My experience learning how to adjust the front and rear derailleurs
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Spent many hours this week learning and working on adjustments... Was going to give up after the first day because I was having such a hard time. Stressed myself out trying to find a LBS (there are none within 45 minutes of me so I don't know where to go).... Spent more time learning and finally figured everything out! I feel so proud of myself!!
But kind of embarrassing... The last thing I needed to figure out was indexing. I couldn't do it because I needed to turn the barrel adjuster clockwise, but it was already turned as far as it could go...
Couldn't find anything helpful online (trying to google if my cable was too tight). Was ready to unclamp and loosen the cable...
Finally, this morning, I took a look and realized the bike has TWO barrel adjusters 😳😅. None of the videos or articles mentioned anything about two barrel adjusters (maybe assume we already know that???). I had been only using the one near the rear derailleur, but I vaguely remember earlier this week playing around with the one near the handlebars. I had that one turned counterclockwise all the way. Indexing was quick and easy after I adjusted it 🤣🤣🤣🤣
When you reanchor the cable, the cable should be taut but not super tight, especially for the rear. It shouldn’t be like a guitar string but you shouldn’t be able to pull it away from the frame much either. You can now make slight adjustments with barrel adjuster. Shimano, in my experience, works best with a little more slack than SRAM. The front derailer cable will be also be tighter than the rear for both.
Finally, once you have most of the construction stretch out of the cable, you won’t experience much more cable adjustment over time. I shorten that initial stretch by pulling the cable up tight and shifting the system without pedaling. I shift 3 to 4 gears a few times and check the cable tautness. It is usually quite slack and I readjust. This significantly decrease the amount of adjustment I need to do.
Stuart Black
Stuart Black
Liked 4,222 Times
Feel good about figuring out the problem on your own. You did well and any thing I’ve said above is only minor quibbles that aren’t necessary but might make you life easier in the future.
Stuart Black
Stuart Black
