Bizarre attempt to fix a flat -- seen at the co-op
Bikes: N+1
Quoted: 229 Post(s)
Liked 652 Times
A guy brought in a bike with a flat front tire to the bike co-op where I volunteer. Said he could not figure out how to fix it. I started taking the tire off the rim and felt something inside the tire -- thought it was a slime tube or similar. Nope. The guy had managed to remove the tire and stuffed rolled up newspaper inside it and remounted it. ;( Needless to say, it did not work. Not only was this a bizarre repair attempt, but the guy came in with a new tube and said he had that before he tried the newspaper -- but apparently could not figure out how to put it in the tire -- and that's when he tried the newspaper. Always a surprise what comes through the door at the co-op....
Likes For JulesCW:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
As Red Green would say, "If women don't find you handsome, they should at least find you handy".
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Where does one find newspaper nowadays?
Likes For dedhed:
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
I did something similar with grass for someone on a ride, I think we had some tube or pump issues I cannot remember so we just stuffed with grass and made it back after 150 miles of riding that weekend.
Liked 2,971 Times
p...a...p...e...r? what's tis pulp fiction material you speak of?
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 3375 Post(s)
Liked 5,514 Times
Likes For Shimagnolo:
Quoted: 6193 Post(s)
Liked 4,809 Times
Run flat protection!
Just need to figure out how to get it in the tube instead of just the tire.
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Better example/worse way to change tires and tube. Offer of Schwinn aluminum road bike very cheap. "Needs tires" was all ad said.
i arrived. Front tire off rim but rim still mounted.
Seller had cut off old tire and tube on rear. He took a brand new rear tire and brand new tube and cut them cross ways and then mounted them to rim (with tape to keep tire on). He'd next tried to fill tire but being cut it wouldn't hold air. He then tried gluing it but again no luck. Onto front tire where this time he got old tire off rim but with rim still mounted you see the problem. Seller very frustrated. I offered to install the brand new front tire and tube but seller just wanted bike and me gone.
Seller hasn't tried just filling the tubes. When I got it home an remounted the old front tube and tire they were fine
Guys who work at garages have people who try to change car tires without using a jack. Bolts off but rim won't come off so they give up and try to drive on flat....
The culture of fix it seems to be dying, so many people have no willingness to try to repair.
Likes For WGB:
Liked 4,809 Times
I'm not sure if I should just go by " at least he tried something" or " bless their heart, he tried". <grin>
Quoted: 18376 Post(s)
Liked 4,511 Times
Until one day a couple of years later I ordered some really heavy items from E-Bay, and I found my mailbox lying flat on the back with the box inside.
I can't really blame it on the snowplow, the post was mighty rotten.
Anyway, a half day's work, and I have a new, strong post to last another 20 or 30 years.
So many roads ...
Bikes: 2013 Specialized Tricross, a (almost) showroom condition 1987 Schwinn Collegiate 3-speed (for short coffee runs), KMX recumbent trike
Quoted: 46 Post(s)
Liked 111 Times
Likes For TCollen:
This story made me think about the time my nice (about 14) was going to fix a tire.
I asked her if she needed some help, but no she was confident it was a peace of cake, and she was able to do it.
Lather I would find the bicycle still in the workshop, and found out that she had glued on a patch without removing the plastic foil. And a bit later I would find out that the tube wasn’t even leaking, it just needed some air. Millennials, sigh!
Quoted: 41 Post(s)
Liked 39 Times
As the thread has strayed from bike only field fixes-once a very long time ago was driving my beater 1967 BWW (car) on the Baltimore Beltway when an oil line broke-losing oil and much smoke. Had tools of course but how to fix it? Undid flare nut connection and found that for some unknown reason there was one very old round of.22 ammo in bottom of tool box. Pulled bullet, put it under flare nut ,tightened it up until lead extruded from flare nut hole and drove home
wheelbarrow had a flat the other day, 14 bucks for a tube! stuffed the heck out of it with bubble wrap, no more flats for me, how many nails does it take to pop 10,000 bubbles?
only use the thin twice a year, found a used wheel on the side of the road that fits but it had a bad tube. blew up the last tube by burning a lot of sticks in the wheelbarrow. thin hot so hot that the tube blew one side of the rim out about 3 inches. could have been dangerous. use a 50 gal drum folks. if they allow burning in your area. if not, put a hot do on a stick and you are legal.
sorry, "g" is out on comp, needs wd 40. which is fish oil. wd stands for water displacement. guides use it on bait.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I took off a MTB tire at the co-op, and found another tire crammed in below it, with a flat tube inside that.
Quoted: 1074 Post(s)
Liked 295 Times
Heading back from the beach one day, we discovered one bike had flatted, probably on the way there. Tried the grass thing first. While it worked in principle, I found it rather lacking in actual use. The grass got compressed/chewed up so fast. Didn’t get any distance at all before it needed to be repacked. After a few tries we ended up using our towels and the ugliest t-shirt instead. This worked well enough to last the 5 mile ride home.
Liked 5,514 Times
Quoted: 4560 Post(s)
Liked 2,802 Times
No surprise. We're in a culture where most of the knowledge acquired throughout history is a Google away on the supercomputer in our pockets, but a week ago people across America were hoarding gasoline in plastic grocery sacks.
We are the Golgafrinchans.
We're Americans, with a capital 'A.' You know what that means? Do ya? That means that our forefathers were kicked out of every decent country in the world. We are the wretched refuse. We're all very, very different, but there is one thing that we all have in common: We're mutants. There's something wrong with us, something very, very wrong with us. Something seriously wrong with us
Likes For canklecat:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Yay, Mississippi!!!
Quoted: 2952 Post(s)
Liked 3,106 Times
I'm impressed. I was proud of myself for riding home 10 miles on a tire that I booted with a Clif Bar wrapper, but this is next level.
Likes For caloso:
Likes For phughes:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,470 Times
Quoted: 878 Post(s)
Liked 726 Times
I don't have any bike-related bodges but I did sell a road bike to a friend last week who didn't know how to change his car tires (had to bail him out years ago, nearly suffered injury when the car rolled off the jack because he hadn't applied the parking brake) nor how to use a can opener (leading to some stunned surprise during a Thanksgiving meal prep). I explained that he should get tire levers and watch a video on how to fix a flat, but warned him not to follow any directions that involve using a screwdriver like Stephen Colbert's.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
I’m curious, if it wasn’t leaking, how did she decide where on the tube to put the patch?
Likes For jccaclimber:
