How do you steer?
Quoted: 696 Post(s)
Liked 910 Times
How do you steer?
If your going to take a left do you push down on your handlebar with your left hand or nudge the the bar from the right?
Quoted: 4227 Post(s)
Liked 2,488 Times
This should be entertaining...
Likes For wolfchild:
Quoted: 3956 Post(s)
Liked 7,304 Times
Left rudder.
Likes For tomato coupe:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 921 Times
Push forward with the left hand to initiate or tighten a turn left.
I think this action, called counter-steering, is more obvious to most motorcyclists than to most bicyclists.
Likes For Fredo76:
Quoted: 2485 Post(s)
Liked 2,956 Times
I steer the way any sane person would. Obviously.
I accept that counter-steering may technically be involved in steering any two-wheeled, one-track vehicle, but I believe that only bicycle riders who are also motorcyclists ever deliberately counter-steer their bikes. I certainly never did, including during my racing days. I valued traction on twisty descents too much.
Likes For pepperbelly:
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
As Fredo76 said. Motorcyclists are well aware of counter-steering and consciously utilize it. Bicyclist who are not motorcyclists "just ride" by intuition and let the rest sort itself out. Blissfully unaware of the physics involved and how to consciously utilize them.
Counter-steering will make you faster anywhere there is speed plus corners.
Likes For base2:
Quoted: 4415 Post(s)
Liked 4,871 Times
I dunno. I'd have thought you valued pointing the bike to the optimum line and making any sort of correction necessary even more.
Likes For PeteHski:
I am potato.
Liked 1,631 Times
PeteHski Well, If you don't care to know how to avoid an unexpected pothole or that last second ride ending bit of road debris at speed...I don't know what to tell you.
The biggest skill in a motorcycle endorsement class is how to utilize counter-steering. The test is designed to achieve basic competence for your own safety. A single failure. A single cone touched. You fail. You will not be licensed to ride a motorcycle today. The skill is a real thing.
...And you're right. Steering should be unconscious. 6 year-olds do it. Many adults ride their entire lives effectively with the skill of a 6 year-old and get along ok.
But, if you are the unskilled 6 year old adult, you are going to panic, freeze, hit that thing, or run off your line simply because you don't have a conscious practiced understanding of how to recognize the hazard and consciously effect the necessary correction.
That's the difference between rider and operator.
Quoted: 9653 Post(s)
Liked 6,365 Times
I drift thru turns.
Likes For Mojo31:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Without trying to overthink this, I have to go with nudge.
Liked 4,871 Times
But my point is that any decent bike rider will subconsciously counter-steer regardless of whether or not they ride motorbikes.
Likes For PeteHski:
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
Oh god, not this again…
This is countersteering:
Anything else one might do at the bars should not be called countersteering, just for clarity’s sake.
Of course, as amply noted in other threads, one needn’t touch the bars at all to steer a bike, and as seen upthread, handlebars are not the only way to steer if you do use hands, which gives lie to the claim that one has to countersteer if they ride a bicycle. Here’s a steering wheel bike in action:
Liked 2,979 Times
aimlessly & as speeds increase, willnilly. add in challenging surfaces conditions, it skillfully goes haphazardly.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Liked 4,871 Times
https://youtu.be/2Uzm--BxzMw?si=WTDvTHyE9QeXTpNm
Pennylane Splitter
Bikes: Yes
Quoted: 1804 Post(s)
Liked 1,444 Times
Once I get up to speed and don't have to slow down very much ts usually leaning into the turn. At slow speed its turn the handlebars as required with both hands. Is this something the OP finds mind-blowingly complex?
Likes For skidder:
Quoted: 18424 Post(s)
Liked 15,573 Times
I don’t think about it. I just do it.
Likes For indyfabz:
I am potato.
Liked 1,631 Times
I guess so much of the contrarian ignorance relates to the difference between steering a 2 wheeled thing and being in control of it.
One of the posters here in this thread also doesn't believe wheels have gyroscopic effect and that effect (if any, apparently) changes the feel and responsiveness of a bike.
I'm out. Stupid is the refusal to learn.
Liked 4,871 Times
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
One has to steer a bike? Telepathic Magic, perhaps.
Liked 7,304 Times
At any speed above walking pace, counter-steering is used because of the effects of gyroscopic precession of the spinning front wheel. Even if you are not aware you are doing it.
Try two things :
1) Riding straight at a moderate pace with plenty of room around you, ( very carefully ! ) slightly nudge the left bar forward ( i.e. "turn right" ) and be prepared for the bike to lean to the left as in a left turn.
2) Take a removed bicycle wheel, spin it fast and hold it by the axle ends. Holding it up in front of you with the wheel vertical, turn it slightly to the right. And then you'll see why you turn the bars to the right, to initiate a left turn.
p.s. I think counter-steering is only used to initiate ( and exit ) the turn. Once the bank and turn are established, the handlebars may even be now turned ( slightly ) in the direction of the turn. And then to leave the turn, you have to counter-steer out of it.
Try two things :
