Creaking Noise
Creaking Noise
Old 12-24-20, 04:02 PM
biker222
Quoted: 57 Post(s)
Liked 19 Times in 11 Posts
Creaking Noise
I developed a creaking noise recently while using road bike on a fluid trainer that only was present during riding out of saddle in higher gears.
Checked crank arm pinch bolts and pulled seat post out and re-lubed , but problem persisted.
Checked 105 cassette lock ring tightness with torque wrench and found it had loosen up about 3 notches. Torqued to 40nm.
Rode out of saddle in higher gears and creaking disappeared. A little surprised lock ring would loosen if torqued properly.
Checked my rear wheel that I use for road riding and 105 cassette lock ring was also loosened a couple of notches.
Moral of story check everything periodically even if torque to specs.
biker222 is offline
Old 12-24-20, 04:30 PM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
I developed a creaking noise recently when getting out of bed in the morning. My girlfriend told me to man up and stop whining
alcjphil is offline
Likes For alcjphil:
Old 12-25-20, 09:42 AM
biker222
Quoted: 57 Post(s)
Sounds like you need to get torque to specs
biker222 is offline
Old 12-25-20, 11:26 AM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
Those cassette lockrings have the clicking detents which, IMHO, interfere with an accurate torque reading.
Another variable is if the threads are greased or dry. 40Nm on a greased thread will produce more clamping force than 40Nm on dry threads.
But your point is well taken, it doesn’t hurt to check torque once in a while.
MudPie is offline
