Pet peeves
Quoted: 5792 Post(s)
Liked 2,582 Times
Pet peeves
The biking season is winding down, so I think it's time to vent. What's your pet peeve here on BF?
Here's mine.
I bristle every time I see the word TENSION used, as in adjusting derailleur cable tension. You don't adjust cable tension --- that's determined by the spring. You're adjusting the LENGTH.
It bugs me, because I consider a clear understanding of how things work, key to successful mechanical problem solving.
It probably doesn't matter much regarding brake or gear cables since the job gets done either way, however it muddies the thinking in things like wheel alignment or building.
As I read those related threads, I keep seeing people focus on spoke TENSION and I wonder if it leads them to miss the point that you adjust the spoke's LENGTH, not its tension to bring the rim properly into position.
Anyway that's mine, what's yours?
Here's mine.
Likes For FBinNY:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Weird auto-correct or text-to-speech artifacts that make reading what should be a few simple paragraphs a bit of a challenge.
Examples:
The bind moggles when considering possible origins.
Examples:
breaker gear cables
wheel alignment or we'll building
despoke length not its tension
Likes For gearbasher:
Quoted: 427 Post(s)
Liked 700 Times
Riders flying by with no announcement--inconsiderate and dangerous for both riders. As this is in "mechanics", guess it would be ?? which obviously need specifics, but none are supplied.
Liked 2,979 Times
political views & assumptions that dictate one's brand of choice.
-Oh Hey!
-Oh Hey!
Quoted: 332 Post(s)
Liked 742 Times
Mine would have to be run-on sentences like when someone blathers on and on with no punctuation in one long paragraph how am I supposed to read all of that and offer suggestions when I can’t even decipher the steps you’ve taken so far a few bulletpoints can go a long way ok I’m done carry on
Likes For bboy314:
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
Seeing riders with, in order of most common, (1) too low tire pressure, (2) something brazenly creaking in the drive train, (3) all black clothing in the dark w/o lights.
Liked 2,979 Times
Likes For Troul:
Likes For Kai Winters:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
Gravel talk. Gravel, gravel, gravel....
Likes For RB1-luvr:
Quoted: 6972 Post(s)
Liked 10,968 Times
My “pet peeve” is posts in which people complain about things just for the sake of complaining.
Likes For Koyote:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
My pet peeve is having to scroll through a lengthy quoted post including several photos to see a reply. Especially on post number two, when we've just read the OP.
Likes For andrewclaus:
Quoted: 2604 Post(s)
Liked 1,933 Times
Incorrect or questionable information posted as truth and defended ad infinitum.
No bonus points for pointing out the lack of italics in the preceding.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Referring to a single sprocket as a "cluster," e.g.:
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
Quoted: 3513 Post(s)
Liked 2,927 Times
Luckily I'm pretty easy-going, so my list is small:
--Handlebars with the brake levers pointing skyward at 45 degrees or greater;
--Saddles pointing downward 25 degrees or greater;
--Triple cranksets on road racing bikes;
--Barcon shifters on road racing bikes;
--Bells on road racing bikes.
--Tires greater than 25mm wide on road racing bikes;
--Dirty road racing bikes;
--90 degree or greater stems on road racing bikes;
--Seeing bikes that are obviously on their face too big or too small for riders, based on seat post height;
--Frayed cables;
--Rust;
--People who size cable housing way too long, so it forms hideous, friction-inducing loops fore and aft;
--Complaints that certain small things are too expensive (cables, bar tape, rim strips);
--Corollary: People using the wrong tool for the job, because they’re too cheap to purchase the right tool;
--Corollary: People who work on their bikes upside-down because they’re too cheap to buy a stand;
--Toe strap ends looped through the buckle;
--Quick releases, hub labels and rim/tire labels on the “wrong” side;
--Neglected bikes;
--The thought that properly cleaned and lubed chains are still “dirty;”
--People who don’t match their bar tape to their saddle color;
--Road racing tires colored anything other than black; Tan sidewalls are fine;
--Using the phrase "Tri-color" to refer to Shimano 600 Ultegra parts;
—People who write “tension meter” when the more accurate word is “tensiometer.”
--Black road racing components.
--Frayed cables;
--Rust;
--Neglected bikes;
Likes For smd4:
Quoted: 6196 Post(s)
Liked 4,810 Times
I know it got coined as a term back in my younger days. And even many magazines have called them by that name, But the thing that make me wince when I hear it is...
Brifter!
I didn't like the sound as it rolls off the tongue then and I don't like it now!
Brifter!
People that don't read the original post thoroughly and post things that don't pertain to the question. Or, offer advice and ask questions that the OP has already posted saying he/she had already tried doing those things.
Quoted: 2338 Post(s)
Liked 2,827 Times
people who ask for input and then get upset when the input does not affirm their thinking
Likes For squirtdad:
Liked 2,927 Times
Likes For smd4:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 1608 Post(s)
Liked 2,216 Times
I know this is a controversy due to the common usage not being specific of the definition, cog vs sprocket. The definitions indicate a sprocket is a subset of cogs with the specific feature of the teeth engaging into a component like a chain and not another cog.
Likes For SJX426:
I am potato.
Quoted: 1789 Post(s)
Liked 1,630 Times
Road handle bars rotated ~180 degrees. Obviously the owner should've bought an Oma/Opafiets if such a thing were available. But, shopping cart action & self reinforcing brake levers? Come on...At least Fred right.
Wait! Fredrite sounds like the name of a commuter bike company. I call dibs!
Car dependency is a tax.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Likes For Rolla:
