Does this look worn to you?
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I haven't been doing much bike work lately, nor even much riding or visiting BF. I've been out a few times this summer and we have taken the tandem out a few times. Been having trouble with the tandem's drive train. Time to do some investigation.
Do you see anything wrong here?
Time for new rings and chain (not installed yet). Ignore the dirty bits. I guess 15,000 miles will have an effect.
New tires too.
New tires too.
Real cyclists use toe clips.
jimmuller
jimmuller
Likes For jimmuller:
Quoted: 5224 Post(s)
Liked 3,581 Times
was it exhibiting any symptoms, doc?
Liked 645 Times
Ah, yes. Skipping teeth when we pushed hard. (The Rear Admiral didn't like that.) We didn't have to push very hard and it was getting worse. I measured the chain. 12 inches covered just a bit more than 11 links!
Surprisingly, the new SRAM PC870 chain fresh out of the box was 56 outer links plus Quick Link, exactly the same as what the bike had. I expected it to be longer, with a few "extra" links I'd have to remove.
We don't use the granny ring all that much, which is why it looks okay.
jimmuller
jimmuller
Likes For P!N20:
Quoted: 3810 Post(s)
Liked 6,699 Times
I think a shark is missing its teeth.
Likes For nlerner:
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 199 Times
Those links above “38 Sugino Japan” don’t look like they are fully engaging the teeth.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
Seeing it's mainly the teeth on the big ring that are worn, you guys must be real fast!
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
I wouldn't rule out stuck pawl on freewheel or similar freewheel related slippage when under any load. I've had more cases of older, heavily- (or under-) trafficked freewheels causing slippage than worn rings. Easy to test for also - toss on another rear wheel with a known-good freewheel, or just swap on a known-good freewheel.
But sure, could be related to chain or ring wear.
Liked 645 Times
It's great when people gang up to tell you everything that is wrong.
Yes, the big ring teeth are hammered. The middle ring teeth are hammered pretty badly too. And the chain is badly stretched. That's the reason the chain isn't engaging the teeth fully, or the teeth not engaging the chain if you prefer to put it that way.
The bar tape is, um, experienced. You really think it should be replaced? Okay, if you say so...
jimmuller
jimmuller
Liked 6,699 Times
Likes For nlerner:
Liked 645 Times
Good suggestions though.
I tried to build this bike with as much original or original-like equipment as I could manage. That rear crank is a modern crank cut down to 140mm but the front is original Stronglight. That means I had a spare timing gear, since the rear crank is a modern arm with (I think) 74mm BCD. Eventually I'll have to switch over to newer stuff, I guess.
jimmuller
jimmuller
Quoted: 1858 Post(s)
Liked 664 Times
New tires too.
New tires too.
(deleted by author - posted in wrong thread).
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
yes I do see something wrong. I think the front derailleur cage is too close to the teeth on the big ring. Campy at least says to set the height of the derailleur for 1.5 mm to 3 mm vertical clearance. I use this spec for all my bike setups. With the cage too low, the cage tries to drive the chain through the outer chainring rather than helping it sneak through.
Liked 664 Times
True dat, but Dr. Jim is looking for what we see. If it was mine, this is one of the reasons I’d put her up on the stand and make a better measurement. I just did this on Mrs. Road Fan’s Campy triple, and the big ring is flush with the derailleur outer plate when the chain is on the middle ring.
Likes For Road Fan:
Was the original chain also SRAM?
Liked 645 Times
Now you wanna' talk about chains breaking, I once tried restoring a Motobecane Le Champion which came to me with all its original parts. So I assembled it for an easy test run around the block, got about 30 yards and the chain broke. I believe the chain was a SedisSport but perhaps not. Closer inspection showed that a third of the outer side plates had visible cracks. That chain got retired immediately. I eventually sold bike and parts to another BF member. The full restoration was bigger than I wanted to jump into.
Another chain-break episode involved the Masi when I was about 30 miles from my car into a planned 75 mile ride. Apparently the Quick Link broke or came apart. I couldn't find the missing half along the 50 yards of roadway where it must have happened. I wondered if there was a bike shop in the nearest town. After foot-pedaling the bike for a quarter mile I asked someone on a riding mower in his front yard. He said the guy who lived next door was an avid cyclist who had just come in from a ride so I should go ring his doorbell. Wow, talk about being in a lucky place and time. The guy did indeed have a chain tool I could use to splice my chain. He had to show me the chain ring from his older-days track bike. The teeth on that ring looked like needles. We had a great conversation and I made it safely back to the car. I have carried a spare Quick Link pair ever since. For want of a few grams of metal the ride was lost, but not the rider or the horse.
jimmuller
jimmuller
https://www.parktool.com/blog/repair...n-on-a-bicycle
If it took only a bit more than 11 links to measure 12" when under reasonable tension, you might have been a wee bit past 0.75% elongation. (smile)
Reminds me, I probably should use the chain wear checker before today's ride.
Quoted: 1949 Post(s)
Liked 2,010 Times
The freewheel was good when you got it from Pastor Bob, and you put it on the bike with an old chain, it might not be good anymore and could be where the chain is skipping. Worn rings for me cause stickyness not skipping.
