Grips for 23.8 Diameter Handlebars?
Bikes: There is always room for one more.
Quoted: 185 Post(s)
Liked 391 Times
I have a set of Velo Orange porteur handlebars that I want to use on a project bike. VO has a brake lever that will fit but their grips only come in 22.2 diameter. I'd prefer a cork or cork blend grip but I might not have the luxury of being choosy. Can an ESI foam grip stretch enough to go onto 23.8 bars? If so, that may be my fall back option.
Thanks for any info you all can provide.
Don
Don
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Good question. I’ve installed ESI grips on 22.2mm bars, and they were a very tight fit. But, they are very stretchy, so they might also install on 23.8mm bars. I have found that the only way I could install them, was to lubricate them liberally with WD-40. If you do get the ESI grips, I recommend the Extra Chunky.
Quoted: 185 Post(s)
Liked 391 Times
Thanks for the tips guys. I'll try to stretch some chunky ESI's onto the bars. If that's a no go, the basket weaves are a possibility. I may even try some thick bar tape or a double wrap of cork tape.
Don
Don
Quoted: 99 Post(s)
Liked 115 Times
Quoted: 586 Post(s)
Liked 612 Times
If you haven't yet, you might also reach out to the folks at VO. They seem like a helpful bunch and they might have the perfect solution for you. I'm sure they get feedback from people who've used those bars.
