sitting in there for more than 4-6 months, now about 2 months. It comes right out with either my bare hand or a common kitchen sponge. If you are worried that removing the sealant will affect any previously sealed punctures, don’t be. Odds are that sealant that is sealing the punctures has solidified and won’t be removed when you remove any old sealant from inside. And even if it were to somehow remove the sealant plugging the hole, as soon as you inflated you tire, the sealant would immediately do its job again. I’ve never had this problem. In any kind of environment don’t expect to convert to tubeless and think you will have years of maintenance free wheels. If that is your expectation, stick to tubes.
Converting tubeless back to tubes is easy and requires removing the valve and a rinsing of the tire to remove the old sealant and wiping down with alcohol if you want get as much of the old sealant off as possible. I did just this with one of my bikes back in Texas. Since it wasn’t getting ridden but every 6 months or so, I converted back to tubes and have had no issues.
Likes For BMC_Kid:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
To answer your question (for my road/gravel bike: I do not track my mileage, probably a couple thousand a year. Roughly 60/40 paved/gravel. Pavement is often rough, gravel ranges from grade 1-3. Ran RH Extralight tires for 6 years with tubes. Got a couple pinch flats on 32s on potholes in the first year then went up to 35-38mm tires. No flats for the next 5 years until I went tubeless a couple years ago. Still no flats, though after a year they would not hold air long and weeped a lot of sealant. Stuck tubes in and still no flats.
I just bought a set of Challenge tires in hopes of finding a tire that rides as well and the RH Extralights but does tubeless better. But if there is any loss in performance, I’ll just go back to RH ELs with tubes. I find tubeless great in theory, but in reality it has made little difference on my bike.
Likes For Kapusta:
Quoted: 672 Post(s)
Liked 417 Times
FWIW, the rear tire of my road bike had a tacky spot this morning. Saw that I apparently punctured yesterday (25 mile anaerobic interval session), but sealant sealed the hole before it lost enough pressure for me to notice. Knocked out a quick 20 miles with a few sprints this morning, no additional sealant leak, no need to patch or maintain in any way. My faith in tubeless justified once again
