fork appears to be welded on investment cast crown?
Quoted: 236 Post(s)
Liked 171 Times
Not sure if this is the right forum but have a question on an old Tange fork I've come across. I was told it was an investment cast crown however when examining the underside it appears to have been welded. Is this just a bad lug that had to be repaired? Ideas why it looks welded? Never seen that on a lug before. The steerer is stamped 'Tange 8B'. Thanks-
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
I think those crowns are formed out of sheet steel and welded. The steerer and legs are then brazed. I've had a number of mid 80s Treks and Cannondales with those Tange forks. They were fine.
Quoted: 3464 Post(s)
Liked 2,831 Times
As I recall this was the same basic crown that Trek needed to recall.
Not excited with all the cracked paint I see there, at the fork leg and steerer.
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Yes, that's a crown made by welding thick sheetmetal that's been bent around. Not cast. Perfectly OK way to make a crown, though not high-end or fashionable. Strong enough (usually) and pretty light. The Nervex Professional crown made famous by the '60s-'70s Peugeot PX-10 was made the same way, and it is also light and strong.
Likes For bulgie:
Liked 2,831 Times
I had to recall the brand- Ishiwata sold them, made them.
Liked 2,576 Times
Isn't that a bit unlikely on a fork made by Tange? I have seen Tange-built forks made with Reynolds 531 tubing, so we know Tange will make forks with other people's stuff, but Tange using Ishiwata steel seems less likely to me. Not impossible, just less likely.
Mark B
Mark B
Quoted: 236 Post(s)
Liked 171 Times
I also saw a picture of a Keirin track bike (forget the brand) that had what looked like an identical fork down to the color, styling and welds.
Quoted: 236 Post(s)
Liked 171 Times
Now it's curious you say that 'cuz the fork came on a Japanese bike from the early 80s that is made with Ishiwata tubing. However, my understanding, based upon limited knowledge of Tange's fork date stamps is that my fork was made in 1988, so, does not appear to be original to the bike.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Nothing to see, here, move along.
You'll see this construction on literally millions of bicycles.
Likes For aland2:
Liked 5,803 Times
No, the OP's title seemed alarmist "fork appears welded on investment cast crown".
1. The fork crown is not investment cast, it's sheet metal that's been bent and welded (just like many lugs from that era).
2. I'm pretty sure Bike Forums doesn't have millions of people visiting here.
3. I think my post, along with others hopefully educated the dozens of people who will read this thread.
Liked 5,803 Times
Formed and welded lugs were quite common on middling quality bike frames from that era. Heck, lots of very nice frames out of France had pressed and welded lugs, you can even find them from time to time on eBay. A quick perusal of the interwebs shows this pic:
Some custom framebuilders in England stamped thin metal and wrapped them around tubes for reinforcement and/or decoration in conjunction with fillet brazing - the so-called "bilaminate construction". I recently had a very nice Gillott mixte come through my shop for some modifications that clearly show this feature.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Yup. That's not an investment cast crown. Advantage: they're lighter than an investment cast crown, but they have that ugly weld seam on the bottom.
Old fart
Liked 3,401 Times
Tange had their own line of welded crowns. The "CCL 1120" looks like the OP's crown:
Likes For JohnDThompson:
