Re riveting a cassette
Quoted: 561 Post(s)
Liked 651 Times
I was mis shifting and thought I bent a ring.
Upon inspection I notice one ring was completely loose of a rivet.
I guess I could re rivet the whole damn thing.
Is there any obvious reason I should not?
Quoted: 4212 Post(s)
Liked 3,883 Times
Yes. You might not have the tooling or skills. or you might not be able to create a rivet with the minimal heads that the common cassette ones have. (Specific rivets for the application using distinct anvil and die for forming the heads just so. These are no pop rivets. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 811 Post(s)
Liked 1,024 Times
The rivets are to keep the assembly together at the factory. You don't really need the rivets and I have removed them when I clean a cassette. All the cogs must be flat. If one of them is bent or otherwise out of shape, it might be easiest to get a new cassette.
Likes For Velo Mule:
Liked 3,883 Times
Unless the rivet in question is joining the cog with a spyder/carrier. Andy
AndrewRStewart
AndrewRStewart
Quoted: 811 Post(s)
Liked 1,024 Times
So, @CrimsonEclipse, can you get a picture. Everything works better with pictures.
Quoted: 561 Post(s)
Liked 651 Times
Ahh, good point. I was thinking straight through rivets. I didn't think about those spider rivets.
Rivet pulled out.
There's room for a standard solid rivet head between the cogs and won't interfere with the chain.
Yeah, it's a carrier connecting the 3 largest cogs.
None of the cogs look bent, just the third one pulled loose.
edit:
Steel rivet, 4.3mm or 5/32 diameter.
Not sure I want to replace a solid steel rivet with an aluminum one.
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,386 Times
...McMaster Carr sells solid steel rivets, and it's not that hard to do a not so neat job of ponding one in there, and doming the insertion side.
But I'm not sure of the minimum quantity, which might cost you more than a new cassette. I would try my local commercial fasteners place, where they sell stuff like this in whatever quantity I request.
Quoted: 4423 Post(s)
Liked 1,569 Times
I doubt an aluminum rivet will fail before the cassette is worn out.
