Flux Types
Quoted: 4209 Post(s)
Liked 3,875 Times
Flux Types
I have been using GasFlux type B for brass/bronze for a long time. I just received a pound of their type G to check out. Has anyone here tried it? Andy
AndrewRStewart
AndrewRStewart
framebuilder
Andy I've used it for years. Long ago I asked Gasflux which of their fluxes would work best with stainless and they recommended Type G. It has a higher active temperature range then Type U by about 100 degrees F. This flux is especially good for beginners because its higher heat tolerance range prevents scorching. I am also under the impression that it has better surface cleaning ability too. I find no reason to buy Type U. Just to be clear, I use Type G for silver and only Type B for bronze.
Likes For Doug Fattic:
Randomhead
Liked 3,699 Times
Is type G clear? I use black flux sometimes, but it's a bit annoying since you can't see through it.
Liked 3,875 Times
Doug- Which means I have used type G before, at your shop! The stainless steel use is what I sort of recalled but was unsure. Thanks, Andy
AndrewRStewart
AndrewRStewart
framebuilder
Yes when it gets up to active temperature, it becomes clear. It is an excellent flux for rookies because of its higher temperature range on regular steel and for anyone using stainless. it is just as good an all purpose silver flux as Type U except with better surface cleaning properties and of course the higher temperature range. I tried to get Hank at Henry James to stock it but wasn't successful. I think one of the west coast frame suppliers carries it now. Cycle Design Stainless Light works great too.
Randomhead
Liked 3,699 Times
Bike fab supply lists it, but they are out of stock. Nova and Framebuilders supply don't list it. Trying to think of who else there is.
I guess Phoenix is west of both of us.
Metal Guru sells it, they are in New York
https://allthingsbrazing.com/
Type G shown in stock. I bought from them a couple of months ago.
Likes For rellis:
Randomhead
Liked 3,699 Times
Didn't we figure out at one point that all things brazing actually is gasflux?
