Folding shorts
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
You need a bigger drawer or else move the non-cycling stuff.
Results matter
Results matter
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Normal people take care of expensive clothes.
Expensive cycling clothes like bibs, shorts, jerseys and vests get treated like any other fine or delicate garment - hand wash setting using Woolite in mesh bags designed for delicate fabrics, hung to dry, stored on a hanger in the closet.
Taking care of expensive things is hardly OCD.
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
So you're saying throwing them in a drawer without folding them. Like, just stuff them in there, like my seven-year old son does, and who invariably incurs the wrath of his very-annoyed mother.
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
Yes, basically, I try to fold them, but not very hard, it's probably different every time, then I grow them in the drawer that has enough room so they can not be squished...then I forget about them...It's kind of like folding a fitted sheet...yeah, I folded it, but it's not pretty.
Bikes: Specialized Tricross, Cannondale CAAD10
Quoted: 14 Post(s)
I roll my bibs. Fold in half along the center seam so the legs lay over each other, then roll from the bottom of the legs up. When you get to the top of the bibs then use the straps to hold it all tight in the drawer.
That is of course when they actually make it to a drawer, generally they get worn, washed, hung to dry with the jersey and then the cycle starts again before making it into a drawer.
Farmer tan
Hold chamois. Fold legs under chamois. Fold top under chamois. Stack in a pile.
must be winter
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
Quoted: 1096 Post(s)
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
You wash them, put in the dryer, and toss in a bin or drawer.
I've got some bibs over eight years old and the only thing that shows age are the white logos are faded.
Stand and Deliver
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
Usually about once/week wifey does the laundry and puts cycling gear in separate basket. I hang the bibs w/ jersey on the same hanger, which makes it very easy to grab and go. I don't waste time looking for the other piece if it's a kit. Socks go in the drawer. I have quite a few kits.
Quoted: 1186 Post(s)
Liked 289 Times
Except cycling clothes aren't like a custom made suit. You sit on bibs for hours at a time in heat, rain, sleet and snow. They get covered with dirt and soaked with sweat. The part that contacts the saddle including your upper legs undergoes constant wear and physical stress.
- Soli Deo Gloria -
Liked 736 Times
I follow the manufacturers care instructions the same way I would for any other garment.
Rapha:
Etc.
Rapha:
- Machine wash cool 30°
- Wash dark colours separately
- Do not tumble dry
- Washing a garment means putting stress on fabric and seams! Therefore, wash cycling garments separately from other clothes / accessories to prevent friction.
- Before washing, turn the garments inside out (seams on the outside).
- Machine-wash is possible but always use a wash bag, a delicate cycle and lukewarm water (max. 30° C).
- Do not use bleach and/or softeners. Use a mild liquid detergent only (e.g. ASSOS active wear cleanser).
- Do not soak, wring or rub. Do not spin after washing. To remove excess water from your garment gently squeeze by hand.
- Dry garments flat or hanging, but do not tumble dry.
- Machine wash at 30 degrees with a liquid detergent (we recommend non-bio detergents) using only a small amount of detergent.
- Do not use powder detergents or any products that contain fabric softeners, conditioners, stain removers or bleach as they will affect garment performance.
- Close all zips and turn the garment inside out
- Do not tumble dry
- Do NOT use a fabric softener on any cycling clothing! This can destroy the wicking treatments, membranes, water repellent treatments, antibacterial properties etc
Etc.
