Carbon Seat Stays - Aluminum Frame??
Quoted: 155 Post(s)
Liked 26 Times
Hi all. In my search for an appropriate aluminum frame for a CRIT bike, I'm seeing several older aluminum frames (my preferred material) with carbon seat stays. I was unaware that some manufacturers built frames in this way. I imagine for the eight savings. But are these decent frames? Does the combination of carbon with aluminum at the seat stay cause problems over time? I watched a video on YouTube where an English gentleman who repairs carbon frames - he is obvioulsy an expert on all things carbon - was critical of combining carbon with anything aluminum. So, I thought I'd throw a query onto this forum to see what you experts think: is a good aluminum frame with carbon seat stays a wise investment? Or should I be weary? Thank you!
Quoted: 2490 Post(s)
Liked 2,960 Times
A few manufacturers offered aluminum frames with carbon seat stays back around 2005 to 2008, approximately. The claimed advantage, at least from what I remember reading, was that the inserted carbon sections would absorb road shock better than full-length aluminum. I suspect it would take a very sensitive instrument to detect any difference. A BS detector, on the other hand . . . .
I also read a suggestion that the real advantage was that it simplified the building process for constructing rear triangles for the various different sizes of a frame model.
There have been a few first-hand reports of the epoxy failing at the joins, so that's something to take into consideration.
In any event, bikes with inserted carbon stays vanished from manufacturers' catalogs almost as quickly as they arrived. Maybe because word spread that there was no performance or comfort advantage for the rider, maybe because manufacturers were having to replace frames under warranty at rates above their comfort level.
Likes For Trakhak:
Quoted: 1461 Post(s)
Liked 1,486 Times
This was common on higher end bikes in the early-mid 2000's. There were also bikes in that era that that had carbon tubes on the main frame triangle, but still connected with aluminum lugs at the bottom bracket, head tube, etc.
I'm not sure there's anything inherently concerning about this. There are current bikes on the market that still combine aluminum and carbon on forks/steerers. I think bike manufacturers moved on from combining carbon/aluminum on frames because they figured out pretty quickly how to build the whole thing out of carbon.
Quoted: 155 Post(s)
Liked 26 Times
There were definitely lugged carbon frames in the early years. I believe that's how the who carbon thing started out. The carbon top tubes, seat stays, and such were lugged into light aluminum. Wasn't Kestrel a pioneer in that field?
So, regarding my initial inquiry, I guess my main concern is whether older aluminum frames with carbon seat stays are SAFE nowadays to race at higher speeds, under some stress.
Thanks again!
Thanks again!
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
The company made other products as well, such as antenna masts and windsurfer masts. They were trying to launch a line of snowboards at the time. But the Trek contract was their biggest money maker.
I enjoyed my time there and learned a lot, although it didn't develop into a career for me.
I still have a few carbon pieces from them. When a part did not pass QC inspection for whatever reason, it would be scrapped, and I got permission to take some of these home.
Liked 1,486 Times
I think your main challenge with bikes from this era will be the extremely narrow tire clearances.
Quoted: 3957 Post(s)
Liked 7,310 Times
My wife had an aluminum Orbea with a carbon rear triangle and carbon fork. It was a nice bike for its day.
Quoted: 155 Post(s)
Liked 26 Times
Ah, tire clearance. I like running 28's. I'm wondering if most of the Italian frames, pre-2010 (post 1998) will allow that? Bianchi's in particular.
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
Likely depends on model and even rim width. But likely may only go to 25.
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
In some cases, your limitation might be the brakes rather than the frame or fork. I can't get a 28mm tire on my #1 road bike because there isn't enough clearance under the arch of the rear brake caliper (Campy Record).
Quoted: 1743 Post(s)
Liked 1,281 Times
I have a Masi Gran Criterium S (2005 or so) and it is AL with CF fork, seat stays and chain stays. it's a size 58 with Dura Ace 10 sp and it weighs a little over 17 lbs w/Speedplay pedals. I love this bike but unfortunately it is too big for me. I ride a 55 w/55TT. It was a present to me from my GF so I've kept it.
Likes For bruce19:
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
I have never owned a Bianchi, but I do have three Italian racing bikes from that time period (1995, 2001, 2008) and none of them will take anything close to a 28. Only one of them will even take 25s.
pan y agua
Quoted: 1451 Post(s)
Liked 731 Times
Carbon itself doesn't "wear out" over time, so the age is irrelevant in terms of structural integrity. I also don't recall inherent issues with the jointing of carbon/aluminum that caused failures, but someone with more expertise than me could weigh in on that topic. The main concern I'd have with any used bike (especially carbon) is ensuring that there is no damage. If it were me, I'd have a qualified shop inspect the bike before racing it. I'd recommend doing this for any bike regardless of age and material.
its not only the carbon fiber, but the matrix, and also how the carbon fiber was joined.
Most notable and catastrophic example is the titan sub that likely weakened and failed with repeated stresses.
I wouldn’t necessarily shy away from an older carbon frame, but that said, why buy an older technology, that proved to have no real advantages, and has the potential to have problems from joining the two different materials, and at this point may be just worn out. Unless someone was giving it to me, I’d look at a newer all aluminum frame that can be had pretty cheap, or all carbon for a bit more money.
You could get lost and die.
You could hit a tree and die.
I have a 2009 or 2010 Salsa Mamasita mountain bike with carbon seat stays. The connection point between the carbon and aluminum is painted over and totally seamless to where I can’t tell exactly where the two materials connect. If there was an issue I figured it would be easy to see as the paint would crack at the connection. I had the bike on the bike stand over the weekend washing it and it looks like new. No indication of any issues. This bike has not been abused but it is a mountain bike and takes more abuse than a road bike. As long as the frame was built properly it should not be a worry. I admit when I bought this bike I thought it was a cool feature but had the same concerns as you. Not so worried about it now given the age and the super hot TX summers in the garage.
Quoted: 769 Post(s)
Liked 1,748 Times
I picked up a used 2006 Cannondale Six13 which had a carbon top tube, downtube and seat tube attached to Alum lugs. It was a nice bike, but It was just a bit too big no matter what I did, I could not make it fit, so I sold it and got a CAAD9, which was a much better fit. I actually found the CAAD9 a better riding bike than the Six13, the Carbon really did not reduce the road buzz that much, so to me it was all hype. I never had any issues with the joints where the carbon\lugs met, but I only owned the bike for about 18 months.
Quoted: 432 Post(s)
Liked 461 Times
Since you're looking for a crit bike, I'd focus on frame geometry/handling characteristics and there really is plenty out there, vintage/used or modern, that will meet your needs. My perception is that alloy frames with carbon seat stays were designed for all-day comfort and not necessarily for crit racing, but that's just my perception.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
To the OP, chances are this frame is very outdated, and for that reason I wouldn't consider it a top choice for building any kind of racing bike. That doesn't mean it won't work as one though. As for the materials as a consideration alone, six of one/half dozen of the other.
It's like riding a bicycle
Quoted: 116 Post(s)
Liked 376 Times
My mid-90s Quattro Assi Team, aluminum with carbon seat stays. I got it and then promptly bought the blue QA Easton Elite behind it in the second photo which I rode all the time. A few years after that I got the QA Titanium and divided the mileage between the two but also put miles on other bikes (all steel) I had at the time and others to come over the years. I think I put only a few hundred miles on the Team with carbon seat stays. When my brother comes to town it used to be the only bike of mine that he could make fit since it was a compact frame. The QA Elite rode nicer even without carbon seat stays but that it probably due to the oversized tubing the Team has. It is too stiff for my liking, look at those chain stays! And when I got the Titanium frame, it ended up being even more comfortable.
I love my 2009 Cannondale Six 5 with its carbon rear triangle and fork. I've got around 7,000 miles on it and it ride in all types of weather. I don't see any reason to upgrade.
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
This was an economic compromise for a while. Then aluminum and carbon both evolved to a point where it no longer made sense (from a manufacturing standpoint) to continue mixing them. You could make a very good alloy frame that was as light as low-end carbon but less expensive and then make a full-carbon frame that was lighter than alloy but more expensive. So that's what manufacturers did.
Quoted: 1088 Post(s)
Liked 1,027 Times
My wife has a trek pilot aluminum with carbon stays and fork from around 2007, bought it for her knowing the ride quality vs cost at the time. I'd ridden a trek 2300 the year before they came out with carbon stays and were full aluminum, the bike was very rigid and I found it unsafe on bumpy corners, the next year's carbon stay 2300 was significantly better at riding through curves. However, cannondale at the same time was producing a very lively full aluminum frame that handled worlds better, and trek only ran the carbon stays a couple more years before going back to full aluminum frames that handled just as well as the carbon stayed version. Personally, unless you're finding one that's been through the wringer and has a wornout drivetrain, I'd have no qualms about racing one.
My Carrera from 2008 has no problems with 25c tires on velocity A23 rims, I suspect 28c would fit but don't usually run that big of a tire.
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
I am using 28s on a 2002 master with a flash fork and 11 speed SR but I only have a couple mm in clearance. The SR brakes had no trouble clearing the tire as long as the release was used on the brake lever.
