Thinking about winter
#51
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
I don't like these transition weeks. Even high 40s feels freezing so I overdress and deal with being a bit too warm. By February I'll be used to winter and high 40s will feel great.
#52
Pennylane Splitter
Bikes: Yes
Quoted: 1804 Post(s)
Liked 1,446 Times
lo-mid 40f's is a pretty normal low here in winter in the Los Angeles area. If you're in an area that's a little more open (way from heat-radiating buildings) then it'll drop a little lower into the high 30F's. Actually I like it at those temps as it keeps the rest of the folks indoors and off the local MUP during the week. A little chilly for the first 10-15 minutes, but after that its a nice quiet morning ride.
#53
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2587 Post(s)
Liked 5,649 Times
SoCal is pretty close, particularly near the coast. Winter highs are typically in the mid 60s with lows in the 40s. Summers are also pretty mild with highs in the 70s and 80s.
The only weather downside are our May Gray and June Gloom overcast months.
From this morning's ride:
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#54
In winter I play squash, which is a very good workout, and which I can easily play without a partner when necessary. I also enjoy skiing, and look forward to when it snows, we have our ski trips already planned. We also have a new condo in Honolulu, which is very pleasant in the wintertime, but with work and kids in school, it’s hard to get out there very often. I bought a bike on our last trip out there, but it’s been hanging in the bike storage for the last 15 months.
Likes For Biker395:
#56
Real winter just started today. 3 inches of snow and more on the way. It had snowed earlier in the month, but it melted in the morning. Now the temperature is well below freezing.
#57
Quoted: 5224 Post(s)
Liked 3,585 Times
#59
Quoted: 12195 Post(s)
Liked 1,497 Times
I got some Aerotech cold weather cycling gloves. If the weather is in the 30s, my hands still get cold, but it's tolerable. I am going to order some cold weather cycling pants soon. I have Sugoi jogging pants, but even with long johns, my legs get real cold, and then my feet start cramping. Speaking of feet, I got some booties. They helped, hoping the pants fix the foot cramp problem. I found about all this yesterday, the weather was in the upper 30s, close to 40.
My resistance exercises are going well, except for my right triceps, which I cooked. Can't train like I used to, not at all sure how to stop doing that.. Talked to my Doc today about getting PT for it.
I am always looking for new exercises, found one yesterday, the Copenhagen Plank. You lie on your side, put your higher leg on a stool, and then do a plank. You lift yourself into position with just that upper leg.
I am getting a clever hamstring exerciser for Xmas, it's only 26 bucks. It's just a bar to restrain your heels, and a thing you put under a door to anchor them. You then lift your entire body with the hamstrings. Sounds brutal.
#60
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
So, credits to an acquaintance who works out at our rec center. He noticed that I run there regularly and suggested that I do running-specific strength training.
I took his advice. I’ve been doing that several times a week for the last month and I’ve noticed that I’m more comfortable running, able to run much longer and last night I did 100m “strides” or accelerations and was very comfortable even sprinting as fast as I ever recall running. So, props to his insight.
With the cold, dark and inclement weather, I’m going to be following a training plan for 10K runs, with plenty of strength training as my cross training. I will try to fit in some rides when we have the occasional nice day.
Otto
Otto
#61
Using a Wahoo Kickr Core. I've thought about this and came to the conclusion that I'm just not mentally strong enough to ride outside in winter alone, at least not fast. For sure, all the clothes and gear make it harder as does the wind and poor road conditions. Rouvy though, has me riding against others and it pumps me up. Outside, I'm always alone winter or summer, just no one around to ride with so I need to find my own motivation and I'm not always great at that. Give me an hour long Rouvy ride trying to pass those ahead and fighting off those behind and I'm pushing it hard.
#62
Quoted: 4418 Post(s)
Liked 4,873 Times
I just don’t enjoy winter riding here in the UK. It’s simply too cold, too damp and a generally miserable experience. I don’t mind the cold (I’m a keen skier) but I hate the constant damp. Plus our roads are dangerous enough without adverse conditions.
So I ride on Zwift and go on long ski trips instead.
#63
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
What does your community transportation department use to keep the roads clear of ice? Here in southern Ontario, Canada our roads get caked in salt which is good for melting through the surface of ice but brutal on bikes. If you do ride a bike on a regular basis over the wiinter you will need to replace most of the parts or the entire bike in a few seasons as the corrosion destroys all metal parts on the bike.
