Way to Weigh?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
Way to Weigh?
Is there a way to weigh a complete bike on a 12"x12" platform scale? I am having a difficult time getting it situated on the scale.
Likes For John Valuk:
Standard Member
Liked 940 Times
It is more like a postal scale for ebay sellers. It only works for items up to 60 pounds.
Quoted: 7652 Post(s)
Liked 3,473 Times
If you can put the bike on its seat (upside down) and sort of balance it you can get an approximate weight.
If you have a little lumber you can lay two rails with three crossmembers, one under each tire and a wide one at the balance point which you would put on the scale.
Liked 3,473 Times
Or spend ten bucks and get a hanging fish scale.
Likes For Maelochs:
Quoted: 1068 Post(s)
Liked 786 Times
No matter how you eventually weigh the bike, just make sure to deflate the tires before weighing.
Liked 3,473 Times
Helium in the tires ..... lowers the weight .....
Quoted: 6193 Post(s)
Liked 4,809 Times
Maybe put the scale on the corner of a table or countertop that has a lot of over hang and then hang the bike by it's top tube on the scale.
If the bike wants to slide on the top tube because of the way it balances, then put a damp rag or towel on the scale and zero that out first.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Weight on the front wheel + Weight on the back wheel = Total weight of the bike
You're welcome
Captain Obvious
You're welcome
Captain Obvious
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Mine's a luggage scale, about the same price: https://www.amazon.com/gp/product/B00NW62PCA
Likes For ThermionicScott:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Quoted: 5224 Post(s)
Liked 3,581 Times
how about putting the rear wheel on the scale & lifting the front of the bike vertical? then just lightly hold it in place w/all weight on rear wheel, while you glance down at the scale? or is that what you tried & it's just nutz?
Likes For rumrunn6:
Liked 2,568 Times
I guess my bike weighs 55 lbs then.
Quoted: 838 Post(s)
Liked 1,082 Times
Liked 2,568 Times
Most of the time I just use the me+bike on a floor scale method.
Quoted: 838 Post(s)
Liked 1,082 Times
It's a bit awkward I'll admit, but yeah, I'll loop the strap around the top tube just behind the bottom bracket and lift up in sort of an upright row motion. If you do it smoothly, you can get a good and consistent reading.
Pennylane Splitter
Bikes: Yes
Quoted: 1802 Post(s)
Liked 1,439 Times
This. To make it a little easier you can use a strap to secure the rear wheel to the seat stays or chain stays, or squeeze the rear brake lever with it, so it doesn't rotate, then lift it to vertical and put it on the scale with the rear wheel.
Likes For skidder:
Quoted: 838 Post(s)
Liked 1,082 Times
Used both the floor scale and ThermionicScott 's luggage hook method. Both gave me nearly the exact same results, putting my 1986 Voyageur at 26.5lb with fenders, double bottle cages, a brooks saddle, leather bar tape and a bell attached. Which probably puts it right around the catalog weight of 24lb if it were stock. Nice!
Likes For polymorphself:
Liked 2,568 Times
