Splicing cables together?
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
I got new handlebars and the shifter cacle is now a couple inches short. I can't buy any at stores here atm and already have plenty of extra cables and I don't want to buy online and have to wait. I was thinking of getting some copper tubing from home depot and crimping it together but that might be a bit expensive depending on how much I have to get. Anything better for this that would probably be at home depot?
Quoted: 18407 Post(s)
Liked 4,530 Times
That would be quite a hack. Most of the Home Depot tubing is quite large. Perhaps thermostat tubing scrounged out of something? I know I've seen coils of small tubing, I think. Maybe refrigerators? Or, Washing Machines?
Is your cable stainless or galvanized? I've found it more difficult to solder stainless cable than galvanized.
Anyway, I'd just hunt down the cables you need. Most department stores will sell cable kits, albeit cheap kits. Keep what you need and toss the rest. I haven't checked bike shops, but I thought some were open.
If you hunt, you can also find thin bulk cable. You may be able to solder on a solid end to the cable. I think I've seen some Youtube videos.
With a mighty wind
Quoted: 1108 Post(s)
Liked 903 Times
Possible, yes. Practical, no.
You can pretty easily extend housing with a double ended housing ferule. You need this or it can't be done.
For actual shift cable or brake I guess (if you're a maniac), you need a couple special things.
First, a miniature Nicopress tool. Pliers or a hammer might work, but probably not in the space you're working in. I have this tool, I use it to repair a specific piece of rock climbing equipment.
Second, you need swages that perfectly the cable. I don't know what size that is but they can be ordered in lots of 50 or so. I do know they're quite a lot smaller than the garage door swages available at the hardware store.
You should probably run 2 or 3 in a row for security. You also have to have this set up on a fairly long run of exposed cable. Probably the downtube. It's also got to be the last thing you attach, since it won't run through housing. Finally, it'll probably scratch your frame, so wrap them or frame with something.
Or you know, order an $8 cable and wait a couple days.
Quoted: 6255 Post(s)
Liked 4,857 Times
I can't imagine copper crimps holding well enough.
Whatever you do, get the replacement cables on their way so your temporary fix only has to be temporary and as brief as possible.
You might take a small bolt and drill a hole in the shaft and then run a nut down on it to use as a cable clamp. Probably need two or three then cover with plenty of electrical tape to keep from scratching up the down tube.
Liked 4,530 Times
I usually pay $1 to $2 on E-Bay, and buy a few spares but then the wait may be shipping from China which can be sporadic, especially now.
I generally choose stainless cable, but galvanized can be used in a pinch.
One can often recycle rear derailleur (or brake) cables to be used in the front, but you'll still need new cables.
Oh, were you talking about cable housing? The department store kits will generally come with unlined housing. Generally very little choice in colors. Black?
Liked 4,530 Times
They'd probably hold for shift cables (not necessarily brakes) if one either soldered the cable into a 1" or 2" copper tube that fit tight. Or, perhaps a larger, shorter "crimp", and made sure the cable was ,looped back through the ends of the crimp.
It is common to spice eyes into fishing and logging cables. It would be curious if a similar splice would be stable on bike cables.
Quoted: 428 Post(s)
Liked 67 Times
I have grip shifters but they don't really work well with my new handlebars so I will probably get something else but I am not sure what to get yet. I also don't like the crappy grips that go with them anyway so have been thinking of replacing them already. For now though I just want to get this going for today. It would be a little silly to get a replacement cable now and then throw it out later if size or color is wrong, and last time I went to walmart the shelves were totally bare so I don't think that's happening anyway.
Walmart? that might be your main problem.
Quoted: 254 Post(s)
Liked 182 Times
Is there any point at which you could remove a couple of inches of housing without affecting performance? That effectively gives you a couple more inches of cable.
Quoted: 2345 Post(s)
Liked 2,860 Times
this is the type of hack that a) would be crazy to even try to brake cables b) might, maybe, if you are luck work for shifter cables.... If i were to have to macgyver some think, I would find very small cable crimps and I would not try to do in line, instead I would make would do 2 loops forgive the terrible graphics, but this should give you the idea cables looped in red, crimps in blue. Soldering cables has never been successful in my attempts
Likes For squirtdad:
With a mighty wind
Liked 903 Times
It's a fun thought experiment.
We all know that a piece of copper or whatever tubing in that diameter wouldn't come close to being strong enough. We also can pretty much assume this is beyond the OP.
I'm talking about a $50-75 tool with extremely limited use. Plus the swages and shipping time.
I don't think there is anything in home Depot that would get this bike on the road today.
Quoted: 1572 Post(s)
Liked 644 Times
What kind of shifters? Indexed shifting (assuming you want it to continue indexing) = a home made splice isn't going to work. Actually, there are cable splicers that are used on bikes that have S&S take apart frames. They actually work without needing to be adjusted each time but that would still require buying an additional replacement cable plus the splicer. The fastest, easiest and cheapest way is to simple replace the cable AND THE CABLE HOUSING with new.
One of the things about modern derailleur bikes that amazes me is how precisely and reliably they shift tiny amounts of cable.
Quoted: 1438 Post(s)
Liked 1,092 Times
Quoted: 428 Post(s)
Liked 67 Times
I have plenty of housing left over from before just no long cable, so that is not an issue. And it's just for the shifter not the brakes. I already cut the cable and made new housing for the front that works and will just keep the housing on the back in place. I will crimp the cable in the middle where I already cut and where there is no housing just cable, make it as tight as possible and then adjust the rear deraullieur as needed. So basically it will be two splices inside a single copper tube (unless anyone else has better idea for equip I can use available at home depot). Indexed shifting should still be fine because there should not be any play at all in the crimp if anything it will be more solid not less.
Liked 2,860 Times
Why the loop? Two or three swages in line would be as strong or stronger than the cable.
SE Wis
Quoted: 2751 Post(s)
Liked 3,408 Times
Likes For dedhed:
Liked 4,857 Times
Got a marine store near you with a lot of rigging supplies? The 3/64ths version of this might work. 3/64 of an inch is only about 3 thousandths bigger than a 1.1 mm shift cable. I've never seen any this small at HD or Lowes, but I've never looked for very small ones.
https://www.jamestowndistributors.co...uct.do?pid=288
Crimping properly without crimpers might be an issue though. I'd use at least two.
With a mighty wind
Liked 903 Times
I think attached loops would be weaker.
Yes a loop is stronger, about double. That's completely dependant on the swages strength. It wouldn't change regardless so it's unnecessary.
This is the sort of thing to do for a 4 person tandem or some other crazy fun. Not something the OP can or should do.
As for strength, judging by the absolute weakest scary aid only climbing gear, those bits have really similar diameter cable as a bike cable. Swages on those achieve 2kn or a little over 400lbs. Terrifying when you're hanging off it. Not bad if all it needs is to move a derailleur.
SE Wis
Liked 3,408 Times
SE Wis
Liked 3,408 Times
Likes For dedhed:
Junior Samples
Dudes, abide. It's a shifter cable. Absolute worst-case scenario, he rides home on the small cog. Hell, I'd tie it in a blood knot or a surgeon's knot and have a go at it.
Likes For JustinOldPhart:
Liked 4,530 Times
Depending on the frame, also wrap the frame with electrical tape near the splice to protect the paint.
Likes For CliffordK:
Quoted: 428 Post(s)
Liked 67 Times
I tried the aluminum ferrules but I could not crimp them at all. I couldn't find any tubing that wasn't huge so I got some copper plates and folded them over the wires several times then crimped the bejesus out of them. It seems to be holding well enough and I can shift properly but it does look really stupid. It only needs to hold up a couple weeks at most and if it does break then it should not cause any problems because the stays will keep the cable from going anywhere important, I just won't be able to shift for the rest of my ride. Now I just have to find some decent handgrips that don't cost 30 bucks and figure out what shifter to order.
