Addiction 2021.3
#1801
VFL For Life
Bikes: Velo Volmobile
Quoted: 28616 Post(s)
Liked 1,857 Times
#1802
Quoted: 18416 Post(s)
Liked 15,556 Times
#1803
Bikes: Shmikes
Quoted: 10171 Post(s)
Liked 5,866 Times
#1804
Quoted: 20810 Post(s)
Liked 9,456 Times
#1805
Should Be More Popular
Quoted: 22599 Post(s)
Liked 8,925 Times
#1806
Quoted: 8281 Post(s)
Liked 9,046 Times
I have almost 40K miles on the Ultegra bb on the Gunnar. I've had it apart twice but never replaced a part in it. It's pretty worn. The other bike has Campagnolo Ultra Torque bb which is really simple. The bearings are on the crankarms which have over 40K miles. It's also been apart twice and one of the bearings is a bit iffy.
The mtb has some kind of pressed fit bb. It's over 3 years old and has been ridden in mud and wet sand and fine dust. It hasn't ever been serviced but it's very quiet and smooth. I was riding it 2 weeks ago and I could feel something dragging and thought it was the bb, turned out the lower jockey pulley was so gunked up I couldn't turn it with my fingers. Mr Maintenance strikes again.
When we used square taper bb with ball bearings I would actually service them but still wore out some cups and axles. I had a cartridge-type square taper on my touring bike and it started clunking bad in Kansas or someplace and I took it apart at a motel and wrapped electrical tape around it and hammered it back into the frame and it worked! My second touring bike had a Phil Wood bb that was given to me. The thing had needle bearings and a little plug you could remove to inject oil. Super cool except the crankarm bolts kept loosening.
#1807
Bikes: Shmikes
Liked 5,866 Times
#1808
VFL For Life
Liked 1,857 Times
#1809
Quoted: 10237 Post(s)
Liked 5,184 Times
#1810
Liked 5,184 Times
Likes For bampilot06:
#1811
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Thanks for the help bah humbug, and Mo. Ended up ordering the one mo posted from CC.com. Should arrive in a couple of days.
Sweat problems, mine have multiplied since I started wearing glasses. Seems like it constantly falls on my glasses now. Makes seeing kind of hard.
How long do bottom brackets usually last you guys/gals, and how often if at all do yall service them. Mine had 6877 before it went kapooie.
Mine has 5500 and is fine, I have the bearings replaced annually. Wear something on your head for sweat? I have an issue with it too.
Likes For phrantic09:
#1813
Liked 9,046 Times
#1814
Liked 8,925 Times
I think so too.
But I am spoiled as all my road bikes have "standard" threaded bottom brackets which last a long time and are stupid easy to replace. So simple, even a caveman can do it.
#1815
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,900 Times
I've found that wearing a skull cap at an angle that leaves most of my forehead uncovered, plus squeezing the sweat out of the pads with my head tilted to one side, then the other, works for me. It may disgust anyone seeing an old guy squeezing sweat out of his helmet, but it beats having it run down the inside of my glasses. I tried a Sweat Gut'r headband under my helmet, but it didn't seem to work. I think the helmet squeezed the gutter closed at the ends, so all it did was to build up sweat till it poured over the rim.
Luckily, it's generally dry enough out here, especially when it's hot, that I don't have constant rivers of sweat running down my face.
#1816
Liked 11,900 Times
My current approach to BB bearings involves spreading my riding out among so many bikes that each one only gets a maximum of a thousand or so miles. The Canyon, which I got last July, and which has been my Sunday bike, only has about 1700 miles on it, for example.
#1817
Liked 9,046 Times
So if I buy enough cars I will never have to do another oil change?
Likes For big john:
#1818
Bikes: Shmikes
Liked 5,866 Times
Yup. When the time comes to replace the bearings in my plastic bike's BB, I will buy the tools, but only to save the bother of dealing with a bike shop and not having the bike for a week.
#1819
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Stung by something while riding in the dawn, and now work is being stupid. #caseofthemondays
#1820
VFL For Life
Liked 1,857 Times
datlas do you prescribe biologics to any patients?
#1822
Fat n slow
Liked 2,085 Times
Work being stupid is the story of my life - at least you got to ride today, I got to spend my morning learning that at 41 I have significant hearing loss on one ear and likely need a hearing aid unless an MRI turns up a mechanical cause.
#1823
Liked 9,046 Times
#1824
VFL For Life
Liked 1,857 Times
Any reason?
