Seatpost Clamp Bolt Hex Head broken - no grip
The bolt head hex grip on my seatpost clamp bolt is broken, so there is no grip for my hex key to screw it out (see pic below).
I've already ordered a replacement clamp bolt, but do you have any ideas on how to get the screw out before I try something that might makes things worse? Some ideas:
1) Drill a metal drill through the bolt head to destroy the bolt altogether - difficult because the bolt is thick
2) Try to saw the bolt off - difficult since it's so thick
3) Any other way to "get grip" in the bolt for unscrewing?
Cheers!
Cheers!
Quoted: 3241 Post(s)
Liked 2,512 Times
Try an Easy Out screw extractor first.
Quoted: 41 Post(s)
Liked 39 Times
Cheers!
Cheers!
ps be sure to stuff something into the seat tube before cutting to keep chips out of bb and clean tube out afterwards so you don't seize the seatpost
Quoted: 4806 Post(s)
Liked 3,931 Times
Can you grab enough of the center portion of the bolt with needle nose vice grips and simply unscrew the nut? If the nut won't unscrew, then hold it with an Allen key and hacksaw as suggested above.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Is the bolt actually broken or is the hex portion merely rounded out? If the latter, you might be able to drive in the next larger size hex (either metric or standard) or a Torx bit.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
a number of viable options here, but i'll throw in another. grab the female bolt within the slit using needle nose pliers or vice grips and use a reverse drill bit on the head of the male side
Likes For Mr. 66:
Quoted: 1106 Post(s)
Liked 1,328 Times
Here are some options, in order of risk-of-damage:
a) grind a hex key of the proper size flat, so you get sharp corners at the end. Drive it deep into the socket, there may be enough of the hex left down there to grip. If the hex does not work, try with a torx bit if you can find an appropriate size (as mentioned above).
b) use a dremel cutoff wheel or hacksaw to cut the bolt in the plane of the seatube slot. This will take time, but you are not likely to wander far enough to damage the ears.
c) use a vice-grip or similar pattern to grab the outer edge of the screw head (as mentioned above).
d) use a dremel cutoff wheel to cut a slot in the face of the screw head, then use a flat-blade screwdriver on it. You must be careful not to cut into the ears.
A while ago a friend turned up with a bike she was to ride the next day in an event, seat at the wrong height, and the socket-had screw had rounded as yours - plus the screw was in a counter-bored hole so the head was flush. a) worked, and after that I that I made a little spacer so the head of the (longer) replacement screw would always be proud of the hole. A socket-head capscrew in a counterbored hole is about as intelligent a design element as seatpost flutes.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 4236 Post(s)
Liked 2,949 Times
then you ruin a good tool....unless you have plenty of spares. it certainly works, though!!
Likes For himespau:
Great input. Just ordered a pair of vice grips and a set of bolt extractors and left hand drill bits so in a few days I should have some options to try out.
Quoted: 394 Post(s)
Liked 346 Times
I doesn't seem like it could be very tight since there's no seat post to tighten it up against.
Anyway, I think a small pair of vise grips should work, and if not just cut it.
Quoted: 4512 Post(s)
Liked 6,386 Times
Here's another option: take it to a business that specializes in bicycle repairs (aka a bike shop). When you do this, something magical happens: your problem becomes their problem. Plus, you help your community and you start to build a relationship with your shop that may pay dividends down the road. And all this for just a little amount of $ that you probably won't miss. Just sayin'.
Quoted: 3242 Post(s)
Liked 2,086 Times
If it were me I would use a dremel cutoff wheel to cut the bolt(carefully) via the slit in the seat post. You could also use a hacksaw blade but would need to keep the bolt from turning
I stripped a L crank bolt once, used a Dremel to carve a slot, used a large flat bladed screwdriver to loosen the bolt. I got lucky, it worked.
Quoted: 3464 Post(s)
Liked 2,831 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
[QUOTE=onyerleft;22199085]Here's another option: take it to a business that specializes in bicycle repairs (aka a bike shop). /QUOTE]
Kinda new to this C&V crowd aren't you?
The major shop here says this
Special Notes
Some bicycle styles or repairs require additional work and are therefore subject to additional charges:- Recumbents, tandems and specialty bikes
- Older bikes, department store bikes or bikes in poor condition
- Hydraulic brake maintenance
- Insurance or accident estimates
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Stripped Hex Sockets On Seatpost Bolts
Couple of things to consider...
Those seatpost bolts are usually made of through hardened alloy steel with a Rockwell C (Rc) hardness of 45 Rc or more. The OPs' is stamped Cro Mo meaning Chrome Molybdenum alloy steel like 4130.
Most "hardware store" i.e. cheap drills are made of carbon steel hardened up to ~60 Rc.
But... when carbon steel reaches ~400° F it looses it's hardness and becomes useless. Commercial industrial quality drills are made of "high speed" alloy steels with hardnesses from 60 Rc to 62+ Rc. The benefit of high speed steel is that it will maintain usable hardness up to 1000° F.
A problem trying to use a drill in that stripped out hex hole is that it's likely going to grab and chip or break.
An "easy-out" or screw extractor isn't going to be of much use either because there's only going to be about 3mm-4mm length of "purchase" for the tool to dig in and grip the screw head. They work best with longer engagements.
Another point, many seatpost bolts have a small tab that fits into a small slot in the lug to keep the non drive side part from spinning during tightening.
Vise Grips make thin long nose pliers that will fit in the space between the "ears' on the lug but they wont do much good unless you can grip the right side threaded part of the bolt and try to turn it. The left side wont turn because of the tab. Also there is not enough exposed surface on the bolt head side to grip. See OP's photos below.
What to do? What to do? What to do?
If a drill will cut into the bolt head, by using increasing larger dills enough metal can be removed so the the head will pop off. Easy way, Home Free!
Next thing would be to take a Dremel tool with about a 1/4" carbide burr or a mounted abrasive point and grind through the bolt in the center of the lug ears. As some one mentioned above, unless the BB is going to be removed, use something in the seat tube so that the metal chips and grit doesn't get into the bearings.
Cause of the problem???
Usually happens with cheap of worn out hex keys (Allen wrenches).
One of those never ceases to amaze me things, folks who spend hundreds of dollars on the best components and not use good tools - bike shops too!
Quality hex keys are made hardened steel that resists wear and most importantly, they're accurately sized to fit the sockets.
Quality hex keys have chamfered ends that smoothly fit into the sockets. Cheap hex keys have rough corners which can keep the key from seating properly.
Hint, as the ends wear, grind up to 1mm off to keep the end size accurate.
Quality hex keys are some of the cheapest tools you can buy. Why settle for garbage?
End of lecture...
verktyg
Just one more thing that I just thought of:
Solid carbide drills for drilling hard steels. Known as Die Drills or HiRoc drills, they're strong and work well but can sometimes be expensive (read way overpriced).
Carbide tipped masonry/concrete/rock drill bits are cheap and can be used in a pinch to drill hard steel.
End of lecture...
verktyg
Chas. ;-)
Chas. ;-)
verktyg
Liked 1,238 Times
OP In Sweden???
Special Notes
If so, those suggestions may be irrelevant...
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 472 Post(s)
Liked 1,028 Times
I subsequently decided I did not really want a triple wrench at home. Took it back and it's still in service with little sign of wear.
I also learned, over the years, that if I buy tools that are better than I am, I always grow into them. Worth the money.
Likes For Prowler:
Liked 1,328 Times
From the pic supplied it looked to me not as though there wasn't enough to grip, but that that was a rounded edge, and a mole- or vice-grip would tend to slip off. You could use a clamp to hold it on, and incrementally increase the pressure without moving the arrangement, causing the teeth to bite deep enough into the rounded edge that it'll have a chance at turning it before it slips off; alternatively you could use a safe-back file (or riskier: dremel) and carefully cut some flats on the screw head.
Likes For oneclick:
verktyg
Liked 1,238 Times
Latest Invention In Wheels!
Latest re-invention:
Remember, a hammer should be the first or last tool to pick up!
verktyg
Chas. ;-)
Chas. ;-)
Great post, a lot of good things to pick up on there!
Sweden/Uppsala (Stockholm) it is, and from your username I'm guessing there's a connection there? Yes, good bike shops around here are hard to come by and even the bad ones charge around 50$ to change an inner tube
I couldn't wait for the tools to arrive so I adjusted the dremel advice and took a small hacksaw and carved a slot through the bolt head. Worked like a charm in this case since the bolt itself wasn't really stuck.
