Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
UCI Reach limit extends to 10cm from 01/01/23
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 11-25-22, 07:50 AM
m@tty
Quoted: 28 Post(s)
Liked 34 Times in 21 Posts
Looks like the UCI have seen sense and amended the rules.
just saw a post on the new ruling onVelobike Instagram
m@tty is offline
Likes For m@tty:
Old 01-05-23, 05:06 AM
RobertPaulson
RobertPaulson's Avatar
Bikes: Dolan DF4, Tarmac SL7
Quoted: 12 Post(s)
Liked 10 Times in 9 Posts
Link
they also increase the max angle to 30deg, praying mantis becomes legal again! (if you can get your height and pad position sorted right)
RobertPaulson is offline
Old 01-05-23, 08:31 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
without significant changes to the 10cm rule (pads to tips) the 30° is nice, but doesn't change much, especially now that you can't push the pads far up towards the end of the extensions.
Morelock is offline
Old 01-05-23, 01:48 PM
RobertPaulson
Quoted: 12 Post(s)
you can go 140mm now (if you are tall enough), 5cm width (up from 4cm) on the extensions also lets a decent bit more of a fairing effect. nothing mindblowing but it is going to make people faster
Old 01-05-23, 02:11 PM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
yeah, I mean every bit is nice, but even the tallest guys aren't going back to mantis, and they made it pretty impossible to do what Ganna / Archibald were doing before to "cheat" the rule, so if you wanted that setup, it's a net negative imo from 2022.
Morelock is offline
Old 01-09-23, 10:37 PM
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 385 Post(s)
Liked 180 Times in 102 Posts
Could you explain to a aero bar newbie?
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
carpediemracing is offline
Old 01-10-23, 11:16 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
which part?
Morelock is offline
Old 01-10-23, 04:29 PM
carpediemracing
Quoted: 385 Post(s)
which part?
lol I realize now it's probably all of it.
So the thing I understand is that you want your hands up to your face, but your arms had to be almost level. So there must have been some workaround for Ganna etc to get their hands higher? I don't know how the new rules affect the "hands up to face" bit.
Old 01-10-23, 05:33 PM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Without going too deep into the nuances
Before 2023 - 10cm mid pad to the tip of the furthest point of the extension (or shifter, and if a shifter is installed, they measure at the tallest/furthest *possible* position) With a maximum pad angle of 15° - In practice this restricts the mantis position because the middle of the pad very quickly reaches 10cm to the tip of the extension just do to how an upturned extension would pivot, and on 99% of commercial aerobars the pads are in a fixed mounting area. (generally above the base bar more or less)
So if you look at the original Carbon Wasp bars Archibald used, or the 3d Printed ones Ganna has been using, the pads actually mount much, much closer to the tip of the extension. This effectively let them significantly "raise the angle" of the extension to a more mantis' like position than what "should" have been possible, at the expense of you having your armrests closer to your wrists than your elbows. (There is a WC photo floating out there somewhere of Archibald where you can actually see he has padding in the sleeve of his skinsuit and is using the "flat" part of his custom aerobars behind where the actual pad is mounted as a support to game the system.)
Now, it's not as simple as "more mantis more faster" but, for guys that have tested and it is...it's obviously a big advantage vs. guys without access/willingness to go to those extremes.
2023 rules address this somewhat by having defined area's where the pad sits in relation to the extension, ie the gap has to stay wider, which enforces the distance from pad to extension tip "more fairly" (at least for now in theory)
Morelock is offline
Old 01-10-23, 10:28 PM
carpediemracing
Quoted: 385 Post(s)
thanks, that clarifies things.
Old 01-11-23, 08:56 AM
topflightpro
topflightpro's Avatar
Quoted: 1852 Post(s)
Liked 679 Times in 430 Posts
CDR, are you planning to do pursuits? If you are just doing 500s, you should be fine with just drop bars.
topflightpro is offline
Likes For topflightpro:
Old 01-13-23, 10:05 PM
carpediemracing
Quoted: 385 Post(s)
No pursuits, to answer here.
Old 01-19-23, 09:48 AM
topflightpro
In that case, don't bother with aero bars. Just work on your drop bar starts.
