Why some road bike manuf. put rear brake cable guide on the Driveside?
GranitCurbVia53x11Sprint
Bikes: Cervelo R2.5 Campy Record 10, Dean Ti 'Cross, Merlin Agilis (road), Litespeed Obed (mb), Basso (ss/fixie)
Specialized, Trek, others...... are putting the rear brake cable guide on the drive side of the top tube (near the jhad tube) instead of the taditoional non-drive side.
This allows a clean cable line from drive side to non-drive side under the top tube, but it also forces the right brake lever cable to do a sharp bend towards the cable guide by passing the housing to the drive side of the head tube....
WHY? Is this just suddenly fasionable or is it actually a cleaner cable line?
Large Member
because running the rear brake off the left lever makes more sense.
especially if you ride a motorcycle too.
sheesh.
sheesh.
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
Does it eliminate some cable/frame rub on CF bikes?
MARGINALS
Bikes: 09 Tarmac Pro SL / Sunday BMX /
Bikes: Custom Custom Custom
motorcycle riders, aussies, kiwis, sheldon brown.
If you think about it, your front brake does most of your stopping. Your right hand has the most power, dexterity and control. You would want your better hand to do your braking. This obviously only applies if you were right handed.
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
^I've thought about this a lot lately. I've come to the conclusion that it doesn't matter. After a few hours on the bike, your left hand will become just as good as your right at braking.
There are two scenarios (in the US) where it makes sense to flip it.
One is so that you can make hand signals and brake at the same time, but that's not the safest idea anyway, so throw that out.
The second is if you ride a motorcycle as well, and don't want to get confused between the two. In this case, I would say it makes sense to flip them. The rest of the reasons Sheldon gives (I don't remember them all right now), I don't really agree with.
In order to make good, smooth cable runs on most (new) bikes, you are almost forced to run the front brake on the left. The angles can get too sharp otherwise.
My .02 on a contentious issue.
Bikes: TREK 1000c
This is just an observation and may have nothing to do with the real reason ...
When I'm working on a bike (cabling everything up and such), the rear brake cable (along the left side) is almost the only thing that I can't rig up exclusively while standing on the right side of the bike. I generally have to walk around the bike stand to do that one piece of cable up/ setup.
The rear brake cable routed along the right side would alleviate me from having to go to the other side of the bike.
that's just me thinking out loud ...
Formerly Known as Newbie
There's really not that much power, dexterity or control involved in braking IMO. But if you have to downshift at the same time, with the same hand, things get more complicated. That's why I think it's preferrable to have the rear shifter and "redundant" brake lever (rear) both in right hand side.
--J
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Bikes: Norco Monterey with a road conversion kit used in the summer and stock parts for the winter.
I have to say that I also run front/right. I like it much, I just do it's hard to explain other than all the reasons given above. Down-shifting is a bit more tricky, but only slightly (with STI that is). But I got used pretty fast to stop braking 1/2 a second to down shift in the middle of my braking motion. Would I go back? Probably not. But I say.. try it out, see how you like it... at worst you only wasted a couple housings. Not the end of the world unless you're using super high end titanium housings
Isaias
Bikes: Ridley X-Fire (carbon, white)
Quoted: 7 Post(s)
For me, especially when racing, I prefer to be able to shift and brake simulateously. It's a little difficult to do if both are actuated by the same device under control of only one hand.
https://www.sheldonbrown.com/brakturn.html
Which Brake Which Side?
There is considerable disagreement as to which brake should be connected to which lever:
- Some cyclists say it is best to have the stronger right hand (presuming a right-handed cyclist) operate the rear brake.
- Motorcycles always have the right hand control the front brake, so cyclists who are also motorcyclists often prefer this setup.
- In countries where vehicles drive on the right, it is common to set the brakes up so that the front brake is operated by the left lever.
- In countries where vehicles drive on the left, it is common to set the brakes up so that the front brake is operated by the right lever.
