Downtube shifters in the 2020s
Quoted: 1109 Post(s)
Liked 1,200 Times
It's definitely possible to build a DT shifter bike with wider gearing. For me, though, my DT shifter bikes are C&V, and the cranksets are all 130mm BCD, so I can't do chainrings smaller than 39 without changing to a different crankset, which doesn't fit with what I want the bikes to be (as close to original as possible). Similarly, at the back end, I could use a wider cassette, but then I'd have to use different derailleurs, which also doesn't fit with what I want. AND they've all got C&V brakes, which are not as good as dual pivots, so the fact that I can't do extended climbs also means I don't do long descents, so it all works out. I do have one with a 6sp 13-32 cassette, but I find I'm not really fond of the big jumps between cogs - I'm spoiled by 10 and 11 speeds!
For low gears though, a C&V bike could have a triple and a relatively tight rear cluster, no? So hills wouldn't be an issue unless braking would be.
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,911 Times
I get it. A true classic and vintage bike is a different goal than just wanting a bike to ride and race on with DT shifters. It certainly is possible to get the same gearing and braking with DT shifters and brake levers as with more modern controls. Everything on the bike I have is early/mid 90s Campagnolo stuff on a mid-80s frame. Except for the crankset - I had to go a bit modern to when "compact" cranks were offered by Campy.
Likes For genejockey:
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Salsa Vaya with 11-42 & 50-34 downtube shift hydro brake by Richard Mozzarella, on Flickr
This Salsa Vaya made a previous BF appearance as an orange frame with a bubbling cauldron of doom percolating from the seatpost.
It is currently adorned with the same Ene Ciclo shifters displayed in the eBay listing up thread. Though I got mine from QBP. The shifters shift an XTR rd-M-9000 Shadow plus derailleur & an Ultegra 6800 with 11-42 & 50-34 gears respectively.
The pull ratio of the rear derailleur is different than lesser speed groups & consequently it works just fine with the close together cogs. Shifting is a breeze.
The older Suntour friction downtube shifters with the small barrels are what I would recommend if using 10 speed so that you can more finely tune the derailleurs position. Be forewarned though, you will need nearly a full 180 degrees of rotation to use the whole cassette.
20190316_090930 by Richard Mozzarella, on Flickr
20190305_163259 by Richard Mozzarella, on Flickr
I wouldn't try bar end or friction thumbie shifters with SRAM derailleurs. IME the derailleur requires too much cable pull & the chances of success too small to be worth the effort.
OP: Have at it. There's massive street cred to "doing things the hard way" & even more when you're competent at it.
Lurker
It is not downtube or bar-end, but I have been running Gevenalle shifters (Microshift bolted onto the front of the brake lever) on my cross bike this year, and they have been great. Really smooth shifting from the hoods with an 11sp grx rear derailleur, and nice smooth braking with TRP hydros. I removed the front shifter since I am running 1x at the moment, so the look is a bit asymmetric up front, but it is an easy replacement if I go back to 2 chainrings on the crank. It does make shifting from the drops mostly impossible, but in cross that is rarely an issue. Also, the hydro brakes are a massive step up from cheap mechanical discs.
Gevenalle in action.
Likes For esarhaddon:
Friendship is Magic
Bikes: old ones
Quoted: 26424 Post(s)
Liked 10,380 Times
...I bought a bike from a Cat 3 guy here who said they wouldn't let him race with DT shifters. This was probably ten years ago. I use them on a lot of stuff, but I ride mostly by myself.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Likes For mstateglfr:
Wow, first time I hear about actually not letting someone race because of dt shifters. Do you know if it was the race organizers or the riders team/club that said so? Itīs not against the rules anywhere that's for sure.
I don't know about 11 speed friction from any personal experience But I did try friction DT shifting with a 9 speed cassette a few years ago. I "grew up" and rode through the 70s, 80s and part of the 90s with 5-7 speed (rear) friction shifting. I feel I know how to shift friction shifters.
I could shift the 9 speed OK but it was a bit fussy to trim. The spaces between the sprockets is so small that it's much more difficult to get the shift just right and I had a few occasions where it would ghost shift without me hearing any sound that sounded like it needed trimming. So I just was too distracted getting the 9 speed right on. I got some 9 speed DA indexed DT shifters and they worked much better. My guess is that 11 speed friction might be way too fussy to get right.
Likes For zastolj:
Likes For DonkeyShow:
Quoted: 4560 Post(s)
Liked 2,802 Times
My 1989 Centurion Ironman still has the original 7-speed indexed downtube shifters. I've ridden fast group rides, long casual group rides, solo centuries and snagged some of my personal best times on Strava segments, including a couple of top tens, on that bike.
Yeah, it takes a bit more care in balance to hold a line while shifting. But most riders get the hang of it with practice.
Usually I ride with 13-24 or 13-25 freewheels on solo or fast rides, 13-28 on casual group rides. With the 28 big cog I can usually sit and spin more often. But with only 7 cogs, choices are limited and the more we try to stretch from 13 to 28 or more, the bigger and more awkward the gaps are. Even a 13-25 freewheel can have some slightly awkward gaps between some cogs, compared with a 13-21.
However, if you watch enough films of older grand tour races, including the Greg LeMond era when downtube shifters were still used and the film/video quality was very good, you'll notice that riders shifted less often than they do with brifters, and tended to get out of the saddle more often, if only briefly, to regain or maintain momentum on climbs or breakaways, rather than shifting to maintain a cadence. It can be more tiring, which makes the strength and stamina of those riders more impressive. Not that contemporary riders are any less impressive, but their gains are more in terms of aerobic capacity and ability to maintain a fairly fast cadence, rather than brute strength to grind out 40-60 rpm on climbs in ridiculously steep gearing.
And when riding a bike with downtube shifters and old school gearing, on hilly terrain and mountains it'll often be necessary to stand at least sometimes to climb. When riding alongside folks who aren't using downtube shifters, it's best to leave plenty of room around you in all directions because, for riders who usually sit and spin, they won't be expecting the slight rocking and chugging motion that accompanies standing to climb or maintain momentum. Even when standing to climb with brifters, if you practice you can shift while standing and not miss a beat. That's practically impossible with downtube shifters and I'm not sure I'd trust anyone who tried to shift that way while standing to climb. So when I'm the lone oddball riding an old school bike in a group, I leave enough room to avoid annoying or alarming anyone around me. Often I'll drop to the back on climbs and catch up on the downhills.
But since getting carbon fiber bikes with brifters around 2018, I don't ride the Ironman with downtube shifters quite as often, other than solo or casual group rides. I'll always enjoy the experience of my first road bike, a mid-1970s Motobecane with downtube friction shifters. But it's easier to meld with a fast group and go with the flow using brifters, and in some cases trying to maintain a somewhat faster cadence rather than mashing. Especially on roller coaster terrain with lots of shifting.
Regarding criteriums, the last races I rode were in the 1970s, so everyone used downtube shifters. Most crit courses are pretty flat, so you don't need to shift often anyway. It really shouldn't be an issue unless it's an unusually challenging crit course. Our courses were on big industrial park parking lots, as flat as can be, and I don't recall ever shifting gears after the start. Maybe for a sprint finish, but I usually avoided those after a bad crash in one sprint finish. After that my goal was to finish in the middle of the pack, stay upright and safe and just have fun.
Likes For canklecat:
I actually have a crit in my plans next june. It has a slight hill before the finish line so the dt shifters will for sure be a compromise but I think I'll go with them anyway and see how it goes.
Likes For zastolj:
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I'd only ridden with downtube shifters until I was in my 50s, when I got behind a guy with about my same power but using brifters, mildly hilly terrain. I was a convert in about 5 minutes of that.
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 514 Post(s)
Liked 449 Times
Back in the day we didn't dare shift in the middle of a sprint. You chose a gear for the wind-up and hoped it was the right one.
Likes For oldbobcat:
Old fart
Quoted: 3589 Post(s)
Liked 3,400 Times
The other thing about DT shifter bikes is that since they tend to be from pre-1995, they also tend to have "Hero Gears". You know, 52/42 x 12-21, 13-23 - that kind of thing. I rooted around on Ebay so that I could put at least a 12-25 on all my DT shifter bikes. Even so, I tend to ride them only on routes that don't have extended climbs. I CAN do medium length climbs on them, but it's a chore.
Liked 1,200 Times
I like my two Sram 10 speed mechanical shift bikes, my Campy 8 speed DT bike and my 12 speed Sram AXS Etap bike.They're all fun and all have identical ranges except the AXS bike which is different, but functionally very similar in range. Frankly, I could have easily built up the DT bike with brake/shift levers but I wanted to have a DT bike for the fun of it. It's nice just for that reason alone, variety is fun. And frankly, for my use as an "energetic enthusiast", the 8 speed drive train works as well as the 10 and 12 speeds. The gaps, which are "huge" by modern standards, are functionally irrelevant for me. Shifting is easy and spot on for all 4 of them.
Likes For Camilo:
Quoted: 514 Post(s)
Liked 449 Times
With so many cogs on the rear wheel, it isn't about the location, it's about the lack of indexing. With 9 or 10 cogs, you want an indexed downtube shifter. And remember, if you're going to spread your chainstays to 130 mm, you need to square up the dropouts and derailleur hanger.
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
You're not alone. I've got STIs, bar ends and downtube shifters. Lately I've been enjoying the simplicity of DT shifters. Maybe next year I'll fall back in love with STIs, who knows. If you want 11 speed DT shifters you can certainly go that route.
Quoted: 446 Post(s)
Liked 1,045 Times
I did a fast paced smash group ride and there was a young kid using a DT shifter road bike. He did just fine keeping up with us. In fact the shifting sounded pretty cool especially when we did the hard sprint segments. I think it's one of those things you just get used to and let muscle memory do it's job.
Professional Fuss-Budget
I don't think there is a big safety risk, though it will take time to get proficient with them. Rather, it's that you're hobbling yourself slightly by using such older gear. E.g. round tubes, a more flexible frame, less frequent shifting, fewer gears, needing to take your hands off the brakes to shift etc will all put you at a competitive disadvantage. That won't make you stronger, it will make you slower... which is the exact opposite of what you want in a competitive situation.
I'd save the vintage bike for solo and casual rides where speed isn't important.
Quoted: 65 Post(s)
Liked 60 Times
Back in the early 90's, I was one of the first to have Dura-Ace STI when they first came out. My coach was a track sprinter, he didn't like me shifting during the sprint. We worked a lot on spinning out a gear like track sprinters do. Then I went into my retro phase running Simplex retro friction shifters with Mavic SSC derailleurs with 8 speed. Raced mid 90's through the late 90's with that setup
Racing with downtube shifters requires being more aware of your course. Since I was already sprinting like a track sprinter, not being able to shift didn't really matter.
Likes For Fredo76:
Quoted: 389 Post(s)
Liked 255 Times
When I first started racing, I had a Cannondale with 6 speed DT shifters. 52/42 x 13/24. At the Los Gatos Criterium, there's a short steep hill. I blew the double shift to my lowest gear and never made one lap.
Likes For Jack Tone:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
Route selection is key. The other thing about DT shifter bikes is that since they tend to be from pre-1995, they also tend to have "Hero Gears". You know, 52/42 x 12-21, 13-23 - that kind of thing. I rooted around on Ebay so that I could put at least a 12-25 on all my DT shifter bikes. Even so, I tend to ride them only on routes that don't have extended climbs. I CAN do medium length climbs on them, but it's a chore.
On the days I do switch back to my brifter bike, I have to laugh at my inability to adapt, where I find myself reaching for the downtube to shift. What a moron.
Back to the OP: For racing, you might find that to keep up with your fellow racers, you will have to be SUPER adept at shifting, since people on brifter bikes can change gears so quickly, especially out of the saddle. When I bought my first set of Campy Ergo shifters, I was floored and never looked back.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 1399 Post(s)
Liked 1,882 Times
I couldn't get away from down tube shifters (and thumb shifters on MTB) fast enough
for the taller riders the down tube shifters could be even more of an issue because of the increased reach / movement
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
