Technical questions for the retro grouches on here
#51
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 980 Times
My first bike with a disk brake was a Schwinn Stingray, which was made before many people on this forum were born. But that didn’t mean it was good. I don’t mind seeing innovation creating solutions to problems, but lots of innovations are solutions to problems which don’t really exist. The science of marketing is convincing people to buy things they don’t really need and can’t really afford.
Rim brakes are popular with retro-grouches because they are simple, effective, lightweight, easy to maintain and adjust, don’t require bleeding, and the pads are very long lasting. They are inexpensive, easy to install and set up, and, depending on the levers you use, you can precisely adjust the modulation.
I have a couple of bikes with hydraulic disk brakes. I like how the brakes work, great stopping power and modulation, great in the rain, and they look cool (an important point to some people). However, installing and bleeding is a messy and often annoying job, and for bike newbs who aren’t handy with a wrench, and don’t have a bleeding kit, they are much harder to maintain than a mechanical rim brake system. Mechanical disk brakes aren’t much different than rim brakes when it comes to maintenance, but I don’t much like the “feel” of mechanical disk brakes.
Most people won’t ride a particular bike anywhere near as long as it takes rim brakes to wear out a rim. I’ve got a road bike which is running old-school (thin) Mavic Helium wheels, I’ve put more than 100k on this bike, and haven’t worn down the rims yet.
#52
Steel is real
Quoted: 671 Post(s)
Liked 980 Times
Agreed we can give the examples of shimano cable eating shifters and with dura ace and ultegra bonded cranks which previous models were forged. A friend of mine said "Old tech that works is good tech"
#53
Steel is real
Quoted: 671 Post(s)
Liked 980 Times
#54
Quoted: 2490 Post(s)
Liked 2,961 Times
#55
Quoted: 696 Post(s)
Liked 910 Times
SRAM makes (made) a hydraulic rim brake.
#56
Quoted: 18431 Post(s)
Liked 15,586 Times
Likes For indyfabz:
#59
With a mighty wind
Quoted: 1090 Post(s)
Liked 874 Times
As an occasional retrogrouch, I will move beyond the disc brake discussion, and say Technically that I cannot foresee:
1a. Using 13 cogs on a cassette,
1b. Neither a 10 cog nor one with 52 teeth.
2. I like tubes on my road bikes.
3. I prefer external cable routing
4. Custom, handmade frames are priceless
5. 40+mm road tires are for sissies (and maybe some self supported tourers).
6. If you can clear your handlebars, your mind will follow
I ride vintage & modern, downtube shifting/Ergo10/Di2, CF/Ti/Steel frames, tubular/clincher - just make the frame 60cm please, and the weather pleasant.
1959 or 2020 - or anything in between, doesn’t really matter to me, just give it nice tires and wheels.
Custom handmade and internal cable routing. 1985
13 speed cassette with a 10 tooth cog (because I didn’t want the 9) and greater than 40mm tires. No tubes.
10 tooth and 52 tooth in the same place!!
What’s a tube?
#60
Liked 15,586 Times
#61
Quoted: 1034 Post(s)
Liked 1,292 Times
I hope we can use this thread to query the retro grouch community on border issues pertaining to equipment, cycling performance, expectations, etc.
So here is my question/point of discussion:
If disc brakes had come before rim brakes, would RGs still love rim brakes as much as they do?
I mean imagine if disc brakes were there first and then the idea of rim brakes came along? A brake that sacrifices the rim you say? I’m sticking with my tried and true sacrificial rotor to protect the wheel!
#62
Liked 1,292 Times
That is not a rim brake, and it actually was made for a very good reason. With the rotor mounted on the rim, Erik was able to make a very lightweight wheel, since the "spokes" did not have to carry the load of braking. The majority of force went directly to the rim/tires, not the spokes. The lowered the unsprung weight, and lowered the gyroscopic action that works against turning inputs, making the bike much more "flickable."
#63
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 339 Post(s)
Liked 230 Times
Wow, how novel, a discussion on rim vs disc brakes. Just curious, any of you guys hear about soaking your chains in wax as a form of chain lube?
#64
Liked 15,586 Times
#65
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,847 Times
@rosefarts = nice bikes, but Richey and Canfield go where I (almost) never ride. Spectrum, if you frequent it, qualifies as occasionally retrogrouchy.
Versatility to explore one's chosen territory is good. I have access to this beast that my son has moved on from, but had yet to remove from our garage. 3x10 moderates the cassette.
Likes For Wildwood:
#66
Sr Member on Sr bikes
Brakes are about stopping the bike. If/When you lock up the wheel, all your stopping ability comes down to a matter of how much of your tire is in contact with the ground. The one or two square inches (if that much) of tire rubber don’t care what made the wheel/tire stop rotating. So, if your “whatever” brakes are properly adjusted, and can lock up the wheel, how is one system better than the other? That being said, I will agree that there are certain conditions where disc brakes would be more functional than rim brakes…like descending mountains in the rain, for example. But otherwise, stopping is stopping.
Dan
Dan
#68
Quoted: 3958 Post(s)
Liked 7,312 Times
#69
Quoted: 3515 Post(s)
Liked 2,929 Times
I’m in the camp that says they’re a solution in search of a problem. I’d put my Dura Ace 7700s with compressionless housing and Swiss Stop pads against any disc brake.
Likes For smd4:
#70
Sunshine
Quoted: 10971 Post(s)
Liked 7,499 Times
#71
That works in theory, but this thread is directed at "retro grouches" and whenever I say I like "insert old thing here" I am called a retro grouch and stopping "progress".
It's easier to accept the somewhat derogatory name and roll with the punches. This happens in most domains where tech and products have changed rapidly.
#72
Quoted: 5793 Post(s)
Liked 2,595 Times
And, of course, you can be a grouch without being retro.
FB
Chain-L site
FB
Chain-L site
#73
Quoted: 4428 Post(s)
Liked 4,880 Times
Yet from 1983 until 2004/2006 when the disc brakes went mandatory on the mountain bikes, none really bothered about disc brakes on mountain bikes. XTR , TRP Vbrakes, and Avid Extreme Arch were the most performing Vbrakes ever made alongwith the XT 780 T Vbrakes. There was a time when you could order a MTB with v brake mounts and disc brake mounts, after 2006 it was not more possible.
Likes For PeteHski:
#74
Quoted: 7653 Post(s)
Liked 3,485 Times
Yup ... mountain bikes went way deeper into development than road bikes .... They started out as old cruisers, basically followed road bike design, and suddenly got popular in a big way, so companies had to compete for customers ... and the R&D departments got busy. Meanwhile, the "gold standard" for road bikes was whatever had been popular a decade earlier ....
Interesting ... I was listening to the rambling reporters during the Paris-Roubais Femmes (I think) broadcast, and they mentioned some brand which had an onboard air system to inflate and deflate the tires to adjust to the cobbles and tarmac.
I haven't googled it but ....
#75
Liked 7,312 Times
Likes For tomato coupe:
