Testing an S/A Dyno Hub
Quoted: 887 Post(s)
Liked 335 Times
I have an opportunity to buy a bike with the affore mentioned hub. There is no wiring or light. The wheel seems to be a repalcement. So my question is how do I test the hubs output?
Is a VOM set to AC voltage adequate, and what reading should I expect to see with a vigorous spin of the wheel?
Quoted: 964 Post(s)
Liked 1,451 Times
The Old Way was to put a screwdriver across the terminals to short them, give the wheel a vigorous spin, and pull the screwdriver blade a minuscule amount away from one terminal. You should see and/or hear a tiny spark jump the gap. Might take a few tries if it's your first time. Can also do it with a wire if you have one handy. Also, when it's shorted, you will notice more drag and vibration via the axle if you don't have it securely clamped in the dropouts.
It is not harmful to short a dynamo like this. Well, it might heat up if you shorted it and then went on a ride for half an hour.. They are naturally current-limited by the gauge of wire used in the windings, so no damage will occur, unlike when you short a battery (which will try to supply all the amps you can draw from it, right up until the battery explodes).
Digital voltmeters tend to be unreliable for this sort of thing. The voltage and frequency will be varying all over the place as the speed of the wheel changes, and it can be hard for a digital meter to follow. I prefer an analog meter if I'm measuring a dynamo, but in practice I rarely have needed to.
Likes For scarlson:
Quoted: 1829 Post(s)
Liked 3,376 Times
With a literal volt-ohm meter, then you can always check the open-circuit voltage. The problem is that this voltage is mostly proportional to the wheel speed, so the value could be anything. If you can connect a resistor that is close to 12 ohms to the terminals, then an output voltage of 3VAC or more is probably a good sign (but again, I'm not certain exactly what the output of these is).
You could also use the ohm-meter to make sure that there isn't a break in the dynamo's wiring.
The problem with the SA dynohub that I've heard of is demagnetized magnets. This will result in reduced power output. To measure this, you'd need to either measure output current or else connect a known suitable resistor and measure the voltage across the resistor.
The alternative to using a meter would be to short out the dynamo terminals. If it is working properly, it should produce a significant drag when spinning. This is very obvious with the Schmidts that I own. Not sure how obvious it would be with the dynohub, but you should notice a difference between the open-circuit and short-circuit drag.
Steve in Peoria
Quoted: 887 Post(s)
Liked 335 Times
I have a digital meter that can measure current, and with that, the most meaningful measurement would be to measure the current out of the dynamo. With a modern dynamo, it should be producing 400mA or more at decent speeds. I know that the SA dynohub produces less power, so maybe 250mA to 300mA?? edit: obviously, this would be a measure of AC current. If the meter is set up to measure DC current, the reading will be zero.
Steve in Peoria
Steve in Peoria
Likes For dweenk:
Liked 3,376 Times
Even with a bulb, it would be good to measure the voltage across the bulb, to know if the dynamo output is up to spec. Of course, you'd have to know the spec... and I haven't looked it up.
Isn't the dynamo output rated at 1.8 watts or something? I don't know if that is 6v at 0.3A or some other combination of voltage and current.
Steve in Peoria
blahblahblah chrome moly
Quoted: 1176 Post(s)
Liked 2,572 Times
a simple bulb could work if it is the right bulb. I'm not sure how easy it is to find the right bulb. Basically, it should be rated for the voltage and current that the dynamo produces.
Steve in Peoria
Steve in Peoria
I've used Dyno-Hubs with the original correct incandescent, and the light is somewhere in the paltry to pitiful range.
Mark B
Liked 3,376 Times
I use a B&M IQ-X on mine, and it gives a lot of light. It's probably not as bright as the same lamp on a modern hub, but without doing a side-by-side comparison, I'm not sure if I can tell the difference. I was pleasantly surprised by how bright it is, very usable, better than a modern dynamo with an incandescent bulb.
Mark B
Mark B
https://www.sheldonbrown.com/dynohubs.html
I fully agree that dynamos with incandescent bulbs produces a barely tolerable stream of photons.
How did we ever survive? Of course, I do recall augmenting my little Jos block dynamo with a Cateye Micro II light. Between the two of them, I managed to see most potholes and roadkill.
Steve in Peoria
Bikes: N+1
Quoted: 229 Post(s)
Liked 652 Times
I've heard favorable comments about using modern LED headlights with dynohubs from other sources too. It also suggests that the dynamo is producing 6v with that load. A further reading of Sheldon's (and John Allen's) info on the dynohub does specifically state that it is intended to be a 6v dynamo.
Steve in Peoria
Steve in Peoria
Surely you're not implying that the depiction of the amount of light cast by vintage dynamos and bulbs in these vintage advertisements is hyperbolic?
Likes For JulesCW:
Liked 3,376 Times
But... to some degree, if you are accustomed to feeble headlights, you'll be happy with something slightly less feeble. Another factor is the ambient light environment. If you are having to deal with the feeble headlights of cars with 6v electrical systems, these vintage lights might not be that bad. By comparison, I see so many modern cars with really bright headlights that are blinding. There's also the tendency of people to turn on their fog lights as a regular driving light. Terrible.
Even with my feeble Jos block dynamo, it wasn't bad on really dark roads. Once your eyes adapt to the dark, not that much light is needed.
Steve in Peoria
Likes For steelbikeguy:
Palmer
Quoted: 1668 Post(s)
Liked 1,821 Times
Ah, you, my friend, need a Dynohub™️ Tester!
Manual @ https://www.sturmey-archerheritage.co.../view-1013.pdf
Likes For tcs:
Palmer
Liked 1,821 Times
6V @ 2W until the early 1970s, 1.8W afterwards. There are questions as to whether this was an actual down-rating or just a change in test method.
Sturmey-Archer developed an updated and improved 3W Dynohub in the late 70s/early 80s, called the XAG. This was shown at cycle trade shows in 1982 to positive reviews but - if you know anything about the history of Sturmey, you know where this is headed - they never put it in production!
Fun fact: the GH6 was introduced in 1946, replacing pre-war 12V and 8V models. Despite post-war shortages and supply chain disruptions, by early 1951 the factory was making 12,000 a week!
Likes For tcs:
Palmer
Liked 1,821 Times
Likes For tcs:
Ass suggested above, there should be 6V of output with a 20 ohm resistor connected, or a little over 300mA short-circuit current. It is hard to get a good measurement while spinning by hand. One method I have used is to use the chuck of a variable-speed electric drill as a roller on the tyre. For comparison, I measured internal resistance at 6.5 ohms and inductance 86-108mH, varying with wheel position.
Likes For markk900:
Quoted: 887 Post(s)
Liked 335 Times
Thanks all. I'm going to do some reading of St. Sheldon and decide whether or not to buy the bike.
Quoted: 1858 Post(s)
Liked 664 Times
I agree with a lot of what has been said here. One thing that I think is needed is to emphasize that if you only want to check that the generator is functioning, the VOM needle movement will show that it is really producing voltage, even if the wheel speed is not steady. If you can spin the wheel steadily you should get an AC signal which will look steady on the VOM. Because the meter is mechanical, its response is far slower than for an electronic AC voltmeter. If you look at the signal with an oscilloscope, it should look like a clean sine wave or one with some kind of distortion or spiking at the peaks, due to magnetic hysteresis and saturation. If there's too much weirdness the generator might be no good, or have the magnets out of place in ways that might be hard to understand without a good set of blueprints or CAD.
Liked 664 Times
To confirm that, the inductance is at a minimum in a stable position of the wheel, where magnet and stator poles should be aligned and the flux path has maximum length. (I had to look up the definition of reluctance!) That was an at-home measurement: wall socket, transformer, resistor, multimeter and Pythagoras. So probably not very accurate.
You can also test for continuity before the test. The magnets should almost be able to be felt as you gently rotate the wheel, not much but noticeable. That's a good sign right there. Continuity, some magnetism, good signs it's a keeper.
Not many bulbs on the market that are compatible with it's low output. For mine it runs the rear light (cool factor), and I use a separate rechargeable LED for the front.
Palmer
Liked 1,821 Times
Right, incandescent, but the Dynohub™️ lights up modern LED headlamps just fine. I've got mine wired to a B&M OneFive, and Bulgie upthread reported energizing the uber photon cannon IQ-X.
Likes For Greg R:
Palmer
Liked 1,821 Times
So long as we have a Dynohub™️ thread, let's talk about...threads!
The GH6 (front hub!) Dynohub axle is a 3/8x26tpi. The threads on the terminals are 2BA, a British spark plug thread size.
Now, you're probably asking yourself, 'Self, why is his axle so long?' Well, I'll tell you. Some of the GH6 Dynohubs were built for the old roadster bike front OLD of 90mm. Yeah, that's not long enough to fit in a standard 100mm OLD fork. So I replaced the axle in this NOS Dynohub with a generic one - but, and it's a big but, on a Dynohub axle, one of the cones screws down against a stop. On the generic replacement axle I simulated this with some blue Locktite.
Likes For tcs:
