Upgraded hubs exactly why?
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 336 Post(s)
Liked 782 Times
I’ll freely admit to upgrading things on my bike for absolutely no good reason other than “ that looks cool” but I’m hardly alone in this. So my question being: what would be some legitimate considerations on why one would consider going from DT Swiss 350 hubs to 240’s? Who or what would be the target rider, situation or environment that would actually see a gain or benefit with such a change?
Quoted: 6972 Post(s)
Liked 10,970 Times
Likes For Koyote:
As a stand alone upgrade that one makes no sense. If your 350 is worn out, rebuild it and add in the Ratchet, they last forever though, so unlikely it is worn out. Can’t justify the 40g weight savings, just not enough. The EXP Ratchet just isn’t a big enough difference either.
Now if you are going to a lighter wheelset, like a carbon wheelset, and it comes with 240s, I can see that, but that’s really only way. I’ve got the new 370 I upgraded to 54t, so basically I have a upgraded 350 now (370 has 18t, 350 has 36t) and I have thought about carbon wheelsets laced on 240s, but as my 54t set is not EXP, I could not swap it in, so that’s a con.
Quoted: 426 Post(s)
Liked 274 Times
If you are buying a brand new wheel then it could make sense depending on what is important to you. I would not tear down a perfectly good wheel to install new/upgraded hubs.
Quoted: 4227 Post(s)
Liked 2,488 Times
There is no legitimate reason to upgrade hubs unless your hub is damaged and beyond repair.
Quoted: 2333 Post(s)
Liked 2,097 Times
Rear hubs that sound like angry bees don't need upgrading, they need regraded........ by a steamroller.
Liked 2,097 Times
Quoted: 4416 Post(s)
Liked 4,871 Times
Liked 2,097 Times
Likes For GhostRider62:
Liked 10,970 Times
You’re right – – I violated my own rule, which is to not judge other people’s purchase decisions.
If someone wants all the quality of the DT 350 hubs, and wants to save a little bit of weight, then the DT 240 hubs are perfect. The weight is inconsequential, especially at that location… But there’s no accounting for taste.
Likes For Koyote:
Quoted: 18424 Post(s)
Liked 15,579 Times
Instead, spend the money on call girls from Dubai.
Quoted: 3514 Post(s)
Liked 2,927 Times
Likes For smd4:
Liked 2,488 Times
Liked 2,927 Times
Liked 2,488 Times
Liked 2,927 Times
Liked 2,097 Times
I want bearings that are smooth, low friction, and last 30,000 miles not 2,000 miles. Steel. NTN or NSK with LLB or VV seals.
Do you enjoy tearing hubs down on a tour? I do not nor do I like the feeling of ground up glass in SRAM/Zipp crap bearings
Liked 15,579 Times
Liked 2,927 Times
Quoted: 1109 Post(s)
Liked 1,200 Times
Liked 1,200 Times
You accurately stated "it makes no sense to me..." (emphasis added). that's all that matters to you, but it matters nothing to anyone else. But I know that you know that.
Liked 10,970 Times
You're absolutely correct there's no accounting for taste. This is usually said with the implication that the other person's taste is bad. Mea Culpa - people who like stuff I don't have bad taste. And, I've been guilty of getting "upgrades" just because I wanted what I thought was better or the best of something, just because it's the best. Like Sram Red, Campy Record, Shimano Dura Ace. "I've alway wanted to have a top of the line bike, so now I'll get one" sort of deal. No rational functional reason. Except maybe during my weight weenie phase when I was trying to build a 15lb bike and would spend inordinate amounts of time hunting down parts to save 30 grams here and there to get that last pound (I think I ended up with 15.3 or so). Although I worked hard to do it at bargain prices, it was still a waste of money by any objective criteria. But by my own subjective criteria ("best", "cool looking", brand name cachet, etc.) it was totally worth it. I still think so; I enjoyed the project, no regrets, no embarrassment. But BTDT
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
I have nearly 30K miles on the original bearings in my Shimano RS80's.
I have had no problems with them.
I routinely pass my riding buddies when coasting downhill (neither I nor my bike are heavier than they).
I have a 10 speed (2x5) from 1976 with the original bearings in Shimano 600 hubs. Again, no problems.
No accurate idea how many miles, didn't have an odometer, but I commuted on it for 6 years in addition to weekend rides. It was my only ride until I bought my "new" bike in 2006.
If you feel that better hubs or bearings make a difference, I have no problem with you buying whatever you like.
I have friends who are 20 pounds (or more) overweight and will spend thousands to get a bike 3-5 pounds lighter; THAT strikes me as silly,.
