Saddle Raise/Lower Versus Saddle Fore/Aft
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
I started the thread below which leads me to my question in this thread.
https://www.bikeforums.net/fitting-y...l#post22645697
Within that thread I mentioned, for a variety of reasons, that I moved my saddle forward by 15mm, or ~ 6/10th of an inch.
My question is, approximately how far upward should I raise my seat post, if any?
Thanks.
Glenn
Thanks.
Glenn
more daylight today!
Quoted: 5133 Post(s)
Liked 3,617 Times
By the amount of change that makes from where you sit on the saddle to the pedal when furthest away from that point.
However the ideal saddle distance probably has more margin of tolerance than the few millimeters you changed. If you can do drafting or cad, it's pretty easy to model.
If you notice a decrease in power or something sore going on then you'll know there is more to do.
Quoted: 118 Post(s)
Liked 88 Times
I'm confused, which is not unusual. I'm not sure if I'm thinking about this correctly.
If I move the saddle forward, does that, by itself and all else equal, increase or decrease effective saddle height?
If I understand correctly, it reduces effective saddle height.
Thanks.
Glenn
Thanks.
Glenn
What is important is the position of your hips relative to the cranks and it is different for everyone. I want to have my weight on the saddle so that when pedaling and in the saddle as much leg power as possible goes into the forward motion of the bike. I need to adjust the fore and aft position and the height of the saddle to get into the sweet spot for me and it is different for every bike I have owned. I know the distance from the front of the saddle to the rear of the handlebar stem and that is a starting point. Particularly when pedaling up a hill it is obvious to me if the saddle position is not optimal and I will take hex wrenches so I can make small adjustments as I go with a new bike or a new saddle.
Quoted: 118 Post(s)
Liked 88 Times
So, if I move the saddle forward, does that, by itself and all else equal, increase or decrease effective saddle height?
Thanks.
Glenn
Liked 3,617 Times
Yes it typically will reduce the effective saddle height. So you might have to raise your saddle. But if we are only talking about silly little milimeters, then your new position with respect to the BB might have your body feeling that it needs a different saddle height altogether that is disproportional to the mathematical difference in distance.
So why not just try something and see if it works for you.
Quoted: 118 Post(s)
Liked 88 Times
Got to thinking I should try a new saddle and got a couple of loaners from the local Trek shop. When I put the 165mm on it was perfect on my sit bones, unlike anything before, but I had to slide back in the saddle to get exactly spot-on.
Tried the 155mm - no go. Back to the 165mm saddle and then forward 15mm. Ah, good. But then it felt like my weight on the saddle was lower than it should have been given the weight distribution on my pedals. Not equal support between the two when just cruising along flats with a few rolling hills thrown in for good measure.
That led me to the question of effective saddle height given the move forward and the feeling the saddle needed to be higher in relation to everything else.
I think it is disproportional to the actual mathematical difference. It has to be because the actual distances are so small. As you said, millimeters don't matter - until they do
My body definitely feels it. I think I'll raise it 5mm at first and see what I think (feel) and go from there.
I really appreciate your help with me thinking through all this.
Thanks again.
Glenn
OM boy
Bikes: a bunch
Quoted: 434 Post(s)
Liked 510 Times
If you're wondering of there's some mathematical formula/relationship between height and fore/aft - there might be for some 'Fit' systems. But really there are too many variables, even before considering the possible ranges in human physio for the elements involved. Saddle design (as relates to where one sits) will have a great effect. Then there's 'Why' ... Maybe because rider wants a light touch on the bars - or - rider is competing in events which call for constant, hard, quick, accels & decels - or - rider is setting for max power at a constant tempo of riding - lots of 'riding' variables.
Riders competing in 'crit' type riding, or track, or TT might find themselves better positioned 'forward', whereas a rider having to do a steady hard tempo over longer distance may find a bit more rearward position works best - a range. How does one decide? I find that if my riding style for the type of riding I do most, when power needs are required, finds me constantly moving forward on the saddle when I need to lay power down - I'll move the saddle forward in smaller increments, until I find a good balance between my fore and aft movements, during efforts.
Over the many years, I've come to my 'start' points, which find me going there when I first get on a new bike. Then I ride, and adjust over a number of rides, in small increments (3-4mm).
My 'std' measure point is different from some common measures used, like 'saddle nose setback'. But saddles have always varied, especially now with the large increase in variants - like the new 'power' type saddle which are quite a bit shorter overall. I use BB to sitzbones placement. I find where my sitzbones will be on the saddle, and that cross line on the saddle is (or was) 30.5 cm behind the BB (that MY number, most certainly diff. for others). 'Was', because recently, my increase in riding harder, more often and with fast groups, makes me come forward more often - the NEW fore/aft setting is 29.5 cm.
I believe many 'Fit' systems use hip/femur angle to pick a setback. But I think that can only be an approx. because accurately measuring the angle with precision is quite 'variable'. ANd who's to say that, at any angle measured, power production over a period of a few minutes is going to be the same as power production over a longer period, like an hour of drilling the ride?
If you've made a 15mm change - that quite signifcant - I would make height adjustments in smaller increments, ride for a few days/rides and evaluate. Nothing wrong with going a bit further ('up' in your case) to know when you've reach a discernible 'limit' point. The assumption being that your current 'height' has worked well for many prior rides and was the 'sweet spot'.
Your leg length differences are as affected by Height as setback - maybe even more. It sounds like you've found the saddle which works for you. SO your current saddle height might actually be the 'spot' also. Experimenting, in small changes of saddle height ALONE/ONLY will point that out over a number of rides. Any Change will always feel 'different' - often not so great, but given time a change might be effective.
Experiment.
Ride On
Yuri
Experiment.
Ride On
Yuri
Likes For cyclezen:
just another gosling
Quoted: 3589 Post(s)
Liked 1,576 Times
Ah. Never adjust reach by moving the saddle. Change the stem length for that. You want the saddle where it should be to give you good balance on the bike, little weight on the hands, no feeling of falling forward. Then see what stem length you need to get reach correct. My bike fitting primer is here: https://www.bikeforums.net/21296948-post3.html
Go through the steps from top to bottom, in order.
Results matter
Results matter
Quoted: 118 Post(s)
Liked 88 Times
My biggest problems are that I'm old, tall, major clyde, top-heavy, and not that flexible. If I ever lose the clyde and gain the proper flexibility I will definitely need/use a longer stem. I gotta get there first. I was making major progress. You may have read in one of the two threads that I've been off the bike for a year and recently started riding again around August 1st. 7 months of off season and laziness and 5 months due to a serious, unrelated calf injury.
I really am grateful for your help.
Thank you.
Glenn
Likes For GAtkins:
Liked 1,576 Times
You gotta do whatcha gotta do. Good for you!
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 118 Post(s)
Liked 88 Times
Ok, so I did another 18 miles last night and started with the saddle up 10mm. Immediately felt the saddle was too high, both riding and with a foot down at stops, and the bike was more twitchy - left toes had started the hot foot and numbness.
Stopped mid ride and lowered the saddle 5mm, so that it was up a net 5mm from the start of the ride. Sweet spot! Left toe numbness subsided. Bike still twitchy, but I'll get used to that now and solve it later with a longer stem as my fitness/posture improves. When I rode a couple of nights ago before raising the saddle (but after having moved it forward 150mm), the muscles right above and in front of both knees felt overworked after the ride and when I woke up the next morning.
This time, nothing abnormal hurt. Just felt like a slow, old guy had gone on a bike ride when I got up this morning. I'm going to leave it there for a while.
Glenn
Glenn
Liked 3,617 Times
Most of the times I've felt something that I'd describe as the bike being more twitchy after a change is was simply just that it felt different. And after 3 or so good rides after the change it no longer felt different. So don't be so adverse to "twitchy" unless that is something that never goes away after many rides.
Likes For Iride01:
Quoted: 118 Post(s)
Liked 88 Times
Glenn
Thanks.
Glenn
Thanks.
Glenn
Adjusting the tilt of the saddle also affects the measurement, at least if you measure from the sit-bone position to the crank axis or pedal axis.
I'm not sure what you mean by effective saddle height. I use leather saddles which sag a little when I am on them, so if I fine-tune height for comfort there will be a little rise. But it I duplicate that height after the other adjustments I usually am done, unless a new problem arises (i.e. pain in another spot).
Glenn
Glenn
Not all of these "final" adjustments are saddle height. There are fore-aft as you know, tilt up and down (aka "pitch"), and rotation of the saddle around the seat tube axis ("yaw"). In general I try to get balance on the saddle first (fore/aft), then lack of sliding (pitch), lack of lateral pressure (yaw), and leg/hip comfort in extension (saddle height). Then go back and do it again when I find I screwed something up!
Quoted: 118 Post(s)
Liked 88 Times
I've done a lot of in-ride adjustments, but I try to keep them very small, 1 mm if I can - I want to sneak up on the good spot, not adjust back an forth circling around it. Usually these adjustments are driven by abrasion pain between the top of the thigh and what's in between them, balanced by perineal pain if I go too high and make my hips rock, or knee pain if I go too low and have too much pressure in my patella. And when I do find a sweet spot, it will need reconsideration after perhaps 10 or 15 miles. For me training up for distance is equal to fine tuning the saddle to a point which is tolerable over that distance. But this is why I said before that I am a little in doubt of your term "effective saddle height." What makes a given saddle height be in the range which is best, is the comfort of the bike in the riding you need or want to do, not any mathematical ideal, thought such calculations make a good starting point. One reason they make a good starting point is, that point is repeatable.
Glenn
Ok, so in your terms 98% of the tuning I do is about "effective" saddle height.
Quoted: 118 Post(s)
Liked 88 Times
"What makes a given saddle height be in the range which is best, is the comfort of the bike in the riding you need or want to do, not any mathematical ideal, thought such calculations make a good starting point."
I'm confused by that reply.
Quoted: 118 Post(s)
Liked 88 Times
We may be talking about the same thing. My original question was to make sure I understood that if I move the saddle forward that the height of the seat post would go down. It wouldn't actually go down, but would effectively go down because I was closer to the handle bar. In other words, it would subjectively appear/feel to have gone down.
Therefore, to keep everything in relative proportion, I would actually have to raise the height of the seat post by some length. Once I had the relative positions and movements understood, I then raised my saddle by 10mm, which was too much. So I then lowered it by 5mm mid-ride (so that it was only up 5mm from the beginning of the ride). That amount was much better. Leg/calf muscles up and down felt well balanced. None more or less sore than the others. When only the saddle was forward by 15mm, my lower quads, right above my knees were abnormally stressed.
Your suggestion of making changes by a mm or 2 might actually be a better way to do it. I didn't know if I could feel the difference of a 1mm to 2mm change, but I could sure feel the difference in a 5mm change up to the seat post. Seems like we're both making initial adjustments somewhat related to actual, measured geometry and then fine tuning things by feel.
Thanks for your comments.
Glenn
Glenn
Quoted: 354 Post(s)
Liked 286 Times
All good stuff. Thank you. I had seen your great work before and will review again.
Glenn
Glenn
Likes For oldbobcat:
