GoPro external power option
Quoted: 829 Post(s)
Liked 1,671 Times
I have two GoPro cameras on my bike - one forward facing, one rearward facing. However, I found the battery life wasn't all that great, especially in hot weather, and stopping to change batteries (and carrying extras) was becoming a PIA.
I found some aftermarket battery doors on Amazon that have openings to allow you to plug in a USB cable to power the cameras externally. Of course, they are no longer waterproof with that option, but I seldom ride in the rain, and if I get caught out, I bring Ziplock baggies.
My Garmin is on an 'out front' mount, with the optional external Garmin battery pack underneath. I run a USB from that to the front camera. For the rear camera, I picked up an Anker PowerCore 5000 and used some Garmin mounts (with bands) and cellphone case adapter mounts around the seatpost and pack to attach it under the saddle, and run a USB cable to the rear camera.
It works great! Not having to stop to change batteries is such a relief. I was always concerned that the battery would die before I got a chance to change it out, and of course, that would be when some incident occurred that I would have wanted to get on video.
Quoted: 5227 Post(s)
Liked 3,596 Times
Quoted: 829 Post(s)
Liked 1,671 Times
Front setup with Garmin 1030 on top, Garmin external power pack below on out front mount. USB from the external pack powers the GoPro, which mounts on a bracket that also accepts a Bontrager Flare daytime headlamp.
Rear setup uses the Anker external supply with two Garmin 1/4 turn self-adhesive phone case mounts and two handlebar 1/4 turn mounts on pack and seat post. USB runs under the saddle to the GoPro, mounted on an extender arm under the seat bag. A Varia radar unit mounts below the arm mount on the seat post.
Liked 3,596 Times
Quoted: 5 Post(s)
Thanks. I value the cameras ever since I was struck from behind by a vehicle that decided to just drive off. Video goes a long way.
Quoted: 829 Post(s)
Liked 1,671 Times
There have been several threads on various platforms regarding the Cycliq cameras. The "new" versions have had complaints of water intrusion, leading to camera failure. Cycliq customer service, according to those that have needed it, is not exactly exemplary.
Quoted: 829 Post(s)
Liked 1,671 Times
Just be aware that once you change the door on the GoPro to allow the external power cable to attach, the camera is no longer waterproof, so if it starts to rain on a ride, you MUST stop and either reinstall the original door with an internal battery, or stuff the cam inside a plastic bag.
Quoted: 2281 Post(s)
Liked 1,710 Times
My camera sits inside a waterproof case, so it would be very hard to run external power to it. However, I did buy a set of batteries for it (since the one which came with it seems to be going bad, dies after around an hour) so I can keep going for a while. However, it's a PITA that every time I install a new battery I have to reset the date/time on the camera. All the rest of the settings remain the same, but for some reason the clock doesn't appear to be backed up.
Quoted: 5 Post(s)
