Unusual pulse behavior
Quoted: 112 Post(s)
Liked 25 Times
Recently I have experienced the following unusual pulse behavior.
The ride has a flat section in the beginning and then turns hilly.
For example, total ride about 60 klm with 500-700 m climbing depending on the route.
On the flat section with a RPE of 3 I keep the pulse rate between 115-120 bpm depending on the slight inclinations.
On the hilly section I expect the pulse rate to follow in profile of the route. That is, on the steep sections to vary between 135-145 bpm, depending on how hard I am pedaling, and on the descent to go down to about 90 bpm which has been happening in the past.
However, recently the following happens, but not always.
On the flat section while it is about 115-120 all of a sudden it will increase to 128 bpm and stay there. On the uphill sections it might climb to 135-140 bpm while I would expect it to be higher, and on the descents it remains at 128 bpm where I would expect it to drop to 90-100 bpm within a few minutes.
This perculiar pulse behaviour does not happen all the time, but seems to be happening more often.
Anyone experience such a condition.
Quoted: 6214 Post(s)
Liked 4,824 Times
Last time I had something similar, I replaced my HR strap that was probably about 5 years old and the issue went away. I expect it'll come back when this strap gets old.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4395 Post(s)
Liked 3,018 Times
Yeah, check that your HRM is working properly. Make sure the strap is sufficiently tight. Also, at high temperatures and low humidity, one can get odd effects if the strap is not making good contact with your skin (not damp) or is experiencing effects associated with static electricity from your jersey. the latter two are more likely early in a ride.
Quoted: 112 Post(s)
Liked 25 Times
Expired Member
Quoted: 3686 Post(s)
Liked 5,461 Times
I've found the HRM gels to be useful. If you think it's something other than your HRM, you need to talk to a doc.
Likes For shelbyfv:
Liked 4,824 Times
I think we all pretty much assume your HR device is at fault. However you should make sure that it's not actually you.
I don't know, but I think there are some heart conditions that might give you such. As well sometimes whether or not you are dehydrated from not drinking enough fluids or are just overworked and tired can affect your HR during times you are riding your bike.
So consulting a medical professional might be a wise move.
Likes For Iride01:
Bikes: Shmikes
Quoted: 10178 Post(s)
Liked 5,875 Times
Typical funky HRM behavior. Look at the rate trace for non-physiological-looking changes (e.g., step rises and drops).
Normal exercising heart rates in asymptomatic, healthy, individuals, do not generally require medical attention.
Quoted: 2605 Post(s)
Liked 1,935 Times
Credential disclaimer: I'm not an M.D. or D.O.
Likes For pdlamb:
Liked 4,824 Times
MIght be, but I doubt it. Unless you've got a working relationship with a cardiologist who's an athlete and tuned into the kind of riding you do. Otherwise, my experience was you get lots of "Wow, your resting pulse rate is really low!" or "You ride your bike on the road? Aren't you afraid you'll get killed?" kinds of comments. You can spend a lot of money on specialists and EKGs and get nothing more than "I wouldn't worry about pulse changes of less than 10 bpm."
Expired Member
Liked 5,461 Times
I was referred to a Cardiologist after I reported to my PC that I felt faint/woozy during a really tough climb. When I related this to the Cardio, he said "Why didn't you get off and walk?" Nevertheless, he sent me for all the tests and I felt at ease knowing nothing was amiss.
Likes For shelbyfv:
Quoted: 112 Post(s)
Liked 25 Times
My cardiologist who runs moderately keeps advising to reduce intensity which I have. On the other hand, a lot of literature proposes to keep the intensity up as we age. Of course, on a personal level, how intense, how often, and age should all be part of it. On my next ride I am going to use a different heart rate monitor to see if the above mentioned condition is repeated.
I have also arrange for a stress test with my cardiologist.
Bikes: Shmikes
Liked 5,875 Times
I agree. And I had the same experience when asking doctors questions related to cycling. However the doctor can tell if there are any diagnosable heart issues beginning. And I think that any of us here in the 50+ forum should already be getting to know a cardiologist or other heart doctor so base lines and other things can be established before an actual heart issue puts one calling for the ambulance.
Likes For MoAlpha:
Expired Member
Liked 5,461 Times
Quoted: 828 Post(s)
Liked 1,665 Times
Agreed. A club member, who is relatively young (50s) and did a lot of riding, including competing in the Mt Mitchell challenge, was on a training ride with a group. After a hard climb, he felt "woozy" and on the descent (at about 40 MPH) began to lose control of his bike. Luckily, he managed to get it stopped and dismounted, where he proceeded to have a heart attack.
Heck, I think we all do.
That is nuts. Also, I can't think of anything more fun and plan to do similar tomorrow.
Likes For bblair:
Quoted: 2333 Post(s)
Liked 2,097 Times
What studies? They are typically short duration with outcomes related to VO2 max or wattage at some effort level. In my opinion, older riders say in 60+ range should be very, very careful doing HIIT workouts in terms of frequency and intensity. I can point to many older athletes where large volume and less frequent HIIT has maintained their power and time on the planet. So, if you are trying to break a world record, find a coach.
On a 60 km ride with 700m of climbing, I assume you are riding 2-3 hours in duration. For many people that is a hard workout.
When HR stays elevated on the descent after a climb, it could mean many things. Like.....my body is really hot and it needs to cool or I've exceeded my endurance capability (decoupling), or in common terms.......you were hot and fatigued. I see this on every single long ride. Of course, "long" is relative.
No idea how old you are or your fitness. I would follow your Cardiologists advice and dial it back a bit on intensity, have fun riding, and do a hard workout once in a while. You won't do a world record or anything but if you take 1-2 years with slow increases in load, you will become very fit. But no harm getting checked out. That is how this 60+ does it and it gets me fit enough.
Bikes: Shmikes
Liked 5,875 Times
Quoted: 112 Post(s)
Liked 25 Times
As the intensity of the stress test was increased the test was stopped at 220 mmHg systolic pressure and 143 bpm. I could have gone harder, but the cardiologist recommended 200mmHg as a limit which would correspond to about 130-135 bpm.
I am 76 and have already reduced the intensity. I also have an enlarged aoerta which seems to have stabilized with the reduction of intensity.
I have recently chosen slower or similar riding partners to avoid the pressure of keeping up with stronger riders. However, I do a lot of solo riding so I can control the ride.
Usual ride is about 60-70 klm with 600-700 m ascent 3 times a week.
Thanks everyone for responding.
Likes For yannisg:
Old fart
Quoted: 3593 Post(s)
Liked 3,401 Times
As an RN who worked in cardiology, I learned to mistrust external pulse monitors. There are many reasons why they can double-count or half-count pulse rates. If you get an anomalously high or low pulse reading, palpate your pulse directly (radial artery or a carotid artery are easy to find) to verify the reading. "Treat the patient, not the monitor" was our motto.
Liked 2,097 Times
HRM straps like the Polar H10 do not measure pulse (like ppg wrist straps) and are accurate to within 1% of a lab ekg.
Quoted: 514 Post(s)
Liked 451 Times
I'm not a doctor, so I have no advice other than this. See your PCP and get a referral to a cardiologist.
Bikes: Carrera Virtuoso and friend
Quoted: 129 Post(s)
Liked 47 Times
A blood test might be of benefit. Too much cholestoral? Try for a simple stress test on a cross trainer. You can achieve max easily on that, quickly, and see how long HR takes to reduce. 30 pointswithin a minute should be achievable with active cyclists/gym bunnies
I had a little too much cholesterol recently, (it was Mother's Day and I scoffed all the chocolates) and the result was surprising. I guessed all was not well.
Had a statin for a month and the result was vastly improved. Hope to be off the statin soon.
just another gosling
Quoted: 3896 Post(s)
Liked 1,947 Times
Results matter
Results matter
I had an issue not long after my second jab, an irregular and elevated heartbeat. I saw a cardiologist right away, and had a portable EKG taped to my chest for a few days. It was put on statins for 3 weeks, after which my heart settled down. It’s now been 18 months with no issues, and I have been riding pretty hard this season.
Likes For 50PlusCycling:
Liked 2,097 Times
Not those who overstimulated their sympathetic nervous system with chronic HIIT, developed a-Fib, and then needed stents to deal with the effects of inflammatory conditions.
Don't take medical advice from the internets.
I do love statins, the profits allowed me to fly first class, drink $500 bottles of wine, and stay in deluxe Paris hotels on the drug company's dime.
