Do patched road tubes last?
Quoted: 196 Post(s)
Liked 12 Times
I don't flat too often and have always had a stash of new tubes around, so when I would, I'd just put a new tube in and carry on, never giving patching a thought. Now that tubes are getting little pricier, I'm wondering if a patched tube will last, because I have several in a pile with a single small hole in each. A new tube is around $10, whereas a patch kit (like Park's) looks like it might cover 2-3 tubes for $10. But do patched tubes really last long? If they do, is there any specific kit you all would suggest for longevity?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Yes, a tube properly patched with a Rema kit is as good as new, and will last until something else takes it out.
Likes For ThermionicScott:
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
A properly patched tube will serve you as reliably as a new tube would. I never throw away a tube unless it has a valve stem issue or large tear in the rubber - they get patched and put back into rotation. I typically will put in a fresh (new or previously properly patched) tube on a roadside flat repair instead of patching a tube on the side of the road, unless I have a ride with more than one puncture. I will bring the damaged tube back to the garage to assess and repair, normally waiting until I have a few tubes needing patches, and doing them all in one sitting. This gives a better chance of being able to use all of the vulcanizing fluid in the patch kit before it evaporates.
In my experience, the Park patch kits are pretty good. My preferred are the Rema Tip Top kits, but both work well. Just make sure to get a proper repair kit, and not the patches with pre-applied adhesive (like stickers). Those are no good and will fail.
Likes For SalsaShark:
Quoted: 1438 Post(s)
Liked 1,092 Times
The key is to use a good vulcanizing fluid, which causes a chemical reaction that fuses the rubber pieces together, NOT ordinary rubber cement.
I’ve patched lots of tubes, and patches work perfectly well. Park patches and cement do a good job, just make sure that you prep the tube (roughen up the rubber around the puncture) with the included sandpaper or scraper, and let glue set before putting on the patch.
Likes For 50PlusCycling:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
If done correctly, a long time. IME, that is true for both vulcanized and glueless patches. I have both on tubes that have lasted for a couple of years. I have one tube that has 4 patches on it.
Quoted: 427 Post(s)
Liked 700 Times
As others have said, a patched tube-using good vulcanizing and fluid and a Rema patch will last. If it's the front tube that was patched, I'll usually move it to the rear and put a new tube in the front. That's just me though, probably not necessary. I've never had a patch go bad.
Quoted: 2604 Post(s)
Liked 1,933 Times
Yes, a well patched tube will hold air just as well as a new one.
IME preparation is more important than the specific patch kit brand. You've got to get the mold release off the tube before anything will stick to it, so use your grater or sandpaper to get all the "shiny" off around the patch. I've used Rema glue in the patch, but now I'm using Slime from the auto parts store, and I haven't seen a difference. Had to ask for another box of 100 Rema patches for Christmas last year, I finally used up the first box.
Glued-on patches, I usually have something go wrong (like a blow-out, long cut, or the stem starts leaking) before I accumulate more than a dozen or so patches. That's probably over five years of service (I don't label tubes!). Glueless patches usually last me 2-3 years before they start to leak.
I usually accumulate a half dozen leaking tubes (replacing them on the road) and patch them on a rainy weekend. Sand one, put the glue on, sand the next and put the glue on that, go back and put the patch on the first, and continue. I'll do an overnight leak test the next day. Oh, one more tip: get yourself a sliver Sharpie to mark the hole, especially if it's a small leak you need to find in a sink full of water.
Likes For pdlamb:
Quoted: 581 Post(s)
Liked 921 Times
'Vulcanizing' patches (separate cement-and-patch patch kits), in my experience, are as good as a new tube when properly (tube scuffed, cement left to dry before applying patch) applied.
Also in my experience, 'glueless' patches are crap. They might work for a while but I wouldn't trust them for any bike I needed to be reliable. Others have had better experience with them, but I have tried multiple brands on different occasions and was never satisfied - the extra one step and ~3 minutes to apply a traditional patch is worth the effort a million times out of a million.
I also carry a known good (new or patched) tube as a spare when I ride, as well as a patch kit. While patching is an almost 100% reliable fix, it's no fun on the side of a busy highway or in the pouring rain.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Yes. Good as new.
Unless they are the peel and stick “glueless” kind. Those usually don’t hold up long term in my limited experience with them.
Liked 2,973 Times
I consider how frequent I experience getting a flat & for where/what type of riding. Justifying the cost of patching or replacing has those areas to consider for me. Keeping the damaged tubes around until I accumulate enough to open the sticky messy patching fluid can take a while, & I don't have a good spot to store them that keeps them conveniently out of the way.
-Oh Hey!
-Oh Hey!
Quoted: 137 Post(s)
Liked 81 Times
Store old tubes in a zip lock bag. In my racing days I used to store and install tubes with talcum powder but in the last 30 yrs stopped using talc as I stopped racing, rode less and tires became more puncture resistant
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
A good quality patch (I prefer Rema, but there are others) properly applied can last the life of the tube. A compelling reason to replace a tube would be a blow-out too large to patch, or a leak in an unpatchable location, such as at the base of the valve stem.
Quoted: 2975 Post(s)
Liked 1,182 Times
https://www.parktool.com/product/super-patch-kit-gp-2
I have used them on long road rides and they work. Had an incident last year on a 100 mile ride where I got flat and put in my spare tube then 30 miles later got another flat so had to use the patch kit I carried. The patch held up fine for the rest of the ride and few rides after until I put a new one back in.
I'm the type that thinks tubes are cheap...buy most of mine from e-bay for $5-$10...So any tube that has been punctured I eventually throw it away. Eventually just going to switch my road bike to tubeless and be done with tubes just like I am on my mountain and fat bikes.
Liked 2,568 Times
Then I crack open a 3-gram tube of glue and see how many I can patch with it.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
It goes a bit further than that. Cold vulcanization is a 2 chemical process much like epoxy. The fluid has one chemical and the patch has the other. If you use vulcanizing fluid without a patch that has the matching accelerator, the vulcanizing fluid is about the same as rubber cement. Rema is the only system that I can say with certainty that uses the 2 chemical process. Most all of the others are just rubber cement.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 114 Post(s)
Liked 119 Times
The only time I have trouble with patching is when the hole is adjacent to a seam in the tube.
But otherwise (as everyone stated already) properly patched tube is completely reliable.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
I also put punctured tubes in a box and patch them all at once, with a new tube of glue. I never keep opened tubes of glue, they just dry up eventually.
Additional tools:
a silver sharpie. I draw a 4 long lines pointing to the hole, so I know where it is if it's tiny. And it's easier to center the patch, too.
Real sandpaper! that tiny scrap in the patch box is annoying to use. I'll use a piece of 100 grit or 150, whatever I have. So much faster!
I use a corner of the the plastic patch box to press down the patch thoroughly. A screwdriver handle would be good, too.
(I clamp the finished patch with a woodworking spring clamp for a few hours. I don't know that it actually helps, but its easy to do.)
Test the patched tube on the wheel at home, then I treat it as if it's a new tube from then on.
Additional tools:
Quoted: 837 Post(s)
Liked 1,061 Times
One trick is to fold the tube so the seam is on the edge of the fold and sand away. Faster and easier than sanding a seam in the middle of a flat section of tube.
Likes For Crankycrank:
Likes For icemilkcoffee:
Likes For 10 Wheels:
As a kid I in New Mexico I had an old Schwinn cruiser. New Mexico is infamous for “goat head” stickers or thorns, these puncture both bike tires and bare feet with ease. The tubes in my old Schwinn were covered with patches, the rear tire had 18 of them. They still held air quite well.
