Silver rims with rim brake tracks
Quoted: 253 Post(s)
Liked 223 Times
Hi,
is it just me, or is it virtually impossible to find rims (not wheelsets) in silver for use with rim brakes? Esp deep or semi-deep section rims seem to be impossible to come by.
Anyone has the same problem? If not, kindly reccomend a retailer (preferably in Europe) who sells these.
All the best
Positron
All the best
Positron
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
https://www.chainreactioncycles.com/...B&gclsrc=aw.ds
The 36h silver option is in stock.
I have multiple sets of wheels with this rim in black with 28, 32, and 36h- its quite good. 25mm deep.
Velocity Dyad comes in silver too.
Velocity Deep V is 30mm and thats probably close to the deepest you will find for an aluminum rim with brake track.
Likes For mstateglfr:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Velocity sells many models of rims in silver for rim brakes.
Stuart Black
Stuart Black
Quoted: 1562 Post(s)
Liked 1,734 Times
Kinlin rims:
https://thecycleclinic.co.uk/collect...in-silver-700c
Available in various drillings, both symmetrical and assymetrical, and tubeless ready.
Quoted: 1949 Post(s)
Liked 2,010 Times
H + son archetype
Likes For Classtime:
Quoted: 3464 Post(s)
Liked 2,829 Times
Unsure what the definition of "deep" is.
reference Campagnolo Shamal and comment on that as deep enough or not
Quoted: 1163 Post(s)
Liked 442 Times
Pacenti makes some nice silver rims. Velocity A23's and Quill rims are available in both polished and silver anodized.
Likes For masi61:
Quoted: 964 Post(s)
Liked 1,451 Times
Mavic A319 and Rigida Sputnik are great for touring, and can be gotten cheaply through SJS Cycles in the UK.
Quoted: 1819 Post(s)
Liked 1,694 Times
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Not deep, & not 'high end', but I think the polished Sun M13-II rims build up nicely and look great (especially if you peel off the ugly sticker...) on a classic/vintage ride for a hard-to-beat price*.
*best I've found was from Cason City Bike Shop. They were $25 or so for a while, but now showing at $35.
Likes For ehcoplex:
52psi
Quoted: 790 Post(s)
Liked 802 Times
H+Son rims. Many varieties available, I believe most can be had in silver. Quality is superb.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
There's a set of 24H Sun Venus (25mm height) on Ebay right now. Tremendous rim.
Polished version of the Kinlin XR19W is available at Interloc Racing Designs
under the name "Cadence". Otherwise, unpolished at Bicycle Wheel Warehouse.
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
These Kinlin XR26T & XR26RT rims came in the mail today. Silver and 26mm deep.
Likes For BradH:
What are the benefits of a deep rim?
Catching Smallmouth
Quoted: 88 Post(s)
Liked 134 Times
Strength and aerodynamics are the main benefits. There are drawbacks too. At some point deep rims become heavy, especially when made of aluminum. Crosswinds can be nasty with deep wheels, especially a deep front wheel.
If I've got a frame with 25.4/28.6 tubing and a threaded 1" steerer I'll stick with box section rims or rims less than 30mm deep if possible.
Likes For BradH:
Standard Member
Liked 940 Times
When I went from a rim-brake 13mm box rim to 25mm (welded and machined), I experienced far fewer loose spoke (truing) and risk of "tacoing" the rim on abrupt application on down-hills. Also, higher rims tend to be newer (although still velo) than traditional box rims, so not only the height makes them stronger and stiffer, but the overall design and material (better aluminum).
I consider anything 25mm rim height and up to be semi-deep. In my opinion, they are definitely in a different classification than the 13-19mm. I use DTSwiss 14g competition, single-butted, for a bullet-proof wheel.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
Positron400 FWIW the whole brake track thing started because the hard anodized darker rims becoming ever more popular in the late ‘80s didn’t break quite as well as their silver counterparts until the anodizing wore off. The uneven wear of the anodizing was very unpopular and eventually the manufacturers started the machining to resolve these issues. There was no real reason, other than aesthetics, to machine the silver ones.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
source of supply for silver Kinlin rims
lovely silver rims. Where have you purchased these rims? It's a pity, that silver high-quality rims are so hard to find.
I'm looking for silver XR26T 20 holes and XR26RT 24 holes rims.
Or does anybody else have a source of supply, preferably in the EU?
Greetings from Germany
Alexander
Catching Smallmouth
Quoted: 88 Post(s)
Liked 134 Times
Hi Brad,
Alexander
Alexander
I don't know if he ships to Europe
Of course, that presumes that you're ordering rims that are meant for rim brakes...otherwise they might be too thin where the pads would hit. The last set I bought were polished Velocity Ailerons, and...man, they look good polished.
I've built with the H+ Son rims, too, and they build as well as any good rim.
Thanks, Brad.
As the XR26RT hadn't been available at bikehubstore.com in silver, I ordered black XR26T + XR26T at bitexhubs.uk.
Maybe I'll grind off the color, as I did before with DT R460 rims. Anyway an unpleasant work.
