Looking for Shimano 105 simple solution
Bikes: 2007 Kona Jake the snake, 2014 Specialized Epic Marathon
Hello all,
Currently running a stock 2007 Kona JTS { high vis green/lime) sans a 34T chainring I swapped to replace the stock 36T upfront.
So, stock is 105 drivetrain, 10 speed, short cage RD, 10 sp 105 shifters, 2x up front. I'm seeking better climbing capabilities (I haven't ridden for a bit due to the ankle biters at home) and have a bikpacking trip (my first) coming up so need to get this dialed.
I purchased the below to allow for a wider range,
-Shimano 105 RD-5701-GS RD
-Shimano 10sp chain CN-HG95 -Shimano 105 CS-HG700-11 11-34T cassette
So first and foremost is there any way to make this work?
10 sp shifter v. 11 sp cassette?
If this will not work any suggestions as to the most simple and affordable fix at this juncture?
Is there one of the above components I can swap out to make this combo work?
I am really after the 32T but preferably a 34T cassette range.
Thanks for the input!
Likes For bboy314:
Quoted: 6193 Post(s)
Liked 4,809 Times
You need a 10 speed cassette. The 11 speed cassette will only be useful if you love to tinker, have great mechanical abilities and can improvise stuff to make a half-arsed solution work well enough for you and you take great pride in such things.
What is your rear DR. That will most affect the largest tooth count you can put on the cassette. If it's a Shimano DR, then the part and version number will be printed on the back of the parallelogram. It'll be real hard to see if it's gunked up. But from the other side of the wheel, a camera zoomed in on it and a good light, you might see it.
You might very well be better off getting a new crank with smaller still ring or rings. Is this 1x or 2x? Still a drop bar with STI's or some other type bar with independent shift levers a brake levers.
Quoted: 581 Post(s)
Liked 921 Times
As above, no there is no simple way to make a 10sp shifter work with an 11sp cassette (no way at all AFAIK - there aren't enough clicks). You need a 10sp cassette, or an 11 sp shifter.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Why would you buy an 11 speed cassette?
Likes For cxwrench:
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
As others said, you need a 10 speed cassette.
Your drivetrain has the "old" cable pull ratio for RD (as opposed to the "new" one of Shimano 11 speed road and 10 speed 4700 series Tiagra). This pull ratio is also shared by almost all road/MTB RDs up to 9 speed. I am saying this because something like Shimano RD-M591 or Microshift M46 RD (I had a very good experience with the latter, caveat is that I run 9 speed) may work for you, it will have even higher chain wrap/largest cog capacity. If it works you will be able to fit a 10 speed 11-36 cassette.
I appreciate all the quick replies. I will order a Tiagra 10sp cassette and call it good. When ordering the new hg700 cassette I was thinking I would remove the spacer and perhaps a cog to get the 10 sp effect. Lesson learned.
My stock RD is a Shimano 105, 10-speed, short cage.
Quoted: 1944 Post(s)
Liked 2,164 Times
You don’t need a Shimano branded cassette, you can use a Shimano compatible cassette which include SRAM and the lower priced Sunrace.
This does allow you to find the gearing/gapping that suits your objective.
Your RD-5701-GS is rated at 32t max cog. Shimano is generally conservative and you can probably run a 34t. Pushing it to 36t night be tough, but it is more hanger dependent of the specific bike. Some work and some don’t.
John
John
FWIW: Jenson USA had at least one type of Microshift 11-32 10 speed cassette (w/o "spider") in stock as of about 5 min ago. Price was about $27 plus S/H.
I've heard good things about Microshift products, so that might be an option if you have trouble finding a Shimano cassette at a reasonable price.
I went with a 46/30 front and a 12-30 cassette on my gravel bike. Works great.
Really Old Senior Member
John
John
So I went with a Tiagra HG cassette 11-34t, 10 speed. Im feeling optimistic it will work with my 105 gs RD and of course a new chain. I'm going to tackle this project tomorrow when the goods arrive!
